256-32-M8-30-55-GR
256-32-M8-30-55-GR
    JWWINCO
    SILICONE BUMPER CONICAL, S.S.
256-32-M8-30-55-GR 数据手册
Silicone Vibration / Shock Absorption Mounts GN 256 Conical Type, with Stainless Steel Components Inch | Metric Inch table 1 2 d1 d2 Length l   .75 19       10 x 24   .39 10      .98 25      1/4 x 20  1.26 32    Dimensions in: inches - millimeters 3 d3 h s t Spring rate ≈ Hardness 55   .75 19      .47 12      .63 16     .08 2      .20  5    360 lbf/in 63 N/mm 56.20 lbf 250 N   .16  4      .51 13      .98 25      .65 16.5    .81 20.5   .08 2      .24  6    514 lbf/in 90 N/mm 103 lbf 460 N   .20  5.1  5/16 x 18   .63 16     1.26 32      .83 21     1.02 26     .08 2      .31  8    668 lbf/in 117 N/mm 171 lbf 760 N   .26  6.5   1.50 38    5/16 x 18   .63 16     1.26 32      .96 24.5   1.26 32     .08 2      .31  8    645 lbf/in 113 N/mm 202 lbf 900 N   .31  8     1.97 50      3/8 x 16   .63 16     1.26 32     1.26 32     1.69 43     .08 2      .39 10    845 lbf/in 148 N/mm 355 lbf 1580 N   .42 10.7  Thread Max. load Hardness 55 Max. deflection ≈ Metric table Dimensions in: millimeters - inches 1 2 3 d1 d2 Length l 19      .75 M 5  6      .24 10      .39 25      .98 M 6  8      .31 32     1.26 M 8 38     1.50 50     1.97 d3 h s t Spring rate ≈ Hardness 55 Max. load Hardness 55 Max. deflection ≈ 20      .79 12      .47 16      .63 2     .08  5      .20 63 N/mm 360 lbf/in 250 N 56.20 lbf  4      .16 12      .47 25      .98 16.5    .65 20.5    .81 2     .08  6      .24 90 N/mm 514 lbf/in 460 N 103 lbf  5.1    .20 10      .39 16      .63 30     1.18 21      .83 26     1.02 2     .08  8      .31 117 N/mm 668 lbf/in 760 N 171 lbf  6.5    .26 M 8 10      .39 16      .63 30     1.18 24.5    .96 32     1.26 2     .08  8      .31 113 N/mm 645 lbf/in 900 N 202 lbf  8      .31 M 10 12      .47 20      .79 40     1.57 32     1.26 43     1.69 2     .08 10      .39 148 N/mm 845 lbf/in 1580 N 355 lbf 10.7    .42 Thread Specification 4 5 • Mount body Silicone natural rubber Elastosil® (MVQ) -- FDA compliant GR -- Gray -- Vulcanized to the cover plate -- Temperature resistant up to 392 °F (200 °C) -- Shore hardness A ±5 Medium 55 • Cover plate, tapped insert, threaded stud Stainless steel European Standard No. 1.4301 (AISI 304) • RoHS compliant • Other colors 2 GN 256 silicone vibration / shock absorption mounts are frequently used as end-stop bumpers, e.g. for conveyors. The silicone rubber used is age-resistant and has an increased working temperature range. Due to the material purity, use is possible in the food and medical industry. They absorb most of the accumulated kinetic energy on impact. They act as dampers and prevent damaging shock and rebound. They also act as sound dampers. These mounts are also used as set-up elements and leveling feet. How to order (With tapped hole) 1 4 2 5 GN 256-38-5/16X18-55-GR On request • Versions with shore hardness A ±5 -- Soft -- Hard Information How to order (With threaded stud) 40 70 1 2 3 4 5 GN 256-25-M6-25-55-GR | 3.4 Installing, Lifting, Dampening with Leveling Feet, Lifting Gear and Rubber Elements 1 Outside diameter d1 2 Thread d 2 4 Hardness 5 Color 1 Outside diameter d1 2 Thread d 2 3 Length l 4 Hardness 5 Color www.jwwinco.com | phone: 1-800-877-8351
256-32-M8-30-55-GR 价格&库存
很抱歉,暂时无法提供与“256-32-M8-30-55-GR”相匹配的价格&库存,您可以联系我们找货
