451-30-30-M8-SS-55
451-30-30-M8-SS-55
    JWWINCO
    RUBBER BUMPER CYLINDRICAL SS
451-30-30-M8-SS-55 数据手册
GN 351 GN 451 Vibration Isolation Mounts Steel Stainless Steel Cylindrical Type Metric 4 Type EE With 2 tapped holes ES With tapped hole / threaded stud SS With 2 threaded studs Specification 5 Information GN 351 and GN 451 vibration isolation mounts are suitable for the elastic mounting of machine units • Mount body Natural rubber (NR) such as motors, compressors and pumps. -- Black These rubber mounts are simple and economical construction elements. Their resilience and their -- Vulcanized to the cover plate broad range of different sizes and dimensions allow these mounts to be used in many applications that -- Temperature resistant up to 175 °F (80 °C) require vibration isolation. -- Shore hardness A ±5 see also... Medium 55 • Vibration / Shock Absorption Mounts GN 353 / GN 453 • GN 351 • Vibration Isolation Mounts GN 351.1 / GN 451.1 (Inch Versions) Cover plate, tapped inserts, threaded studs Steel, zinc plated, blue passivated finish, molded-in • Vibration Isolation Mounts GN 351.2 / GN 451.2 (Inch Versions) • Vibration Isolation Mounts GN 351.3 / GN 451.3 (Inch Versions) • GN 451 Cover plate, tapped inserts, threaded studs Stainless steel European Standard No. 1.4301 (AISI 304), molded-in • RoHS compliant On request • Versions with shore hardness A ±5 -- Soft 40 -- Hard 70 • Gray color rubber • Specials, with certain minimum quantities How to order (Steel) 1 2 3 4 5 GN 351-8-8-M3-EE-55 How to order (Stainless steel) 1 2 3 4 5 GN 451-10-10-M4-SS-55 2 | 3.4 Installing, lifting, dampening with leveling feet, lifting gear and rubber elements 1 Outside diameter d1 2 Height h 3 Thread d 2 4 Type 5 Hardness 1 Outside diameter d1 2 Height h 3 Thread d 2 4 Type 5 Hardness www.jwwinco.com | phone: 1-800-877-8351 GN 451 / GN 351 Vibration Isolation Mounts continued Metric table 1 2 d1 h 2 Type ES Type EE 8 10 15 20 25 .31 .39 .59 .79 .98 8 .31 10 10 15 20 .39 .39 .59 2 13 15 15 20 .59 .59 .79 20 20 25 8 .79 .79 .98 .31 10 .39 10 15 .98 30 1.18 15 .79 30 1.18 40 1.57 15 40 1.57 20 .79 25 .51 .39 3 Type SS 13 15 15 .59 .59 - - 8 20 - 10 25 10 20 .79 .98 .79 - 15 .59 30 1.18 40 1.57 - 15 .79 30 1.18 40 1.57 - 20 40 1.57 50 1.97 20 .79 .98 s 6 20 - M 4 10 25 M 4 10 30 1.18 M 6 18 .79 30 1.18 - M 6 18 .59 30 1.18 40 1.57 - M 8 20 .79 30 1.18 40 1.57 - M 8 23 40 1.57 50 1.97 M 10 28 1.10 2 .59 .59 15 15 20 20 .51 .59 .59 .79 20 25 .79 .79 .98 .98 .24 1 t Type EE / ES M 3 .39 13 Length l Type ES / SS - .39 30 1.18 20 25 .79 Thread Dimensions in: millimeters - inches - .31 15 .59 20 .51 30 1.18 .59 d2 .04 .39 1.2 .05 4 .39 1.4 .06 4 2 6 .71 .71 .08 2 .08 30 1.18 20 40 1.57 20 .79 30 1.18 50 1.97 30 1.18 40 1.57 50 1.97 20 .79 30 1.18 .79 30 1.18 60 2.36 30 1.18 40 1.57 50 1.97 30 1.18 40 1.57 50 1.97 - 30 1.18 40 1.57 50 1.97 - M 10 28 1.10 2 70 2.76 30 1.18 45 1.77 - 30 1.18 45 1.77 - - 30 1.18 45 1.77 - - M 10 27 1.06 3 75 2.95 30 1.18 40 1.57 55 2.17 25 .98 40 1.57 55 2.17 - 25 .98 40 1.57 55 2.17 - M 12 37 1.46 3 100 3.94 40 1.57 55 2.17 75 2.95 40 1.57 55 2.17 75 2.95 - 40 1.57 55 2.17 75 2.95 - M 16 41 1.61 3 125 4.92 55 2.17 75 2.95 - 55 2.17 75 2.95 - - 55 2.17 75 2.95 - - M 16 41 1.61 3 www.jwwinco.com | phone: 1-800-877-8351 3 .79 .91 2 .08 2 .08 .08 .08 .12 .12 .12 .12 6 8 8 10 10 10 12 16 16 .12 .16 .16 .24 .24 .31 .31 .39 .39 .39 .47 .63 .63 3.4 Installing, lifting, dampening with leveling feet, lifting gear and rubber elements | 3
451-30-30-M8-SS-55
物料型号: - GN 351:钢制 - GN 451:不锈钢制
器件简介: 这些橡胶座用于弹性安装机器单元,如电机、压缩机和泵。它们是简单且经济的构造元素,具有弹性和广泛的尺寸范围,适用于需要振动隔离的多种应用。
引脚分配: - Type EE:带2个螺纹孔 - Type ES:带1个螺纹孔/螺纹螺柱 - Type SS:带2个螺纹螺柱
参数特性: - 材质:天然橡胶(NR),耐温高达175°F(80°C) - 硬度:Shore A ±5,中等硬度55 - 特殊版本:软40、硬70 - 灰色橡胶 - 特殊订单:特定最小数量
功能详解: - 用于减少振动和冲击 - 提供不同硬度和颜色的橡胶版本
应用信息: - 适用于多种需要振动隔离的应用
封装信息: - 钢制和不锈钢制的盖板、螺纹嵌件、螺纹螺柱 - 钢制:镀锌蓝白钝化处理 - 不锈钢:欧洲标准1.4301(AISI 304)
订购信息: - 根据外径、高度、螺纹和类型进行订购
安装、提升、减震方法: - 使用调节脚、起重装置和橡胶元件进行安装、提升和减震
451-30-30-M8-SS-55 价格&库存
很抱歉,暂时无法提供与“451-30-30-M8-SS-55”相匹配的价格&库存,您可以联系我们找货
