GN 351.2
GN 451.2
Vibration Isolation Mounts
Steel
Stainless Steel
Cylindrical Type
Inch
Inch table
Dimensions in: inches - millimeters
1
2
3
d1
h
d2
Length l
s
t
Spring rate ≈
Hardness 55
Max. load
Hardness 55
Max. deflection ≈
.63
16
.51
13
8 x 32
.51
13
.05
1.2
.16
4
490 lbf/in
85.81 N/mm
73.00 lbf
324.72 N
.31
8.00
.98
25
.51
13
1/4 x 20
.51
13
.08
2
.24
6
1160 lbf/in
203.14 N/mm
116 lbf
515.99 N
.49
12.49
.98
25
.75
19
1/4 x 20
.51
13
.08
2
.24
6
1445 lbf/in
253.05 N/mm
217 lbf
965.26 N
.49
12.49
.98
25
.98
25
1/4 x 20
.51
13
.08
2
.24
6
800 lbf/in
140.10 N/mm
200 lbf
889.64 N
.49
12.49
.98
25
.98
25
5/16 x 18
.63
16
.08
2
.31
8
800 lbf/in
140.10 N/mm
200 lbf
889.64 N
.49
12.49
1.38
35
.98
25
5/16 x 18
.63
16
.08
2
.31
8
2000 lbf/in
350.25 N/mm
500 lbf
2224.11 N
.67
16.99
2.01
51
1.61
41
3/8 x 16
.63
16
.08
2
.39
10
187 lbf/in
32.74 N/mm
748 lbf
3327.26 N
1.00
25.40
2.01
51
2.01
51
3/8 x 16
1.14
29
.08
2
.39
10
1364 lbf/in
238.87 N/mm
682 lbf
3033.68 N
1.00
25.40
3.11
79
2.24
57
1/2 x 13
1.26
32
.12
3
.47
12
3357 lbf/in
587.90 N/mm
1880 lbf
8362.65 N
1.38
35.00
Thread
Specification
4
Information
• Mount body
GN 351.2 and GN 451.2 vibration isolation mounts are suitable for the elastic mounting of machine units
Natural rubber (NR)
such as motors, compressors and pumps.
-- Black
These rubber mounts are simple and economical construction elements. Their resilience and their
-- Vulcanized to the cover plate
broad range of different sizes and dimensions allow these mounts to be used in many applications that
-- Shore hardness A ±5
require vibration isolation.
Medium
55
For metric versions see GN 351 or GN 451.
• GN 351.2
see also...
Cover plate, 1 tapped insert, 1 threaded stud
• Vibration Isolation Mounts GN 351 / GN 451
Steel, zinc plated, molded-in
• GN 451.2
Stainless steel
European Standard No. 1.4301 (AISI 304),
molded-in
• Vibration Isolation Mounts GN 351.1 / GN 451.1
• Vibration Isolation Mounts GN 351.3 / GN 451.3
• RoHS compliant
How to order (Steel)
On request
1
2
3
4
GN 351.2-16-13-8X32-55
• Versions with shore hardness A ±5
-- Soft*
40
How to order (Stainless Steel)
-- Hard* 70
* Not available from stock, requires a
1
2
3
minimum order quantity
• Specials, with certain minimum quantities
2
4
GN 451.2-35-25-5/16X18-55
| 3.4 Installing, Lifting, Dampening with Leveling Feet, Lifting Gear and Rubber Elements
1
Outside diameter d1
2
Height h
3
Thread d 2
4
Hardness
1
Outside diameter d1
2
Height h
3
Thread d 2
4
Hardness
www.jwwinco.com | phone: 1-800-877-8351
很抱歉,暂时无法提供与“351.2-51-41-3/8-55”相匹配的价格&库存,您可以联系我们找货
