333-1.10-20.00-A-EL
333-1.10-20.00-A-EL
    JWWINCO
    HANDLE ALUMINUM MTG CTR 20
333-1.10-20.00-A-EL 数据手册
GN 333 Tubular Handles Aluminum, with Angled Legs Inch | Metric 3 Type A Mounting from the back (tapped blind hole) B Mounting from the operator’s side (only for d1=28) Specification 4 • Tube Aluminum (wall thickness 1.5 mm) The handle legs of GN 333 tubular handles are highly stable in relation to their small dimensions. Tube and legs are secured together with self-tapping screws and do not require any further machining or processing steps allowing even small quantities of special lengths to be manufactured. Screw heads are covered with plastic covers to provide a clean and finished look. • Handle legs Zinc die-cast, powder coated • Tube / handle legs Powder coated Black, RAL 9005, textured finish SW • Tube Anodized finish, natural color EL Typical use is on double winged swinging doors and sliding doors on machines. see also... • Product Range Standard Parts for Profile Systems • Tubular Handles GN 333.1 (with Straight Legs) • Tubular Handles GN 332 (with Power switching Function) Handle legs Black, RAL 9005, textured finish • Tube Anodized finish, natural color Information • T-Nut Assemblies GN 965 (for 30 / 40 mm T-Slot Profile Systems) ES • T-Nut Assemblies GN 968 (for 30 / 40 / 45 mm T-Slot Profile Systems) Handle legs Silver, RAL 9006, textured finish • Covers Plastic, light gray • Cover caps (Type B) Plastic, Technopolymer -- Black (for SW / EL) -- Light gray (for ES) • RoHS compliant Accessory • Angled handle legs GN 333.8 On request • Special tube lengths other than listed How to order 1 2 3 4 GN 333-0.79-7.00-A-EL 60 | 1.2 Operating by Using Machine and Device Handles 1 Handle diameter d1 2 Length l 3 Type 4 Finish www.jwwinco.com | phone: 1-800-877-8351 GN 333 Tubular Handles continued Inch table 1 Dimensions in: inches - millimeters 2 d1 Length l ±0.01 d2 .79 20.1 7.00 177.8 8.00 203.2 10.00 254.0 12.00 304.8 16.00 406.4 - 1.10 27.9 8.00 203.2 10.00 254.0 12.00 304.8 16.00 406.4 20.00 508.0 24.00 609.6 b1 b2 b3 b4 h1 h2 t 1/4 x 20 .94 23.9 .47 11.9 1.65 41.9 2.13 54.1 1.65 41.9 2.13 54.1 .47 11.9 5/16 x 18 .98 24.9 .55 14.0 1.97 50.0 2.60 66.0 1.97 50.0 2.60 66.0 .59 15.0 Thread min. Metric table 1 Dimensions in: millimeters - inches 2 d1 Length l ±0.25 20 .79 180 7.09 200 7.87 250 9.84 300 11.81 350 13.78 400 15.75 28 1.10 200 7.87 250 9.84 300 11.81 350 13.78 400 15.75 500 19.69 30 1.18 200 7.87 300 11.81 350 13.78 400 15.75 500 19.69 600 23.62 d2 b1 b2 b3 b4 h1 h2 t M6 24 12 .47 42 1.65 54 2.13 42 1.65 54 2.13 12 600 23.62 M8 25 .55 50 1.97 66 2.60 50 1.97 66 2.60 15 1000 39.37 M8 27 1.06 .67 51 2.01 68 2.68 51 2.01 68 2.68 15 Thread www.jwwinco.com | phone: 1-800-877-8351 - .94 .98 14 17 min. 1.2 Operating by Using Machine and Device Handles | .47 .59 .59 61
333-1.10-20.00-A-EL 价格&库存
很抱歉,暂时无法提供与“333-1.10-20.00-A-EL”相匹配的价格&库存,您可以联系我们找货
