GN 351
GN 451
Vibration Isolation Mounts
Steel
Stainless Steel
Cylindrical Type
Metric
4
Type
EE With 2 tapped holes
ES With tapped hole / threaded stud
SS With 2 threaded studs
Specification
5
Information
GN 351 and GN 451 vibration isolation mounts are suitable for the elastic mounting of machine units
• Mount body
Natural rubber (NR)
such as motors, compressors and pumps.
-- Black
These rubber mounts are simple and economical construction elements. Their resilience and their
-- Vulcanized to the cover plate
broad range of different sizes and dimensions allow these mounts to be used in many applications that
-- Temperature resistant up to 175 °F (80 °C)
require vibration isolation.
-- Shore hardness A ±5
see also...
Medium
55
• Vibration / Shock Absorption Mounts GN 353 / GN 453
• GN 351
• Vibration Isolation Mounts GN 351.1 / GN 451.1 (Inch Versions)
Cover plate, tapped inserts, threaded studs
Steel, zinc plated, blue passivated finish,
molded-in
• Vibration Isolation Mounts GN 351.2 / GN 451.2 (Inch Versions)
• Vibration Isolation Mounts GN 351.3 / GN 451.3 (Inch Versions)
• GN 451
Stainless steel
European Standard No. 1.4301 (AISI 304),
molded-in
• RoHS compliant
On request
• Versions with shore hardness A ±5
-- Soft
40
-- Hard
70
• Gray color rubber
• Specials, with certain minimum quantities
How to order (Steel)
1
2
3
4
5
GN 351-8-8-M3-EE-55
How to order (Stainless steel)
1
2
3
4
5
GN 451-10-10-M4-SS-55
2
| 3.4 Installing, lifting, dampening with leveling feet, lifting gear and rubber elements
1
Outside diameter d1
2
Height h
3
Thread d 2
4
Type
5
Hardness
1
Outside diameter d1
2
Height h
3
Thread d 2
4
Type
5
Hardness
www.jwwinco.com | phone: 1-800-877-8351
GN 451 / GN 351 Vibration Isolation Mounts continued
Metric table
1
2
d1
h
2
Type ES
Type EE
8
10
15
.31
.39
.59
.79
.98
8
.31
10
10
15
.39
.59
2
13
15
15
.59
.79
8
.79
.79
.98
.31
10
.39
10
15
.98
30
1.18
15
.79
30
1.18
40
1.57
15
40
1.57
25
.51
.39
3
Type SS
13
15
15
.59
.59
8
25
10
.98
.79
15
.59
30
1.18
40
1.57
15
.79
30
1.18
40
1.57
1.57
50
1.97
.98
s
6
M 4
10
25
M 4
10
30
1.18
M 6
18
.79
30
1.18
M 6
18
.59
30
1.18
40
1.57
M 8
30
1.18
40
1.57
M 8
23
40
1.57
50
1.97
M 10
28
1.10
2
.59
.59
15
15
.59
.59
.79
.79
.79
.98
.98
.24
1
t
Type EE / ES
M 3
.39
13
Length l
Type ES / SS
.39
30
1.18
.79
Thread
Dimensions in: millimeters - inches
.31
15
.59
30
1.18
.59
d2
.04
.39
1.2
.05
4
.39
1.4
.06
4
2
6
.71
.71
.08
2
.08
30
1.18
1.57
30
1.18
50
1.97
30
1.18
40
1.57
50
1.97
30
1.18
.79
30
1.18
60
2.36
30
1.18
40
1.57
50
1.97
30
1.18
40
1.57
50
1.97
30
1.18
40
1.57
50
1.97
M 10
28
1.10
2
70
2.76
30
1.18
45
1.77
30
1.18
45
1.77
30
1.18
45
1.77
M 10
27
1.06
3
75
2.95
30
1.18
40
1.57
55
2.17
25
.98
40
1.57
55
2.17
25
.98
40
1.57
55
2.17
M 12
37
1.46
3
100
3.94
40
1.57
55
2.17
75
2.95
40
1.57
55
2.17
75
2.95
40
1.57
55
2.17
75
2.95
M 16
41
1.61
3
125
4.92
55
2.17
75
2.95
55
2.17
75
2.95
55
2.17
75
2.95
M 16
41
1.61
3
3
.79
.91
2
.08
2
.08
.08
.08
.12
.12
.12
.12
6
8
8
10
10
10
12
16
16
.12
.16
.16
.24
.24
.31
.31
.39
.39
.39
.47
.63
.63
3.4 Installing, lifting, dampening with leveling feet, lifting gear and rubber elements |
3
很抱歉,暂时无法提供与“351-30-15-M8-ES-55”相匹配的价格&库存,您可以联系我们找货
