GN 352
GN 452
Vibration / Shock Absorption Mounts
Steel
Stainless Steel
Cylindrical Type
Metric
4 Type
E with tapped hole
S with threaded stud
Specification
5
Information
• Mount body
GN 352 and GN 452 vibration / shock absorption mounts are used as end-stop bumpers, e.g. for
Natural rubber (NR)
conveyors.
-- Black
They absorb most of the accumulated kinetic energy on impact. They act as dampers and prevent
-- Vulcanized to the cover plate
damaging shock and rebound. They also act as sound dampers. These mounts are also used as set-up
-- Temperature resistant up to 175 °F (80 °C)
elements and leveling feet.
-- Shore hardness A ±5
For inch versions see GN 352.1, GN 352.2, GN 452.1 or GN 452.2.
Medium
55
see also...
• GN 352
• Vibration / Shock Absorption Mounts GN 351 / GN 451 (cylindrical type)
Cover plate, tapped insert, threaded stud
Steel, zinc plated, blue passivated finish,
• Vibration / Shock Absorption Mounts GN 353 / GN 453 (conical type)
molded-in
• GN 452
Stainless steel
European Standard No. 1.4301 (AISI 304),
molded-in
• RoHS compliant
On request
• Versions with shore hardness A ±5
-- Soft*
40
-- Hard* 70
* Not available from stock, requires a
minimum order quantity
• Gray color rubber
• Specials, with certain minimum quantities
How to order (Steel)
1
2
3
4
5
GN 352-20-10-M6-S-55
How to order (Stainless Steel)
1
2
3
4
5
GN 452-8-8-M3-E-55
2
| 3.4 Installing, lifting, dampening with leveling feet, lifting gear and rubber elements
1
Outside diameter d1
2
Height h
3
Thread d 2
4
Type
5
Hardness
1
Outside diameter d1
2
Height h
3
Thread d 2
4
Type
5
Hardness
www.jwwinco.com | phone: 1-800-877-8351
GN 452 / GN 352 Vibration / Shock Absorption Mounts continued
Metric table
1
2
d1
h
2
Type E
8
10
15
.31
.39
.59
.79
.98
8
8
10
10
25
10
.79
30
1.18
15
.79
30
1.18
40
1.57
15
.79
30
1.18
40
1.57
1.57
50
1.97
15
15
15
Type S
.31
10
3
.59
.59
.59
d2
13
15
.79
.79
.98
s
M 3
6
M 4
10
.79
30
1.18
M 4
10
.79
30
1.18
M 6
18
30
1.18
M 6
18
25
.98
30
1.18
M 8
30
1.18
40
1.57
M 8
23
.79
30
1.18
40
1.57
50
1.97
M 10
28
1.10
2
60
2.36
M 10
28
1.10
2
.39
.39
.39
.59
15
15
15
.59
.59
.79
.24
.04
.39
4
.39
1.4
.06
4
2
6
.71
.71
.08
2
.08
40
1.57
1.97
30
1.18
60
2.36
30
1.18
40
1.57
50
1.97
40
1.57
70
2.76
30
1.18
40
1.57
55
2.17
30
1.18
40
1.57
55
2.17
M 10
27
1.06
3
75
2.95
30
1.18
40
1.57
50
1.97
25
.98
40
1.57
50
1.97
M 12
37
1.46
3
100
3.94
40
1.57
50
1.97
60
2.36
40
1.57
50
1.97
60
2.36
M 16
41
1.61
3
125
4.92
55
2.17
75
2.95
55
2.17
75
2.95
M 16
41
1.61
3
.79
25
.79
3
1.2
.05
15
.59
1
t
Type E
.31
13
Length l
Type S
30
1.18
.59
Thread
Dimensions in: millimeters - inches
.79
.91
2
.08
2
.08
.08
.08
.12
.12
.12
.12
6
8
8
10
10
10
12
16
16
.12
.16
.16
.24
.24
.31
.31
.39
.39
.39
.47
.63
.63
3.4 Installing, lifting, dampening with leveling feet, lifting gear and rubber elements |
3
很抱歉,暂时无法提供与“452-30-20-M8-E-55”相匹配的价格&库存,您可以联系我们找货
