256-32-5/16X18-55-GR 数据手册
Silicone Vibration / Shock Absorption Mounts
GN 256
Conical Type, with Stainless Steel Components
Inch | Metric
Inch table
1
2
d1
d2
Length l
.75
19
10 x 24
.39
10
.98
25
1/4 x 20
1.26
32
Dimensions in: inches - millimeters
3
d3
h
s
t
Spring rate ≈
Hardness 55
.75
19
.47
12
.63
16
.08
2
.20
5
360 lbf/in
63 N/mm
56.20 lbf
250 N
.16
4
.51
13
.98
25
.65
16.5
.81
20.5
.08
2
.24
6
514 lbf/in
90 N/mm
103 lbf
460 N
.20
5.1
5/16 x 18
.63
16
1.26
32
.83
21
1.02
26
.08
2
.31
8
668 lbf/in
117 N/mm
171 lbf
760 N
.26
6.5
1.50
38
5/16 x 18
.63
16
1.26
32
.96
24.5
1.26
32
.08
2
.31
8
645 lbf/in
113 N/mm
202 lbf
900 N
.31
8
1.97
50
3/8 x 16
.63
16
1.26
32
1.26
32
1.69
43
.08
2
.39
10
845 lbf/in
148 N/mm
355 lbf
1580 N
.42
10.7
Thread
Max. load
Hardness 55
Max. deflection ≈
Metric table
Dimensions in: millimeters - inches
1
2
3
d1
d2
Length l
19
.75
M 5
6
.24
10
.39
25
.98
M 6
8
.31
32
1.26
M 8
38
1.50
50
1.97
d3
h
s
t
Spring rate ≈
Hardness 55
Max. load
Hardness 55
Max. deflection ≈
12
.47
16
.63
2
.08
5
.20
63 N/mm
360 lbf/in
250 N
56.20 lbf
4
.16
12
.47
25
.98
16.5
.65
20.5
.81
2
.08
6
.24
90 N/mm
514 lbf/in
460 N
103 lbf
5.1
.20
10
.39
16
.63
30
1.18
21
.83
26
1.02
2
.08
8
.31
117 N/mm
668 lbf/in
760 N
171 lbf
6.5
.26
M 8
10
.39
16
.63
30
1.18
24.5
.96
32
1.26
2
.08
8
.31
113 N/mm
645 lbf/in
900 N
202 lbf
8
.31
M 10
12
.47
40
1.57
32
1.26
43
1.69
2
.08
10
.39
148 N/mm
845 lbf/in
1580 N
355 lbf
10.7
.42
Thread
Specification
4
5
• Mount body
Silicone natural rubber Elastosil® (MVQ)
-- FDA compliant
GR
-- Gray
-- Vulcanized to the cover plate
-- Temperature resistant up to 392 °F (200 °C)
-- Shore hardness A ±5
Medium
55
• Cover plate, tapped insert, threaded stud
Stainless steel
European Standard No. 1.4301 (AISI 304)
• RoHS compliant
• Other colors
2
GN 256 silicone vibration / shock absorption mounts are frequently used as end-stop bumpers, e.g.
for conveyors.
The silicone rubber used is age-resistant and has an increased working temperature range. Due to the
material purity, use is possible in the food and medical industry.
They absorb most of the accumulated kinetic energy on impact. They act as dampers and prevent
damaging shock and rebound. They also act as sound dampers.
These mounts are also used as set-up elements and leveling feet.
How to order (With tapped hole)
1
4
2
5
GN 256-38-5/16X18-55-GR
On request
• Versions with shore hardness A ±5
-- Soft
-- Hard
Information
How to order (With threaded stud)
40
70
1
2
3
4
5
GN 256-25-M6-25-55-GR
| 3.4 Installing, Lifting, Dampening with Leveling Feet, Lifting Gear and Rubber Elements
1
Outside diameter d1
2
Thread d 2
4
Hardness
5
Color
1
Outside diameter d1
2
Thread d 2
3
Length l
4
Hardness
5
Color
www.jwwinco.com | phone: 1-800-877-8351
256-32-5/16X18-55-GR 价格&库存
很抱歉,暂时无法提供与“256-32-5/16X18-55-GR”相匹配的价格&库存,您可以联系我们找货
