41-40-1/2X13-100-D1-SK
    JWWINCO
    STAINLESS STEEL LEVELING FEET
41-40-1/2X13-100-D1-SK 数据手册
Leveling Feet GN 41 Stainless Steel AISI 304, Tapped Socket or Threaded Stud Type Inch | Metric 4 Type (Base) D0 Without rubber pad / cap B0 Without rubber pad / cap, with 2 mounting holes D1 With rubber cap, clipped on, black D3 With rubber pad, vulcanized, black Inch table (only available in version S, SK, U, UK, X) 1 2 3 d1 d2 l1 Thread  1.57 40  1.57 40  1.57 40 l7 Version S / SK Version U / UK - - - - - - - -   3/8 x 16   3.94 100   3.94 100 -   4.92 125   4.92 125 -   5.91 150   5.91 150 - - - - - - - - -   5/8 x 11  2.95 75  2.95 75 -   2.95  75   3.94 100   4.92 125   5.91 150 5/16 x 18 - - - - - - - -   3/8 x 16   3.94 100   3.94 100 -   4.92 125   4.92 125 -   5.91 150   5.91 150 - - - - - - - - -   5/8 x 11  2.95 75  2.95 75 - 5/16 x 18 - - - -   2.95  75 -   3.94 100 -   4.92 125 -   5.91 150 -   3/8 x 16   3.94 100   3.94 100 -   4.92 125   4.92 125 -   5.91 150   5.91 150 - - - - - - - - -   5/8 x 11  2.95 75  2.95 75 - 5/16 x 18 - - - -   2.95  75 -   3.94 100 -   4.92 125 -   5.91 150 -   3/8 x 16   3.94 100   3.94 100 -   4.92 125   4.92 125 -   5.91 150   5.91 150 - - - - - - - - -   5/8 x 11  2.95 75  2.95 75 -   3/4 x 10 - - - -   2.95  75   3.94 100   3.94 100   4.92 125   4.92 125   5.91 150   5.91 150 -   1/2 x 13   1/2 x 13   1/2 x 13 d3 m h1 h6 s  0.98 25  1.10 28  1.22 31  1.46 37 0.21 5.4 0.21 5.4 0.21 5.4 0.21 5.4  1.18 30  1.18 30  1.18 30  1.18 30 0.08 2 0.08 2 0.08 2 0.08 2 0.14 3.5 0.14 3.5 0.14 3.5 0.14 3.5 0.06 1.5 0.06 1.5 0.06 1.5 0.06 1.5  0.98 25  1.10 28  1.26 32  1.46 37  0.98 25  1.10 28  1.26 32  1.46 37  1.02 26  1.14 29  1.26 32  1.50 38  1.77 45 0.26 6.6 0.26 6.6 0.26 6.6 0.26 6.6 0.26 6.6 0.26 6.6 0.26 6.6 0.26 6.6 0.33 8.5 0.33 8.5 0.33 8.5 0.33 8.5 0.33 8.5  1.50 38  1.50 38  1.50 38  1.50 38  1.89 48  1.89 48  1.89 48  1.89 48  2.52 64  2.52 64  2.52 64  2.52 64  2.52 64 0.10 2.5 0.10 2.5 0.10 2.5 0.10 2.5 0.10 2.5 0.10 2.5 0.10 2.5 0.10 2.5 0.12 3 0.12 3 0.12 3 0.12 3 0.12 3 0.16 4 0.16 4 0.16 4 0.16 4 0.18 4.5 0.18 4.5 0.18 4.5 0.18 4.5 0.20 5 0.20 5 0.20 5 0.20 5 0.20 5 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 Version X 5/16 x 18   1/2 x 13  1.57 * 40  1.97 50  1.97 50  1.97 50  1.97 50  2.36 60  2.36 60  2.36 60  2.36 60  3.15 80  3.15 80  3.15 80  3.15 80  3.15 80 Dimensions in: inches - millimeters 3 * Not available in type B0 2 | 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements www.jwwinco.com | phone: 1-800-877-8351 GN 41 Leveling Feet continued (2/4) d1 d2 h3 h4 h5 A/F1 A/F 2 A/F 3 A/F 7 t 1.57 40 1.57 40 1.57 40 1.57 40 1.97 50 1.97 50 1.97 50 1.97 50 2.36 60 2.36 60 2.36 60 2.36 60 3.15 80 3.15 80 3.15 80 3.15 80 3.15 80 5/16 x 