GN 351.1
GN 451.1
Vibration Isolation Mounts
Steel
Stainless Steel
Cylindrical Type
Inch
Specification
4
Information
• Mount body
GN 351.1 and GN 451.1 vibration isolation mounts are suitable for the elastic mounting of machine units
Natural rubber (NR)
such as motors, compressors and pumps.
-- Black
These rubber mounts are simple and economical construction elements. Their resilience and their
-- Vulcanized to the cover plate
broad range of different sizes and dimensions allow these mounts to be used in many applications that
-- Shore hardness A ±5
require vibration isolation.
Medium
55
For metric versions see GN 351 or GN 451.
• GN 351.1
see also...
Cover plate, 2 threaded studs
• Vibration Isolation Mounts GN 351 / GN 451
Steel, zinc plated, molded-in
• GN 451.1
Stainless steel
European Standard No. 1.4301 (AISI 304),
molded-in
• Vibration Isolation Mounts GN 351.2 / GN 451.2
• Vibration Isolation Mounts GN 351.3 / GN 451.3
• RoHS compliant
On request
• Versions with shore hardness A ±5
-- Soft
40
-- Hard 70
* Not available from stock, requires a
minimum order quantity
• Specials, with certain minimum quantities
How to order (Steel)
1
2
3
4
GN 351.1-25-19-1/4X20-55
How to order (Stainless Steel)
1
2
3
4
GN 451.1-10-13-8X32-55
2
| 3.4 Installing, Lifting, Dampening with Leveling Feet, Lifting Gear and Rubber Elements
1
Outside diameter d1
2
Height h
3
Thread d 2
4
Hardness
1
Outside diameter d1
2
Height h
3
Thread d 2
4
Hardness
www.jwwinco.com | phone: 1-800-877-8351
GN 351.1 / GN 451.1 Vibration Isolation Mounts continued
Inch table
1
2
3
d1
h
d2
10
14
16
19
.39
.55
.63
.75
13
Dimensions in: inches - millimeters
Thread
.51
8 x 32
.51
10 x 32
.51
8 x 32
.75
1/4 x 20
.51
1/4 x 20
.75
1/4 x 20
13
13
19
Length l
13
.51
10
.39
13
.51
13
.51
Spring rate ≈
Hardness 55
Max. load
Hardness 55
.04
205 lbf/in
35.90 N/mm
20.00 lbf
88.96 N
.18
4.49
.04
90.97 lbf/in
15.93 N/mm
13.00 lbf
57.82 N
.28
7.01
.05
1.2
440 lbf/in
77.05 N/mm
44.00 lbf
195.72 N
.31
8.00
.08
296 lbf/in
51.83 N/mm
58.00 lbf
257.99 N
.37
9.49
.08
1043 lbf/in
182.65 N/mm
154 lbf
685.02 N
.49
12.49
.08
684 lbf/in
119.78 N/mm
183 lbf
814.02 N
.49
12.49
.08
1220 lbf/in
213.65 N/mm
183 lbf
814.02 N
.49
12.49
.08
670 lbf/in
117.33 N/mm
168 lbf
747.30 N
.49
12.49
.08
616 lbf/in
107.87 N/mm
151 lbf
671.68 N
.49
12.49
.08
1886 lbf/in
330.28 N/mm
283 lbf
1258.84 N
.63
16.00
.08
1425 lbf/in
249.55 N/mm
280 lbf
1245.50 N
.63
16.00
.08
1090 lbf/in
190.88 N/mm
273 lbf
1214.36 N
.63
16.00
.08
1344 lbf/in
235.37 N/mm
336 lbf
1494.60 N
.67
16.99
.08
2615 lbf/in
457.95 N/mm
523 lbf
2326.41 N
.75
18.99
.08
1200 lbf/in
210.15 N/mm
300 lbf
1334.46 N
.75
18.99
.08
2000 lbf/in
350.25 N/mm
500 lbf
2224.11 N
.79
19.98
.08
1710 lbf/in
299.46 N/mm
336 lbf
1494.60 N
.79
19.98
.08
4093 lbf/in
716.79 N/mm
804 lbf
3576.37 N
.98
24.99
.08
1955 lbf/in
342.37 N/mm
576 lbf
2562.17 N
.98
24.99
.08
2582 lbf/in
452.17 N/mm
762 lbf
3389.54 N
1.18
29.99
.12
13282 lbf/in
2325.85 N/mm
2607 lbf
11596.51 N
1.38
35.00
1
1
2
.98
25
13
.98
25
19
.98
25
19
.75
5/16 x 18
.98
25
.98
25
1/4 x 20
.98
25
.98
25
5/16 x 18
1.26
32
19
.75
1/4 x 20
1.26
32
19
.75
5/16 x 18
1.26
32
.98
25
5/16 x 18
1.38
35
.98
25
5/16 x 18
1.50
38
19
.75
5/16 x 18
1.50
38
.98
25
3/8 x 16
1.57
40
.98
25
3/8 x 16
1.57
40
.98
25
5/16 x 18
2.01
51
19
.75
3/8 x 16
2.01
51
1.61
41
3/8 x 16
2.44
62
1.26
32
1/2 x 13
.87
22
2
3.11
79
2.24
57
1/2 x 13
1.26
32
3
13
.51
s
16
.63
16
13
.63
.51
16
13
16
16
16
16
16
16
16
.63
.51
.63
.63
.63
.63
.63
.63
.63
1.14
29
16
.63
2
2
2
2
2
2
2
2
2
2
2
2
2
2
2
Max. deflection ≈
3.4 Installing, Lifting, Dampening with Leveling Feet, Lifting Gear and Rubber Elements |
3
很抱歉,暂时无法提供与“351.1-38-25-3/8-55”相匹配的价格&库存,您可以联系我们找货
