GN 352.2
GN 452.2
Vibration / Shock Absorption Mounts
Steel
Stainless Steel
Cylindrical Type
Inch
Inch table
Dimensions in: inches - millimeters
1
2
3
d1
h
d2
s
t
Spring rate ≈
Hardness 55
Max. load
Hardness 55
Max. deflection ≈
.98
25
.51
13
1/4 x 20
.08
2
.24
6
2050 lbf/in
359.01 N/mm
205 lbf
911.88 N
.10
2.54
.98
25
.75
19
1/4 x 20
.08
2
.24
6
946 lbf/in
165.66 N/mm
142 lbf
631.64 N
.15
3.81
.98
25
.98
25
5/16 x 18
.08
2
.31
8
760 lbf/in
133.09 N/mm
190 lbf
845.16 N
.25
6.35
1.50
38
.75
19
5/16 x 18
.08
2
.31
8
2940 lbf/in
514.87 N/mm
441 lbf
1961.66 N
.15
3.81
1.50
38
.98
25
5/16 x 18
.08
2
.31
8
1600 lbf/in
280.20 N/mm
400 lbf
1779.28 N
.25
6.35
1.50
38
.98
25
3/8 x 16
.08
2
.39
10
1600 lbf/in
280.20 N/mm
400 lbf
1779.28 N
.25
6.35
2.01
51
.75
19
3/8 x 16
.08
2
.39
10
6966 lbf/in
1219.93 N/mm
1045 lbf
4648.39 N
.15
3.81
2.01
51
1.61
41
3/8 x 16
.08
2
.39
10
1675 lbf/in
293.33 N/mm
670 lbf
2980.30 N
.40
10.16
Thread
Specification
4
Information
• Mount body
GN 352.2 and GN 452.2 vibration / shock absorption mounts are used as end-stop bumpers, e.g. for
Natural rubber (NR)
conveyors.
-- Black
They absorb most of the accumulated kinetic energy on impact. They act as dampers and prevent
-- Vulcanized to the cover plate
damaging shock and rebound. They also act as sound dampers. These mounts are also used as set-up
-- Shore hardness A ±5
elements and leveling feet.
Medium
55
For metric versions see GN 352 or GN 452.
• GN 352.2
see also...
Cover plate, tapped insert
• Vibration / Shock Absorption Mounts GN 352 / GN 452
Steel, zinc plated, molded-in
• GN 452.2
Stainless steel
European Standard No. 1.4301 (AISI 304),
molded-in
• Vibration / Shock Absorption Mounts GN 352.1 / GN 452.1
• RoHS compliant
How to order (Steel)
On request
1
2
3
4
GN 352.2-25-13-1/4X20-55
• Versions with shore hardness A ±5
-- Soft*
40
How to order (Stainless Steel)
-- Hard* 70
* Not available from stock, requires a
1
2
3
4
minimum order quantity
• Specials, with certain minimum quantities
2
GN 452.2-38-19-5/16X18-55
| 3.4 Installing, Lifting, Dampening with Leveling Feet, Lifting Gear and Rubber Elements
1
Outside diameter d1
2
Height h
3
Thread d 2
4
Hardness
1
Outside diameter d1
2
Height h
3
Thread d 2
4
Hardness
www.jwwinco.com | phone: 1-800-877-8351
很抱歉,暂时无法提供与“352.2-38-25-3/8-55”相匹配的价格&库存,您可以联系我们找货