18 - - - - - - 0.43 11 0.43 11 - - - - - - - - - 0.67 17 - 0.55 14 - 0.67 17 0.67 17 - - - - - 0.67 17 - 0.55 14 - - - - - 0.67 17 - 0.55 14 - - - - - 0.71 18 0.75 19 0.59 15 0.59 15 0.55 14 0.55 14 0.67 17 0.87 22 0.55 14 0.55 14 0.67 17 0.87 22 0.55 14 0.55 14 0.67 17 0.87 22 0.55 14 0.55 14 0.67 17 0.87 22 1.06 27 0.31 8 0.39 10 0.47 12 0.63 16 0.31 8 0.39 10 0.47 12 0.63 16 0.31 8 0.39 10 0.47 12 0.63 16 0.31 8 0.39 10 0.47 12 0.63 16 0.79 20 Thread 3/8 x 16 1/2 x 13 5/8 x 11 5/16 x 18 - 3/8 x 16 0.43 11 0.43 11 - 1/2 x 13 5/8 x 11 5/16 x 18 - 3/8 x 16 0.43 11 0.43 11 - 1/2 x 13 5/8 x 11 5/16 x 18 - 3/8 x 16 5/8 x 11 0.47 12 0.47 12 - 3/4 x 10 - 1/2 x 13 0.67 17 0.67 17 0.67 17 0.67 17 0.67 17 0.67 17 - 0.47 12 - 0.31 8 - - - - - 0.47 12 - 0.31 8 - - - - - 0.47 12 - 0.31 8 - - - - - 0.47 12 0.59 15 0.31 8 0.39 10 Stud / socket versions 5 5 5 SK Without nut T **K Without nut UK Wihtout nut SK With nut TK ** With nut UK With nut External hexagon at the bottom at d2 3/8 x 16, 1/2 x 13 M 8, M 10, M 12 5 V **K Wihtout nut VK ** With nut External hexagon at the top, wrench flat at the bottom at d2 M 16, M 20, M 24 Wrench flat at the bottom at d2 M 16, M 20, M 24 Internal hexagon at the top, wrench flat at the bottom at d 2 5/8 x 11, 3/4 x 10 M 16, M 20, M 24 5 W ** With adjustable sleeve Covered thread, wrench flat at the bottom at d2 M 16, M 20, M 24 5 X Tapped socket type External hexagon with tapped socket at d2 5/16 x 18, 3/8 x 16, 1/2 x 13, 5/8 x 11, 3/4 x 10 M 8, M 10, M 12, M 16, M 20 ** Only available with Metric thread www.jwwinco.com | phone: 1-800-877-8351 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements | 3 GN 41 Leveling Feet continued (3/4) Metric table Dimensions in: millimeters - inches 1 2 3 3 3 3 d1 d2 l1 l2 l3 l7 Thread Version S / SK 40 M   8 40 50  1.57  1.57  1.97 40 M 10 50 60  1.57  1.97  2.36 40 M 12 60 80  1.57  2.36  3.15 M 16 40*  1.57 50 M   8 40 50  1.97  1.57  1.97 50 M 10 50 60  1.97  1.97  2.36 50 M 12 60 80  1.97  2.36  3.15 50 M 16  1.97 60 M   8 40 50  2.36  1.57  1.97 60 M 10 50 60  2.36  1.97  2.36 60 M 12 60 80  2.36  2.36  3.15 60 M 16  2.36 80 M   8 40 50  3.15  1.57  1.97 80 M 10 50 60  3.15  1.97  2.36 80 M 12 60 80  3.15  2.36  3.15 80 M 16  3.15 80 M 20  3.15 80 M 24  3.15 Version V / VK Version T / TK and U / UK  63   2.48  80   3.15 100   3.94 - - 100   3.94 125   4.92  75   2.95  63   2.48  80   3.15 100   3.94 - -  63   2.48  80   3.15 100   3.94  63   2.48  80   3.15 100   3.94 - - Version W Version X - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 100 125 150 200   3.94   4.92   5.91   7.87 - - - - - - - - - - - - - - - - - - - 100   3.94 125   4.92  75   2.95 - - - - - - - - - - - - - - - - - - - 100 125 150 200   3.94   4.92   5.91   