6T20A07K
6T20A07K
    JWWINCO
    ADJ LEVER ZINC DIE-CAST, S.S.
6T20A07K 数据手册
GN 300.1 Adjustable Levers Zinc Die-Cast, Threaded Stud Type, with Stainless Steel Components Inch | Metric Specification 4 • Lever body Zinc die-cast Information GN 300.1 adjustable levers have proven to be ideal wherever parts have to be clamped in a confined space or in a particular lever position. The insert is connected to the lever via serrations that can easily be disengaged. • Powder coated Black, RAL 9005, textured finish Orange, RAL 2004, textured finish Red, RAL 3000, textured finish Silver, RAL 9006, textured finish SW OS RS SR • Chrome-plated finish CR • Uncoated, tumbled finish RH • Threaded stud / retaining screw Stainless steel European Standard No. 1.4035 (AISI 303) Pulling the lever upwards disengages the serrations, allowing it to be swiveled to the ideal clamping position. When releasing the lever, the serrations automatically re-engage. see also... • Adjustable Levers GN 300 (with Steel Threaded Stud) • Adjustable Levers GN 300.5 (Stainless Steel, Matte Shot-Blasted Finish) • Adjustable Levers GN 303.1 (with Push Button) • RoHS compliant On request • Black, RAL 9011, silk shiny finish SZ • Special colors, stud lengths, and threads How to order (Inch) 1 2 3 4 GN 300.1-92-1/2X13-40-SW How to order (Metric) 1 2 3 4 GN 300.1-63-M8-32-RS 14 | 2.1 Tensioning, Clamping, Switching with Levers 1 Lever length l1 2 Thread d1 3 Thread length l 2 4 Color (Finish) 1 Lever length l1 2 Thread d1 3 Thread length l 2 4 Color (Finish) www.jwwinco.com | phone: 1-800-877-8351 GN 300.1 Adjustable Levers continued Inch table 1 2 3 l1 d1 l2 Thread 1.18 30 10 x 32 1.18 30 10 x 24 1.18 30 1/4 x 20 1.77 45 10 x 32 1.77 45 10 x 24 1.77 45 1/4 x 20 2.48 63 5/16 x 18 2.48 63 Dimensions in: inches - millimeters d3 .63 .79 20 - - - - - .63 .79 20 .98 25 1.26 32 - - - .63 .79 20 .98 25 1.26 32 1.57 40 1.77 45 - .63 .79 20 .98 25 1.26 32 - - - - - - - - - .63 .79 20 .98 25 1.26 32 1.57 40 1.77 45 - .63 .79 20 .98 25 1.26 32 1.57 40 1.77 45 1.97 50 2.48 63 3/8 x 16 .79 20 .98 25 1.26 32 1.57 40 - - - - 3.07 78 3/8 x 16 .79 20 .98 25 1.26 32 1.57 40 1.77 45 1.97 50 2.48 63 - 3.07 78 1/2 x 13 .79 20 .98 25 1.26 32 1.57 40 1.97 50 - - - 3.62 92 1/2 x 13 .98 25 1.26 32 1.57 40 1.77 45 1.97 50 2.48 63 - - 12 12 12 12 16 12 16 .47 16 .47 16 .47 16 .47 16 .63 .47 - 16 d4 h2 h3 h4 .16 1.22 31 .14 3.5 .16 1.22 31 .14 3.5 .16 1.22 31 .14 3.5 .16 1.34 34 .14 3.5 .16 1.34 34 .14 3.5 Stroke .51 .96 24.5 4 .51 .96 24.5 4 .51 .96 24.5 4 .51 .96 24.5 4 .51 .96 24.5 4 .51 .96 24.5 4 .16 1.34 34 .14 3.5 .53 13.5 .69 17.5 1.22 31 .26 6.5 1.77 45 4 .53 13.5 .69 17.5 1.22 31 .26 6.5 1.77 45 4 .83 1.42 36 8 .31 2.13 54 4 .83 1.42 36 8 .31 2.13 54 4 .94 24 1.69 43 11 .43 2.52 64 4 10 10 .39 h1 .39 10 10 10 10 16 16 19 .39 .39 .39 .39 .63 .63 .75 13 13 13 13 13 13 21 21 .16 .16 .16 .16 .16 Metric table 1 2 3 l1 d1 l2 Thread Dimensions in: millimeters - inches 30 1.18 M 3 - - 6 30 1.18 M 4 - - 12 30 1.18 M 5 M 6 - 12 45 1.77 M 4 - - 12 45 1.77 M 5 M 6 - 12 63 M 6 2.48 M 8 - 16 78 M 8 3.07 M 10 M 12 20 92 M 10 3.62 M 12 - 20 108 M 12 4.25 M 16 - 32 1.26 .24 .47 .47 .47 .47 .63 .79 .79 www.jwwinco.com | phone: 1-800-877-8351 8 16 .31 10 .39 .63 h1 13 .51 24.5 .96 4 .51 24.5 .96 4 .51 24.5 .96 4 .51 24.5 .96 4 .51 24.5 .96 4 - - 10 .39 h3 h4 .16 31 1.22 3.5 .14 .16 31 1.22 3.5 .14 .16 31 1.22 3.5 .14 .16 34 1.34 3.5 .14 .16 34 1.34 3.5 .14 Stroke - - 10 .98 32 1.26 40 1.57 50 1.97 10 .98 32 1.26 - - 10 .98 32 1.26 40 1.57 50 1.97 10 .98 32 1.26 40 1.57 50 1.97 63 2.48 13.5 .53 17.5 .69 31 1.22 6.5 .26 45 1.77 4 .98 32 1.26 40 1.57 50 1.97 63 2.48 80 3.15 16 21 .83 36 1.42 8 .31 54 2.13 4 .98 32 1.26 40 1.57 50 1.97 63 2.48 80 3.15 19 .94 43 1.69 11 .43 64 2.52 4 40 1.57 50 1.97 63 2.48 80 3.15 - - 23 30 1.18 50.5 1.99 12 .47 75 2.95 5 16 16 16 20 25 25 .63 .63 .63 .79 20 20 20 25 .79 .79 .79 25 25 25 .39 .39 .39 .39 .63 .75 .91 13 h2 32 1.26 .79 25 .47 16 d4 .98 .63 20 12 d3 13 13 13 24 .16 .16 .16 .20 2.1 Tensioning, Clamping, Switching with Levers | 15
6T20A07K
物料型号:GN 300.1 可调杠杆
器件简介:GN 300.1 可调杠杆适用于需要在狭窄空间或特定杠杆位置固定部件的场合。通过可以轻松脱开的锯齿与杠杆连接。
引脚分配:文档中未提及引脚分配,因为这是一个机械部件,不是电子元件。
参数特性: - 杠杆体材料:锌合金压铸 - 表面处理:粉末涂层,有黑色(RAL 9005)、橙色(RAL 2004)、红色(RAL 3000)、银色(RAL 9006)、镀铬和未涂层磨砂等多种选择 - 螺纹杆/紧固螺丝:不锈钢,符合欧洲标准1.4035(AISI 303)
功能详解:向上拉动杠杆可以脱开锯齿,允许其旋转到理想的夹紧位置。释放杠杆时,锯齿会自动重新啮合。
应用信息:适用于张紧、夹紧、开关等操作。
封装信息:文档中提供了详细的尺寸信息,包括杠杆长度、螺纹直径和长度等,以英寸和毫米为单位。
6T20A07K 价格&库存
很抱歉,暂时无法提供与“6T20A07K”相匹配的价格&库存,您可以联系我们找货
