5NA06K
5NA06K
    JWWINCO
    ADJ LEVER ZINC DIE-CAST, S.S.
5NA06K 数据手册
GN 300.1 Adjustable Levers Zinc Die-Cast, Tapped or Plain Bore Type, with Stainless Steel Components Inch | Metric Specification 3 • Lever body Zinc die-cast Information GN 300.1 adjustable levers have proven to be ideal wherever parts have to be clamped in a confined space or in a particular lever position. The insert is connected to the lever via serrations that can easily be disengaged. • Powder coated Black, RAL 9005, textured finish Orange, RAL 2004, textured finish Red, RAL 3000, textured finish Silver, RAL 9006, textured finish SW OS RS SR • Chrome-plated finish CR • Uncoated, tumbled finish RH • Insert / retaining screw Stainless steel European Standard No. 1.4305 (AISI 303) Pulling the lever upwards disengages the serrations, allowing it to be swiveled to the ideal clamping position. When releasing the lever, the serrations automatically re-engage. see also... • Adjustable Levers GN 300 (with Steel Insert) • Adjustable Levers GN 300.5 (Stainless Steel, Matte Shot-Blasted Finish) • Adjustable Levers GN 303.1 (with Push Button) • RoHS compliant On request • Black, RAL 9011, silk shiny finish SZ • Special colors, bores, and threads How to order (Inch) 1 2 3 GN 300.1-30-10X32-SW How to order (Metric) 1 2 3 GN 300.1-78-M10-OS 12 | 2.1 Tensioning, Clamping, Switching with Levers 1 Lever length l1 2 Thread d1 3 Color (Finish) 1 Lever length l1 2 Thread d1 (Bore d 2 ) 3 Color (Finish) www.jwwinco.com | phone: 1-800-877-8351 GN 300.1 Adjustable Levers continued Inch table 1 2 l1 d1 Dimensions in: inches - millimeters 2 d 2 +0.001 Thread d3 Bore 1.18 30 10 x 32 1/4 x 20 B 1/4 - 1.77 45 10 x 32 1/4 x 20 B 1/4 - 2.48 63 1/4 x 20 5/16 x 18 B 1/4 B 5/16 3.07 78 5/16 x 18 3/8 x 16 B 5/16 B 3/8 3.62 92 3/8 x 16 1/2 x 13 B 3/8 B 1/2 10 10 d4 .39 16 19 .63 h4 .16 1.22 31 .14 3.5 8 8 Stroke 4 .51 .96 24.5 4 .16 1.34 34 .14 3.5 .69 17.5 1.22 31 .26 6.5 1.77 45 4 .83 1.42 36 8 .31 2.13 54 4 .94 24 1.69 43 11 .43 2.52 64 4 21 .75 h3 .96 24.5 13 .53 13.5 h2 .51 13 .39 h1 .16 .16 .16 t min. 11 14 17 .31 .31 .43 .55 .67 Metric table 1 2 l1 d1 Dimensions in: millimeters - inches 2 d 2 H7 Bore Thread d3 d4 h1 h2 13 .51 24.5 .96 4 .51 24.5 .96 4 4 h3 h4 .16 31 1.22 3.5 .14 7 .16 31 1.22 3.5 .14 8 3.5 .14 8 Stroke 30 1.18 M 3 - - - - 10 30 1.18 M 4 M 5 M 6 B 5 B 6 10 45 1.77 M 4 M 5 M 6 B 5 B 6 10 .51 24.5 .96 .16 34 1.34 63 2.48 M 6 M 8 - B 8 - 13.5 .53 17.5 .69 31 1.22 6.5 .26 45 1.77 4 78 3.07 M 8 M 10 M 12 B 8 B 10 16 21 .83 36 1.42 8 .31 54 2.13 4 92 3.62 M 10 M 12 - B 12 - 19 .94 43 1.69 11 .43 64 2.52 4 108 4.25 M 12 M 16 - B 12 B 16 23 30 1.18 50.5 1.99 12 .47 75 2.95 5 www.jwwinco.com | phone: 1-800-877-8351 .39 .39 .39 .63 .75 .91 13 13 24 .16 .16 .16 .20 t min. .28 .31 .31 11 14 17 22 .43 .55 .67 .87 2.1 Tensioning, Clamping, Switching with Levers | 13
5NA06K 价格&库存
很抱歉,暂时无法提供与“5NA06K”相匹配的价格&库存,您可以联系我们找货
