352-75-40-M12-E-55
352-75-40-M12-E-55
    JWWINCO
    RUBBER BUMPER CYLINDRICAL, STEEL
352-75-40-M12-E-55 数据手册
GN 352 GN 452 Vibration / Shock Absorption Mounts Steel Stainless Steel Cylindrical Type Metric 4 Type E with tapped hole S with threaded stud Specification 5 Information • Mount body GN 352 and GN 452 vibration / shock absorption mounts are used as end-stop bumpers, e.g. for Natural rubber (NR) conveyors. -- Black They absorb most of the accumulated kinetic energy on impact. They act as dampers and prevent -- Vulcanized to the cover plate damaging shock and rebound. They also act as sound dampers. These mounts are also used as set-up -- Temperature resistant up to 175 °F (80 °C) elements and leveling feet. -- Shore hardness A ±5 For inch versions see GN 352.1, GN 352.2, GN 452.1 or GN 452.2. Medium 55 see also... • GN 352 • Vibration / Shock Absorption Mounts GN 351 / GN 451 (cylindrical type) Cover plate, tapped insert, threaded stud Steel, zinc plated, blue passivated finish, • Vibration / Shock Absorption Mounts GN 353 / GN 453 (conical type) molded-in • GN 452 Cover plate, tapped insert, threaded stud Stainless steel European Standard No. 1.4301 (AISI 304), molded-in • RoHS compliant On request • Versions with shore hardness A ±5 -- Soft* 40 -- Hard* 70 * Not available from stock, requires a minimum order quantity • Gray color rubber • Specials, with certain minimum quantities How to order (Steel) 1 2 3 4 5 GN 352-20-10-M6-S-55 How to order (Stainless Steel) 1 2 3 4 5 GN 452-8-8-M3-E-55 2 | 3.4 Installing, lifting, dampening with leveling feet, lifting gear and rubber elements 1 Outside diameter d1 2 Height h 3 Thread d 2 4 Type 5 Hardness 1 Outside diameter d1 2 Height h 3 Thread d 2 4 Type 5 Hardness www.jwwinco.com | phone: 1-800-877-8351 GN 452 / GN 352 Vibration / Shock Absorption Mounts continued Metric table 1 2 d1 h 2 Type E 8 10 15 20 25 .31 .39 .59 .79 .98 8 - 8 - - 10 - - 10 25 - 10 .79 30 1.18 - 15 .79 30 1.18 40 1.57 15 .79 30 1.18 40 1.57 - 20 40 1.57 50 1.97 20 .39 15 15 15 Type S - .31 10 3 .59 .59 .59 d2 13 15 20 20 20 .59 .79 .79 .98 s - M 3 6 20 - M 4 10 .79 30 1.18 M 4 10 .79 30 1.18 M 6 18 30 1.18 - M 6 18 25 .98 30 1.18 M 8 20 .98 30 1.18 40 1.57 M 8 23 .79 30 1.18 40 1.57 50 1.97 M 10 28 1.10 2 60 2.36 - M 10 28 1.10 2 .39 .39 .39 .59 15 15 15 20 .59 .59 .59 .79 20 20 .79 .24 .04 .39 4 .39 1.4 .06 4 2 6 .71 .71 .08 2 .08 40 1.57 20 50 1.97 20 .79 30 1.18 60 2.36 30 1.18 40 1.57 50 1.97 - 20 .79 40 1.57 70 2.76 30 1.18 40 1.57 55 2.17 - 30 1.18 40 1.57 55 2.17 - M 10 27 1.06 3 75 2.95 30 1.18 40 1.57 50 1.97 - 25 .98 40 1.57 50 1.97 - M 12 37 1.46 3 100 3.94 40 1.57 50 1.97 60 2.36 - 40 1.57 50 1.97 60 2.36 - M 16 41 1.61 3 125 4.92 55 2.17 75 2.95 - - 55 2.17 75 2.95 - - M 16 41 1.61 3 www.jwwinco.com | phone: 1-800-877-8351 .79 25 .79 3 1.2 .05 15 .59 20 .51 1 t Type E - .31 13 Length l Type S 30 1.18 .59 20 .51 Thread Dimensions in: millimeters - inches .79 .91 2 .08 2 .08 .08 .08 .12 .12 .12 .12 6 8 8 10 10 10 12 16 16 .12 .16 .16 .24 .24 .31 .31 .39 .39 .39 .47 .63 .63 3.4 Installing, lifting, dampening with leveling feet, lifting gear and rubber elements | 3
352-75-40-M12-E-55
物料型号: - GN 352 Steel - GN 452 Stainless Steel
器件简介: 这些支座用于作为端部限位缓冲器,例如用于输送带。它们在冲击时吸收大部分积累的动能,作为减震器防止破坏性冲击和反弹,同时也作为声音减震器。这些支座也用作设置元件和调节脚。
引脚分配/参数特性: - 支座主体:天然橡胶(NR),黑色,硫化至盖板,耐温高达175°F(80°C),邵氏硬度A ±5,中等55。 - 盖板、螺纹嵌件、螺纹螺柱:GN 352为钢制,镀锌,蓝色钝化表面,注塑成型;GN 452为不锈钢制,欧洲标准1.4301(AISI 304),注塑成型。 - 符合RoHS标准。
功能详解: - 这些支座可以作为减震器和缓冲器,防止冲击和声音传播。
应用信息: - 用于输送带等设备的端部限位缓冲器。
封装信息: - 提供了详细的尺寸表,包括外径、高度、螺纹类型等。
352-75-40-M12-E-55 价格&库存
很抱歉,暂时无法提供与“352-75-40-M12-E-55”相匹配的价格&库存,您可以联系我们找货
