159-69-17.5-25-SW
159-69-17.5-25-SW
    JWWINCO
    TECHNOPOLYMER HINGE, STEEL PIN
159-69-17.5-25-SW 数据手册
Hinges EN 159 Technopolymer Plastic, for Use with Profile Systems Metric ELESA original design CFG. Metric table Dimensions in: millimeters - inches 1 2 3 l1 m1 m2 d1 d2 h1 h2 l2 l3 For profile width s1 - s 2  54   2.13 17.5  0.69 17.5  0.69 6.5 0.26 8 0.31 16  0.63 8 0.31 36  1.42 27  1.06 30 - 30 1.18 - 1.18  64   2.52 17.5  0.69 22.5  0.89 6.5 0.26 8 0.31 16  0.63 8 0.31 36  1.42 27  1.06 30 - 40 1.18 - 1.57  69   2.72 17.5  0.69 25  0.98 6.5 0.26 8 0.31 16  0.63 8 0.31 36  1.42 27  1.06 30 - 45 1.18 - 1.77  84   3.31 17.5  0.69 32.5  1.28 6.5 0.26 8 0.31 16  0.63 8 0.31 36  1.42 27  1.06 30 - 60 1.18 - 2.36  74   2.91 22.5  0.89 22.5  0.89 6.5 0.26 8 0.31 16  0.63 8 0.31 36  1.42 37  1.46 40 - 40 1.57 - 1.57  79   3.11 22.5  0.89 25  0.98 6.5 0.26 8 0.31 16  0.63 8 0.31 36  1.42 37  1.46 40 - 45 1.57 - 1.77  94   3.70 22.5  0.89 32.5  1.28 6.5 0.26 8 0.31 16  0.63 8 0.31 36  1.42 37  1.46 40 - 60 1.57 - 2.36  84   3.31 25  0.98 25  0.98 6.5 0.26 8 0.31 16  0.63 8 0.31 36  1.42 42  1.65 45 - 45 1.77 - 1.77  99   3.90 25  0.98 32.5  1.28 6.5 0.26 8 0.31 16  0.63 8 0.31 36  1.42 42  1.65 45 - 60 1.77 - 2.36 114   4.49 32.5  1.28 32.5  1.28 6.5 0.26 8 0.31 16  0.63 8 0.31 36  1.42 57  2.24 60 - 60 2.36 - 2.36 Specification 4 Information • Body Plastic Technopolymer (Polyamide PA) SW -- Black, matte finish LG -- Gray, matte finish -- Temperature resistant up to 265 °F (130 °C) EN 159 hinges are suitable for simple installation on standard commercially available T-slot aluminum profile extrusions. They will support the weight of a door by utilizing the provided rectangular positioning elements. These are simply clipped into recesses in the hinge wings. They will fit 8 mm and 10 mm wide grooves. • Pin Steel, nickel plated • Hinges GN 161 (Zinc Die-Cast, for Aluminum Profiles) • RoHS compliant see also... • List of Hinge Types • Double Hinges EN 159.1 (Technopolymer Plastic, for Profile Systems) • T-Nut Assemblies GN 965 (for 30 / 40 Aluminum T-Slot Profile Systems) • T-Nut Assemblies GN 968 (for 30 / 40 / 45 Aluminum T-Slot Profile Systems) How to order 1 2 3 4 EN 159-84-17.5-32.5-SW 52 | 3.3 Hinging, Latching, Locking of Doors and Covers 1 Width l1 2 Bore distance m1 3 Bore distance m 2 4 Color www.jwwinco.com | phone: 1-800-877-8351 EN 159 Hinges continued Positioning elements Profile width b Groove width Application example a 30 1.18 6 0.24 2 0.08 30 1.18 8 0.31 2 0.08 40 - 45 1.57 - 1.77 8 0.31 4 0.16 40 - 45 1.57 - 1.77 10 0.39 4 0.16 60 2.36 10 0.39 5 0.20 60 2.36 12 0.47 5 0.20 The positioning elements are clipped into the corresponding recesses of the hinge wing. www.jwwinco.com | phone: 1-800-877-8351 3.3 Hinging, Latching, Locking of Doors and Covers | 53
159-69-17.5-25-SW 价格&库存
很抱歉,暂时无法提供与“159-69-17.5-25-SW”相匹配的价格&库存,您可以联系我们找货
