5MTDA
5MTDA
    JWWINCO
    LOCKABLE PLASTIC HINGE, 2X2 BORE
5MTDA 数据手册
EN 151.2 Lockable Hinges Technopolymer Plastic, with Countersunk Screw Holes Metric ELESA original design CFA-ERS 3 Type C 2x2 bores for countersunk screws Metric table 1 Dimensions in: millimeters - inches 2 l1 48  1.89 l2 49  1.93 d1  5.5  0.22 d2 4 0.16 h1 19  0.75 h2 11  0.43 h3 13  0.51 h4 36  1.42 h5 26  1.02 l3 44  1.73 l4 17  0.67 m1 ±0.2 31  1.22 m 2 ±0.2 30.5  1.20 64  2.52 65  2.56  6.5  0.26 5 0.20 23  0.91 13.5  0.53 15  0.59 36  1.42 30  1.18 44  1.73 24  0.94 40  1.57 40  1.57 98  3.86 98  3.86 10.5  0.41 8 0.31 35  1.38 20.5  0.81 23  0.91 48  1.89 46  1.81 63  2.48 35  1.38 63  2.48 60  2.36 Specification Information • Body Plastic Technopolymer (Polyamide PA) -- Black, matte finish -- Temperature resistant up to 176 °F (80 °C) By utilizing EN 151.2 lockable hinges, doors, flaps, etc. can be locked in any position. • Pin Steel, blackened finish • Safety adjustable lever EN 604.2 Plastic Technopolymer (Polyamide PA) Black When not engaged, the clamping lever is not connected to the hinge pin and is in a “free-wheeling” position. When the operator pushes down on the lever button, it engages itself in two notches and the hinge can be tightened or loosened. This prevents the hinge from being accidentally moved. It also ensures that the lever will never interfere with the movement of the hinge. see also... • List of Hinge Types • Hinges EN 151 (Technopolymer Plastic) • RoHS compliant How to order 1 2 3 EN 151.2-64-65-C 82 | 3.3 Hinging, Latching, Locking of Doors and Covers 1 Width l1 2 Length l 2 3 Type www.jwwinco.com | phone: 1-800-877-8351
5MTDA
物料型号:EN151.2-64-65-C
器件简介: - 该铰链由JWWINCO公司生产,属于Ganter公司。 - 铰链采用技术聚合物塑料(聚酰胺PA)材质,黑色,哑光表面处理。 - 铰链具有耐温性,可承受高达176°F(80°C)的温度。 - 铰链销由钢制成,表面黑色处理。
引脚分配: - 铰链有两个用于沉头螺钉的孔,符合DIN 7991标准。
参数特性: - 铰链的尺寸和参数如下表所示,单位为毫米: - 长度:48、64、98 - 孔径:5.5、6.5、10.5 - 其他尺寸参数:h1、h2、h3、h4、hs等
功能详解: - EN 151.2可锁定铰链允许门、盖板等在任何位置锁定。 - 当未锁定时,夹紧杠杆与铰链销不连接,处于“自由旋转”位置。 - 操作者按下杠杆按钮时,杠杆会自动嵌入两个凹槽中,铰链可以被紧固或松开。 - 这防止了铰链意外移动,同时确保杠杆不会干扰铰链的运动。
应用信息: - 该铰链适用于需要锁定的门、盖板等。
封装信息: - 铰链符合RoHS指令,即限制在电子电气设备中使用某些有害物质的指令。
订购信息: - 订购时需要指定宽度和长度,例如:EN151.2-64-65-C。
5MTDA 价格&库存
很抱歉,暂时无法提供与“5MTDA”相匹配的价格&库存,您可以联系我们找货
