12NMA4N
12NMA4N
    JWWINCO
    STEEL LEVELING FEET
12NMA4N 数据手册
GN 343.3 GN 343.4 Leveling Feet Tapped Socket Type Threaded Stud Type Steel, Plastic Base, with or without Rubber Pad Metric 4 Type A Without rubber pad G With rubber pad Specification Information • Base Plastic Technopolymer (Polyamide PA) -- Glass fiber reinforced -- Temperature resistant up to 212 °F (100 °C) -- Black, matte finish GN 343.3 and GN 343.4 leveling feet can bear high static loads through the use of a high quality plastic material, coupled with a design that distributes the load over a larger area. • Tapped socket Steel, zinc plated, blue passivated finish Depending on the application and load case, however, a safety factor must be considered so that the permissible load capacity is below the value given in the table. • Threaded stud Steel -- Property class 5.8 -- Zinc plated, blue passivated finish These leveling feet are supplied assembled but can be disassembled. • Hexagon nut ISO 4032 Steel, zinc plated, blue passivated finish • Rubber pad Perbunan® (NBR) 70 shore A Black Exceeding the static values listed in the table can result in damage to the plastic base. The values in the table were determined by a series of tests, where a limited number of leveling feet were subjected to a vertical static load, in relation to the foot, for a limited time. see also... • Leveling Feet GN 343.1 / GN 343.2 (Steel) • Leveling Feet GN 343.7 / GN 343.8 (Plastic Base, Stainless Steel Tapped Socket / Threaded Stud) • Leveling Feet GN 343.5 / GN 343.6 (Stainless Steel) • Vibration Damping Leveling Feet GN 342.1 / GN 342.2 • Threaded Tube Ends EN 448 • RoHS compliant On request • ESD version (conductive plastic to avoid static charge; see also GN 343.1 / GN 343.2, type KSE or KRE) How to order (Tapped socket type) 1 2 4 GN 343.3-32-M10-A How to order (Threaded stud type) 1 2 3 4 GN 343.4-60-M16-80-G 2 | 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements 1 Base diameter d1 2 Thread d 2 4 Type 1 Base diameter d1 2 Thread d 2 3 Stud length l1 4 Type www.jwwinco.com | phone: 1-800-877-8351 GN 343.3 / GN 343.4 Leveling Feet continued Metric table 1 2 3 d1 d2 l1 Dimensions in: millimeters - inches l2 l3 A/F t min. Static load (See information) GN 343.4 GN 343.4 25 0.98 M 6 M 6 40 1.57 50 1.97 63 2.48 18.5 0.73 4 0.16 12 0.47 9 0.35 5 kN 1124 lbf 25 0.98 M 8 M 8 40 1.57 50 1.97 63 2.48 18.5 0.73 4 0.16 12 0.47 9 0.35 5 kN 1124 lbf 25 0.98 - M 10 50 1.97 63 2.48 80 3.15 18.5 0.73 4 0.16 12 0.47 32 1.26 M 8 M 8 40 1.57 50 1.97 63 2.48 22.5 0.89 5 0.20 12 0.47 9 0.35 7 kN 1574 lbf 32 1.26 M 10 M 10 50 1.97 63 2.48 80 3.15 22.5 0.89 5 0.20 15 0.59 10.5 0.41 7 kN 1574 lbf 32 1.26 - M 12 63 2.48 80 3.15 100 3.94 22.5 0.89 5 0.20 15 0.59 - 7 kN 1574 lbf 40 1.57 - M 8 50 1.97 63 2.48 80 3.15 25.5 1.00 6 0.24 15 0.59 - 10 kN 2248 lbf 40 1.57 M 10 M 10 50 1.97 63 2.48 80 3.15 25.5 1.00 6 0.24 15 0.59 10.5 0.41 10 kN 2248 lbf 40 1.57 M 12 M 12 63 2.48 80 3.15 100 3.94 25.5 1.00 6 0.24 17 0.67 11.5 0.45 10 kN 2248 lbf 50 1.97 - M 8 50 1.97 63 2.48 80 3.15 27.5 1.08 7 0.28 15 0.59 - 10 kN 2248 lbf 50 1.97 M 10 M 10 50 1.97 63 2.48 80 3.15 27.5 1.08 7 0.28 15 0.59 10.5 0.41 10 kN 2248 lbf 50 1.97 M 12 M 12 63 2.48 80 3.15 100 3.94 27.5 1.08 7 0.28 17 0.67 11.5 0.45 10 kN 2248 lbf 50 1.97 - M 16 63 2.48 80 3.15 100 3.94 27.5 1.08 7 0.28 17 0.67 - 10 kN 2248 lbf 60 2.36 - M 10 50 1.97 63 2.48 80 3.15 27.5 1.08 7 0.28 17 0.67 - 10 kN 2248 lbf 60 2.36 M 12 M 12 63 2.48 80 3.15 100 3.94 35.5 1.40 8.5 0.33 17 0.67 11.5 0.45 14 kN 3147 lbf 60 2.36 M 16 M 16 80 3.15 100 3.94 125 4.92 35.5 1.40 8.5 0.33 24 0.94 16 0.63 14 kN 3147 lbf 60 2.36 - M 20 98 3.86 138 5.43 158 6.22 35.5 1.40 8.5 0.33 24 0.94 - 14 kN 3147 lbf 60 2.36 - M 24 98 3.86 138 5.43 158 6.22 35.5 1.40 8.5 0.33 24 0.94 - 14 kN 3147 lbf www.jwwinco.com | phone: 1-800-877-8351 - 5 kN 1124 lbf 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements | 3
12NMA4N 价格&库存
很抱歉,暂时无法提供与“12NMA4N”相匹配的价格&库存,您可以联系我们找货
