GN 343.1
GN 343.2
Leveling Feet
Tapped Socket Type
Threaded Stud Type
Steel, with or without Plastic / Rubber Cap
Metric
4
Type
OS
KS
KR
KSE
Without cap
With plastic cap, gliding
With rubber cap, non-skid
With plastic cap, gliding,
electrically conductive (antistatic)
KRE With rubber cap, non-skid,
Specification
Information
• Base / tapped socket
Steel, zinc plated, blue passivated finish
The static load capacity of GN 343.2 leveling feet results from the permissible load capacity of the
threaded stud (property class 5.8).
• Threaded stud
Steel
-- Property class 5.8
-- Zinc plated, blue passivated finish
The values for static load capacity listed in the table (only valid for type OS, KS and KSE) refer to a purely
vertical load to the ball socket. Under normal operating conditions, bending loads or angular loads are
not uncommon and result in a reduction of the load capacity, which must be taken into consideration.
• Type KS / KSE
Plastic cap
Technopolymer (Polyacetal POM)
-- KS: White, RAL 9001, natural color
-- KSE: Black, electrically conductive
Surface resistivity
很抱歉,暂时无法提供与“10N63M81”相匹配的价格&库存,您可以联系我们找货
