448-D50-D44-M12
448-D50-D44-M12
    JWWINCO
    THREADED TUBE END, PLASTIC
448-D50-D44-M12 数据手册
EN 448 Threaded Tube Ends Plastic, Round Type, with Nickel Plated Brass Insert Inch | Metric ELESA original design NDX.T Specification Information • Body Plastic Technopolymer (Polyamide PA) -- Glass fiber reinforced -- Black, matte finish -- Temperature resistant up to 212 °F (100 °C) EN 448 threaded tube ends enable threaded studs to be installed in tubes, e.g. to accommodate threaded leveling feet. Installed by using a plastic mallet, the tube ends are help in position by the slightly tapered body. • Tapped insert Brass, plain finish or nickel plated • RoHS compliant The values of the static load capacity given in the table are guide values. Exceeding these values can lead to permanent deformation or breakage of the tube end. see also... • Threaded Tube Ends EN 448 (Plastic, Square Type) • Threaded Tube Ends SN 992 (Plastic, Round Type, without Insert) • Threaded Tube Ends GN 992 (Aluminium / Stainless Steel) On request • Additional sizes How to order 1 2 3 EN 448-D1.50-D1.37-3/8X16 2 | 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements 1 Outer diameter d1 2 Inner diameter d 2 3 Thread d 3 www.jwwinco.com | phone: 1-800-877-8351 EN 448 Threaded Tube Ends continued Inch table Dimensions in: inches - millimeters 1 2 d1 d2 D 1.50 D 1.37 - 3/8 x 16-0.39 1/2 x 13-0.39 5/8 x 11-0.59 D 2.00 D 1.78 D 1.87 3/8 x 16-0.39 1/2 x 13-0.39 5/8 x 11-0.59 Outer Ø 3 d 3 Thread Ø - t 1 Thread depth Inner Ø l1 l2 3/4 x 10-0.79 1.50 38.1 3/4 x 10-0.79 1.77 45.0 Static load 0.31 7.9 0.39 9.9 3/8 x 16 - 5/8 x 11 3/4 x 10 1124 lbf 5000 N 1124 lbf 5000 N 1798 lbf 8000 N 1798 lbf 8000 N Metric table 1 2 d1 d2 Outer Ø Dimensions in: millimeters - inches 3 d 3 Thread Ø - t 1 Thread depth Inner Ø l1 D 20 * D 16 - - - M 8-10 - - - - - - D 25* D 21 - - - M 8-10 M10-10 - - - - - D 30 D 25 D 26 D 27 D 28 M 8-10 M 10-10 M 12-10 M 14-15 M 16-15 - - D 32 * D 28 - - - M 8-10 M10-10 - - - - - D 35* D 31 - - - - M 10-10 M 12-10 - - - - D 38 D 33 D 34 - - - M 10-10 M 12-10 M 14-15 M 16-15 - - D 38 D 35 - - - M 8-10 M 10-10 M 12-10 M 14-15 M 16-15 - - D 40 * D 34 - - - - M 10-10 M 12-10 - - - - D 42 * D 36 - - - - M 10-10 M 12-10 - - - - D 38.4 - - - M 10-10 M 12-10 M 14-15 M 16-15 M 20-20 - D 42.4 D 37.4 D 42.4 D 39.4 - - - M 8-10 M 10-10 M 12-10 M 14-15 M 16-15 M 20-20 - D 45* D 39 - - - - - M 12-10 - M 16-15 - - D 48* D 42 - - - - - M 12-10 - M 16-15 - - D 48.3 D 43.3 D 44.3 - - - - M 12-10 M 14-15 M 16-15 M 20-20 - D 48.3 D 45.3 - - - M 8-10 M 10-10 M 12-10 M 14-15 M 16-15 M 20-20 - D 50 * - - - - M 12-10 - M 16-15 - D 50.9 D 45.9 D 46.9 D 47.9 - - - M 12-10 M 14-15 M 16-15 M 20-20 - D 60.3 D 55.3 D 56.3 D 57.3 - M 8-10 M 10-10 M 12-10 M 14-15 M 16-15 M 20-20 M D 44 - - 23 0.91 26 1.02 31 1.22 31 1.22 31 1.22 38 1.50 38 1.50 38 1.50 38 1.50 38 1.50 38 1.50 38 1.50 45 1.77 45 1.77 45 1.77 45 1.77 45 1.77 24-20 52 2.05 l2 5 0.20 5.5 0.22 6 0.24 6 0.24 6 0.24 8 0.31 8 0.31 8 0.31 8 0.31 8 0.31 8 0.31 8.5 0.33 10 0.39 10 0.39 10 0.39 10 0.39 10 0.39 12 0.47 Static load M8 - M16 M20 - M24 4500 N 1012 lbf 4500 N 1012 lbf 4500 N 1012 lbf 4500 N 1012 lbf 4500 N 1012 lbf 5000 N 1124 lbf 5000 N 1124 lbf 5000 N 1124 lbf 5000 N 1124 lbf 5000 N 1124 lbf 5000 N 1124 lbf 5000 N 1124 lbf 5500 N 1236 lbf 5500 N 1236 lbf 5500 N 1236 lbf 5500 N 1236 lbf 5500 N 1236 lbf 5500 N 1236 lbf 8000 N 1798 lbf 8000 N 1798 lbf 8500 N 1911 lbf 8500 N 1911 lbf 8500 N 1911 lbf 8500 N 1911 lbf *For GN 990 construction tubings www.jwwinco.com | phone: 1-800-877-8351 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements | 3
448-D50-D44-M12 价格&库存
很抱歉,暂时无法提供与“448-D50-D44-M12”相匹配的价格&库存,您可以联系我们找货