7.87 - - - - - - - - - 100   3.94 125   4.92  75   2.95 - - - - - - - - - - - - - - - - - - - - 100   3.94 125   4.92  75   2.95  75   2.95 100   3.94 100 125 150 200  75 100 125 150 110   3.94   4.92   5.91   7.87   2.95   3.94   4.92   5.91   4.33 - - - - - - - - - - - - - - - - - - 100   3.94 100   3.94 125   4.92 125   4.92 125   4.92 150   5.91 150   5.91 150   5.91 200   7.87 200   7.87 200   7.87 -  75   2.95 100   3.94 100   3.94 100   3.94 125   4.92 150   5.91 125   4.92 150   5.91 200   7.87 150   5.91 200   7.87 - 110   4.33 134   5.28 159   6.26 25  0.98 28  1.10 31  1.22 37  1.46 25  0.98 28  1.10 32  1.26 37  1.46 25  0.98 28  1.10 32  1.26 135 160 185 37   5.31   6.30   7.28  1.46 26  1.02 29  1.14 32  1.26 135 160 185 38   5.31   6.30   7.28  1.50 159 184 234 45   6.26   7.24   9.21  1.77 209 259   8.23  10.20 * Not available in type B0 4 | 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements www.jwwinco.com | phone: 1-800-877-8351 GN 41 Leveling Feet continued (4/4) d1 d2 40 1.57 40 1.57 40 1.57 40 1.57 50 1.97 50 1.97 50 1.97 50 1.97 60 2.36 60 2.36 60 2.36 60 2.36 80 3.15 80 3.15 80 3.15 80 3.15 80 3.15 80 3.15 M 8 5.4 0.21 M 10 5.4 0.21 M 12 5.4 0.21 M 16 5.4 0.21 M 8 6.6 0.26 M 10 6.6 0.26 M 12 6.6 0.26 M 16 6.6 0.26 M 8 6.6 0.26 M 10 6.6 0.26 M 12 6.6 0.26 M 16 6.6 0.26 M 8 8.5 0.33 M 10 8.5 0.33 M 12 8.5 0.33 M 16 8.5 0.33 M 20 8.5 0.33 M 24 8.5 0.33 Thread d3 d5 h1 h3 h4 h5 h6 l4 l5 l6 A/F1 A/F 2 A/F 3 A/F 4 A/F5 A/F 6 - 2 0.08 2 0.08 2 0.08 2 0.08 2.5 0.10 2.5 0.10 2.5 0.10 2.5 0.10 2.5 0.10 2.5 0.10 2.5 0.10 2.5 0.10 3 0.12 3 0.12 3 0.12 3 0.12 3 0.12 3 0.12 11 0.43 11 0.43 11 0.43 - - - - - - - - - - - - - - - - - - - - - - - - - - - - 17 0.67 17 0.67 17 0.67 - - - 3.5 0.14 3.5 0.14 3.5 0.14 3.5 0.14 4 0.16 4 0.16 4 0.16 4 0.16 4.5 0.18 4.5 0.18 4.5 0.18 4.5 0.18 5 0.20 5 0.20 5 0.20 5 0.20 5 0.20 5 0.20 - - - - - - - - - - - - - - - - - - - - - 24 0.94 24 0.94 30 1.18 35 1.38 17 14 0.67 0.55 - 11 0.43 11 0.43 11 0.43 17 0.67 11 0.43 11 0.43 11 0.43 17 0.67 12 0.47 12 0.47 12 0.47 18 0.71 19 0.75 22 0.87 14 0.55 14 0.55 15 0.59 15 0.59 18 0.71 45 45 29 1.77 1.77 1.14 - - - - - - 45 45 29 1.77 1.77 1.14 56 56 37 2.20 2.20 1.46 67 67 42 2.64 2.64 1.65 12 8 0.47 0.31 - 17 0.67 17 0.67 17 0.67 12 0.47 17 0.67 17 0.67 17 0.67 12 0.47 17 0.67 17 0.67 17 0.67 12 0.47 15 0.59 19 0.75 - - - - 8 0.31 - - - - 8 10 0.31 0.39 - - - - 8 10 0.31 0.39 10 13 0.39 0.51 12 17 0.47 0.67 A/F 7 14 0.55 14 0.55 17 0.67 22 0.87 14 0.55 14 0.55 17 0.67 22 0.87 14 0.55 14 0.55 17 0.67 12 20 22 0.47 0.79 0.87 14 0.55 14 0.55 17 0.67 12 20 22 0.47 0.79 0.87 16 24 27 0.63 0.94 1.06 20 30 0.79 1.18 m s t 30 1.18 30 1.18 30 1.18 30 1.18 38 1.50 38 1.50 38 1.50 38 1.50 48 1.89 48 1.89 48 1.89 48 1.89 64 