GN 353.2
GN 453.2
Vibration / Shock Absorption Mounts
Steel
Stainless Steel
Conical Type
Inch
Inch table
Dimensions in: inches - millimeters
1
2
3
d1
h
d2
s
.75
19
.98
25
1/4 x 20
.98
25
1.26
32
1.26
32
t
Spring rate ≈
Hardness 55
Max. load
Hardness 55
Max. deflection ≈
.08
2
.24
6
90.97 lbf/in
15.93 N/mm
22.00 lbf
97.86 N
.24
6.09
1/4 x 20
.08
2
.24
6
132 lbf/in
23.11 N/mm
33.00 lbf
146.79 N
.25
6.35
1.50
38
5/16 x 18
.08
2
.31
8
155 lbf/in
27.14 N/mm
45.00 lbf
200.16 N
.29
7.36
1.50
38
1.77
45
5/16 x 18
.08
2
.31
8
374 lbf/in
65.49 N/mm
146 lbf
649.44 N
.39
9.90
1.77
45
2.01
51
3/8 x 16
.08
2
.39
10
284 lbf/in
49.73 N/mm
168 lbf
747.30 N
.59
14.98
2.01
51
2.24
57
3/8 x 16
.08
2
.39
10
285 lbf/in
49.91 N/mm
191 lbf
849.61 N
.67
17.01
Thread
Specification
4
Information
• Mount body
GN 353.2 and GN 453.2 vibration / shock absorption mounts are frequently used as end-stop bumpers,
Natural rubber (NR)
e.g. for conveyors.
-- Black
They absorb most of the accumulated kinetic energy on impact. They act as dampers and prevent
-- Vulcanized to the cover plate
damaging shock and rebound. They also act as sound dampers. These mounts are also used as set-up
-- Shore hardness A ±5
elements and leveling feet.
Medium
55
The parabolic shape of these isolation mounts generates progressive resilience characteristics: Impact
• GN 353.2
and shock effects are absorbed more gently.
Cover plate, tapped insert
For metric versions see GN 353 or GN 453.
Steel, zinc plated, molded-in
• GN 453.2
Stainless steel
European Standard No. 1.4301 (AISI 304),
molded-in
see also...
• Vibration / Shock Absorption Mounts GN 353 / GN 453
• Vibration / Shock Absorption Mounts GN 353.1 / GN 453.1
• RoHS compliant
How to order (Steel)
On request
1
2
3
4
GN 353.2-19-25-1/4X20-55
• Versions with shore hardness A ±5
-- Soft*
40
How to order (Stainless Steel)
-- Hard* 70
* Not available from stock, requires a
1
2
3
4
minimum order quantity
• Specials, with certain minimum quantities
2
GN 453.2-32-38-5/16X18-55
| 3.4 Installing, Lifting, Dampening with Leveling Feet, Lifting Gear and Rubber Elements
1
Outside diameter d1
2
Height h
3
Thread d 2
4
Hardness
1
Outside diameter d1
2
Height h
3
Thread d 2
4
Hardness
www.jwwinco.com | phone: 1-800-877-8351
453.2-38-45-5/16-55 价格&库存
很抱歉,暂时无法提供与“453.2-38-45-5/16-55”相匹配的价格&库存,您可以联系我们找货
