GN 333
Tubular Handles
Aluminum, with Angled Legs
Inch | Metric
3 Type
A Mounting from the back
(tapped blind hole)
B Mounting from the operator’s side
(only for d1=28)
Specification
4
• Tube
Aluminum (wall thickness 1.5 mm)
The handle legs of GN 333 tubular handles are highly stable in relation to their small dimensions. Tube
and legs are secured together with self-tapping screws and do not require any further machining or
processing steps allowing even small quantities of special lengths to be manufactured. Screw heads
are covered with plastic covers to provide a clean and finished look.
• Handle legs
Zinc die-cast, powder coated
• Tube / handle legs
Powder coated
Black, RAL 9005, textured finish
SW
• Tube
Anodized finish, natural color
EL
Typical use is on double winged swinging doors and sliding doors on machines.
see also...
• Product Range Standard Parts for Profile Systems
• Tubular Handles GN 333.1 (with Straight Legs)
• Tubular Handles GN 332 (with Power switching Function)
Handle legs
• Tube
Information
• T-Nut Assemblies GN 965 (for 30 / 40 mm T-Slot Profile Systems)
ES
• T-Nut Assemblies GN 968 (for 30 / 40 / 45 mm T-Slot Profile Systems)
Handle legs
Silver, RAL 9006, textured finish
• Covers
Plastic, light gray
• Cover caps (Type B)
Plastic, Technopolymer
-- Black (for SW / EL)
-- Light gray (for ES)
• RoHS compliant
Accessory
• Angled handle legs GN 333.8
On request
• Special tube lengths other than listed
How to order
1
2
3
4
GN 333-0.79-7.00-A-EL
60
| 1.2 Operating by Using Machine and Device Handles
1
Handle diameter d1
2
Length l
3
Type
4
Finish
www.jwwinco.com | phone: 1-800-877-8351
GN 333 Tubular Handles continued
Inch table
1
Dimensions in: inches - millimeters
2
d1
Length l ±0.01
d2
.79
20.1
7.00
177.8
8.00
203.2
10.00
254.0
12.00
304.8
16.00
406.4
1.10
27.9
8.00
203.2
10.00
254.0
12.00
304.8
16.00
406.4
20.00
508.0
24.00
609.6
b1
b2
b3
b4
h1
h2
t
1/4 x 20
.94
23.9
.47
11.9
1.65
41.9
2.13
54.1
1.65
41.9
2.13
54.1
.47
11.9
5/16 x 18
.98
24.9
.55
14.0
1.97
50.0
2.60
66.0
1.97
50.0
2.60
66.0
.59
15.0
Thread
min.
Metric table
1
Dimensions in: millimeters - inches
2
d1
Length l ±0.25
180
7.09
200
7.87
250
9.84
300
11.81
350
13.78
400
15.75
28
1.10
200
7.87
250
9.84
300
11.81
350
13.78
400
15.75
500
19.69
30
1.18
200
7.87
300
11.81
350
13.78
400
15.75
500
19.69
600
23.62
d2
b1
b2
b3
b4
h1
h2
t
M6
24
12
.47
42
1.65
54
2.13
42
1.65
54
2.13
12
600
23.62
M8
25
.55
50
1.97
66
2.60
50
1.97
66
2.60
15
1000
39.37
M8
27
1.06
.67
51
2.01
68
2.68
51
2.01
68
2.68
15
Thread
.94
.98
14
17
min.
1.2 Operating by Using Machine and Device Handles |
.47
.59
.59
61
很抱歉,暂时无法提供与“333-28-500-B-EL”相匹配的价格&库存,您可以联系我们找货