2.52 64 2.52 64 2.52 64 2.52 64 2.52 64 2.52 1.5 0.06 1.5 0.06 1.5 0.06 1.5 0.06 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 2 0.08 8 0.31 10 0.39 12 0.47 16 0.63 8 0.31 10 0.39 12 0.47 16 0.63 8 0.31 10 0.39 12 0.47 16 0.63 8 0.31 10 0.39 12 0.47 16 0.63 20 0.79 - Specifi cation Information • Base Stainless steel, plain, tumbled finish European Standard No. 1.4301 (AISI 304) GN 41 leveling feet are intended for use in aggressive environments. The wide range of possible combinations of the base and the adjusting spindle variants make these leveling feet universally applicable. The base with the rubber pad / cap protects sensitive surfaces and reduces lateral slippage. The type B0 can also be fastened to the mounting surface through two holes. • Threaded stud / tapped socket Stainless steel European Standard No. 1.4305 (AISI 303) • Hexagon nut ISO 4032 Stainless steel European Standard No. 1.4301 (AISI 304) These leveling feet are supplied fully assembled and cannot be disassembled. see also... • Leveling Feet GN 40 (Steel, without Fixing Lug) • Leveling Feet GN 42 (Steel, with Fixing Lug) • Rubber cap Santoprene ® (TPE) ≈ 80 shore A - Clipped on - Black • Leveling Feet GN 42 (Steel, with Slotted Lag Bolt Hole, Rectangular Shape) • Rubber pad Perbunan® (NBR) 70 ±5 shore A - Vulcanized, non-skid - Black • Threaded Tube Inserts GN 992 / GN 992.5 (Aluminum / Stainless Steel) • Leveling Feet GN 43 (Stainless Steel AISI 304, with Fixing Lug) • Leveling Feet GN 44 / GN 45 (Stainless Steel AISI 316, with / without Fixing Lug) • Threaded Tube Ends EN 448 (Plastic) How to order (Inch) • RoHS compliant 1 2 3 4 5 GN 41-40-5/16X18-25-B0-X How to order (Metric) On request • Stud versions T / TK, V / VK and W with Inch thread with certain minimum quantities www.jwwinco.com | phone: 1-800-877-8351 1 2 3 4 5 GN 41-80-M16-75-D0-TK 1 Base diameter d1 2 Thread d 2 3 Length l7 (Length l1) 4 Type (Base) 5 Stud / socket version 1 Base diameter d1 2 Thread d 2 3 Length l1 (Length l 2 , l 3 , l7 ) 4 Type (Base) 5 Stud / socket version 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements | 5
物料型号:GN 41 Leveling Feet,由JWWINCO公司生产,属于Ganter公司。
器件简介:GN 41调平脚适用于各种环境,特别是具有腐蚀性的环境。它们具有多种可能的底座和调节螺杆变体组合,因此具有广泛的适用性。底座带有橡胶垫或帽,可以保护敏感表面并减少侧滑。
引脚分配:文档中提供了不同尺寸和螺纹规格的调平脚的详细尺寸和规格。例如,有不同直径(d1)、螺纹类型(d2)、以及不同版本的调平脚,如S/SK、U/UK、X等。
参数特性:调平脚的材质包括不锈钢(1.4301 AISI 304)、螺纹套/内螺纹(1.4305 AISI 303)、六角螺母(ISO 4032)、橡胶帽(Santoprene® TPE,硬度约80 Shore A,黑色)、橡胶垫(Perbunan® NBR,硬度70±5 Shore A,黑色,防滑)。
功能详解:调平脚具有调平、减震和提升设备的功能。它们可以安装在需要调平或减震的设备上,以提高稳定性和减少振动。
应用信息:适用于需要调平或减震的设备,特别是在敏感或腐蚀性环境中。
封装信息:调平脚是预组装的,不能拆卸。它们可以带有或不带有固定耳,并且有不同的螺纹规格可供选择。
订购信息:提供了英寸和公制的订购指南,包括底座直径、螺纹类型、长度等参数。
41-40-1/2X13-100-D1-SK 价格&库存
很抱歉,暂时无法提供与“41-40-1/2X13-100-D1-SK”相匹配的价格&库存,您可以联系我们找货
