GN 352.1
GN 452.1
Vibration / Shock Absorption Mounts
Steel
Stainless Steel
Cylindrical Type
Inch
Inch table
Dimensions in: inches - millimeters
1
2
3
d1
h
d2
Length l
s
Spring rate ≈
Hardness 55
Max. load
Hardness 55
Max. deflection ≈
.98
25
.51
13
1/4 x 20
.51
13
.08
2
2140 lbf/in
374.77 N/mm
214 lbf
951.91 N
.10
2.54
.98
25
.75
19
1/4 x 20
.51
13
.08
2
993 lbf/in
173.90 N/mm
140 lbf
622.75 N
.15
3.81
.98
25
.98
25
5/16 x 18
.63
16
.08
2
604 lbf/in
105.77 N/mm
151 lbf
671.68 N
.25
6.35
1.50
38
.75
19
5/16 x 18
.63
16
.08
2
2653 lbf/in
464.61 N/mm
398 lbf
1770.39 N
.15
3.81
1.57
40
.98
25
3/8 x 16
.63
16
.08
2
1736 lbf/in
304.02 N/mm
434 lbf
1930.52 N
.25
6.35
1.57
40
.98
25
5/16 x 18
.63
16
.08
2
1736 lbf/in
304.02 N/mm
434 lbf
1930.52 N
.25
6.35
2.01
51
.75
19
3/8 x 16
1.14
29
.08
2
5533 lbf/in
968.97 N/mm
830 lbf
3692.02 N
.15
3.81
2.01
51
1.61
41
3/8 x 16
.63
16
.08
2
1600 lbf/in
280.20 N/mm
640 lbf
2846.86 N
.40
10.16
Thread
Specification
4
Information
• Mount body
GN 352.1 and GN 452.1 vibration / shock absorption mounts are used as end-stop bumpers, e.g. for
Natural rubber (NR)
conveyors.
-- Black
They absorb most of the accumulated kinetic energy on impact. They act as dampers and prevent
-- Vulcanized to the cover plate
damaging shock and rebound. They also act as sound dampers. These mounts are also used as set-up
-- Shore hardness A ±5
elements and leveling feet.
Medium
55
For metric versions see GN 352 or GN 452.
• GN 352.1
see also...
Cover plate, threaded stud
• Vibration / Shock Absorption Mounts GN 352 / GN 452
Steel, zinc plated, molded-in
• GN 452.1
Stainless steel
European Standard No. 1.4301 (AISI 304),
molded-in
• Vibration / Shock Absorption Mounts GN 352.2 / GN 452.2
• RoHS compliant
How to order (Steel)
On request
1
2
3
4
GN 352.1-25-13-1/4X20-55
• Versions with shore hardness A ±5
-- Soft*
40
How to order (Stainless Steel)
-- Hard* 70
* Not available from stock, requires a
1
2
3
4
minimum order quantity
• Specials, with certain minimum quantities
2
GN 452.1-40-25-3/8X16-55
| 3.4 Installing, Lifting, Dampening with Leveling Feet, Lifting Gear and Rubber Elements
1
Outside diameter d1
2
Height h
3
Thread d 2
4
Hardness
1
Outside diameter d1
2
Height h
3
Thread d 2
4
Hardness
www.jwwinco.com | phone: 1-800-877-8351
352.1-38-19-5/16-55 价格&库存
很抱歉,暂时无法提供与“352.1-38-19-5/16-55”相匹配的价格&库存,您可以联系我们找货
