161.2-32-63-R-SR
161.2-32-63-R-SR
    JWWINCO
    ZINC DIE-CAST HINGE, SILVER
161.2-32-63-R-SR 数据手册
GN 161.2 Hinges Zinc Die-Cast Metric 3 Form R Fixed bearing (Pin) right L Fixed bearing (Pin) left Metric table Dimensions in: millimeters - inches 1 2 b1  l1 b2 d l2 l3 l4 l5 m1 m2 m3 t Radial load Axial load 32  1.26 63  2.48 15  0.59 M5 17  0.67 31  1.22 6.1 0.24 10  0.39 19  0.75 50.8  2.00 17  0.67 10  0.39 700 N 157 lbf 2000 N   450 lbf Specification Thread 4 • Zinc die-cast, powder coated textured finish SW Black, RAL 9005, textured finish SR Silver, RAL 9006, textured finish • RoHS compliant Information GN 161.2 hinges are a unique variation with a highly attractive design. The mounting screws are concealed. During load tests, these hinges were gradually loaded and relieved at room temperature with incrementally increasing force. For the specified values, an insignificant permanent deformation remained after relieving the load which had no effect on the function and appearance. In most cases, the failure loads are multiples of the specified value. Indicated load bearing capacities are non-binding recommended values and constitute no general warranty of quality and condition. The user must determine from case to case whether a product is suitable for the intended use. Environmental influences and aging may influence these values. How to order 1 2 3 4 GN 161.2-32-63-R-SW 72 | 3.3 Hinging, Latching, Locking of Doors and Covers 1 Width b1 2 Length l1 3 Type 4 Color www.jwwinco.com | phone: 1-800-877-8351
161.2-32-63-R-SR 价格&库存
很抱歉,暂时无法提供与“161.2-32-63-R-SR”相匹配的价格&库存,您可以联系我们找货
