238-60-60-NJ-SW
238-60-60-NJ-SW
    JWWINCO
    238-60-60-NJ-SW FIXED HINGE
238-60-60-NJ-SW 数据手册
Hinges GN 238 Zinc Die-Cast, Adjustable, with Cover Caps Metric iF product design award 3 Type BJ Adjustable on both sides EJ Adjustable on one side NJ Not adjustable Metric table 1 Dimensions in: millimeters - inches 2 l1 42  1.65 l2 42  1.65 d1 5.3 0.21 d2 4 0.16 h1 ≈ 11  0.43 h 2 ≈ 6.5 0.26 h3  7.5  0.30 l3 17  0.67 m1 25  0.98 m2 25  0.98 50  1.97 50  1.97 6.3 0.25 5 0.20 13.5  0.53 7 0.28  8.5  0.33 21  0.83 30  1.18 30  1.18 60  2.36 60  2.36 6.3 0.25 6 0.24 16.5  0.65 8.5 0.33 11  0.43 26  1.02 36  1.42 36  1.42 Specification 4 • Body GN 238 hinges allow a technically and visually perfect alignment of the door to its frame. Zinc die-cast, powder coated Black, RAL 9005, textured finish Silver, RAL 9006, textured finish SW SR • Adjustable disk Steel, hardened • Cover cap Plastic -- Black-gray for SW -- Light gray for SR • Pin Stainless steel AISI 303 • Load Information Rating Information → page 2088 • Stainless • RoHS Steel Characteristics → page 2143 Hinge is available with both sides adjustable (Type BJ), one side adjustable (Type EJ), and fixed hole type (Type NJ). The steel adjustable disk has a serrated ring on its bottom side that seats into the radially positioned serrations of the zinc hinge plate when the countersunk screw is tightened. This secures the disk in place (patented). The plastic cover hides the adjustable disk and the screw to prevent dirt from entering, and also provides a clean, appealing look. see also... • List of Hinge Types → page 1324 • Adjustable • Hinges Alignment Hinges GN 127 (Zinc Die-Cast) → page 1404 EN 236 (Technopolymer Plastic, Adjustable) → www.jwwinco.com compliant How to order 1 2 3 4 GN 238-50-50-BJ-SW 1402 | WARNING: Cancer and Reproductive Harm — www.P65Warnings.ca.gov 1 Width l1 2 Length l 2 3 Type 4 Color www.jwwinco.com | phone: 1-800-877-8351 GN 238 Adjustable Alignment Hinges continued Swiveling range Operating principle (Type BJ) Assembly instruction www.jwwinco.com | phone: 1-800-877-8351 WARNING: Cancer and Reproductive Harm — www.P65Warnings.ca.gov | 1403
238-60-60-NJ-SW 价格&库存
很抱歉,暂时无法提供与“238-60-60-NJ-SW”相匹配的价格&库存,您可以联系我们找货
