EN 448
Threaded Tube Ends
Plastic, Round Type, with Nickel Plated Brass Insert
Inch | Metric
ELESA original design NDX.T
Specification
Information
• Body
Plastic
Technopolymer (Polyamide PA)
-- Glass fiber reinforced
-- Black, matte finish
-- Temperature resistant up to 212 °F (100 °C)
EN 448 threaded tube ends enable threaded studs to be installed in tubes, e.g. to accommodate
threaded leveling feet. Installed by using a plastic mallet, the tube ends are help in position by the
slightly tapered body.
• Tapped insert
Brass, plain finish or nickel plated
• RoHS compliant
The values of the static load capacity given in the table are guide values. Exceeding these values can
lead to permanent deformation or breakage of the tube end.
see also...
• Threaded Tube Ends EN 448 (Plastic, Square Type)
• Threaded Tube Ends SN 992 (Plastic, Round Type, without Insert)
• Threaded Tube Ends GN 992 (Aluminium / Stainless Steel)
On request
• Additional sizes
How to order
1
2
3
EN 448-D1.50-D1.37-3/8X16
2
| 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements
1
Outer diameter d1
2
Inner diameter d 2
3
Thread d 3
www.jwwinco.com | phone: 1-800-877-8351
EN 448 Threaded Tube Ends continued
Inch table
Dimensions in: inches - millimeters
1
2
d1
d2
D 1.50
D 1.37
3/8 x 16-0.39 1/2 x 13-0.39 5/8 x 11-0.59
D 2.00
D 1.78
D 1.87
Outer Ø
3
d 3 Thread Ø - t 1 Thread depth
Inner Ø
l1
l2
3/4 x 10-0.79
1.50
38.1
3/4 x 10-0.79
1.77
45.0
Static load
0.31
7.9
0.39
9.9
3/8 x 16 - 5/8 x 11
3/4 x 10
1124 lbf
5000 N
1124 lbf
5000 N
1798 lbf
8000 N
1798 lbf
8000 N
Metric table
1
2
d1
d2
Outer Ø
Dimensions in: millimeters - inches
3
Inner Ø
l1
D 20 *
D 16
M 8-10
D 25*
D 21
M 8-10
M10-10
D 30
D 25
D 26
D 27
D 28 M 8-10
M 10-10
M 12-10
M 14-15
M 16-15
D 32 *
D 28
M 8-10
M10-10
D 35*
D 31
M 10-10
M 12-10
D 38
D 33
D 34
M 10-10
M 12-10
M 14-15
M 16-15
D 38
D 35
M 8-10
M 10-10
M 12-10
M 14-15
M 16-15
D 40 *
D 34
M 10-10
M 12-10
D 42 *
D 36
M 10-10
M 12-10
D 38.4 -
M 10-10
M 12-10
M 14-15
M 16-15
M 20-20 -
D 42.4 D 37.4
D 42.4 D 39.4 -
M 8-10
M 10-10
M 12-10
M 14-15
M 16-15
M 20-20 -
D 45*
D 39
M 12-10
M 16-15
D 48*
D 42
M 12-10
M 16-15
D 48.3 D 43.3 D 44.3 -
M 12-10
M 14-15
M 16-15
M 20-20 -
D 48.3 D 45.3 -
M 8-10
M 10-10
M 12-10
M 14-15
M 16-15
M 20-20 -
D 50 *
M 12-10
M 16-15
D 50.9 D 45.9 D 46.9 D 47.9
M 12-10
M 14-15
M 16-15
M 20-20 -
D 60.3 D 55.3 D 56.3 D 57.3
M 8-10
M 10-10
M 12-10
M 14-15
M 16-15
M 20-20 M
D 44
23
0.91
26
1.02
31
1.22
31
1.22
31
1.22
38
1.50
38
1.50
38
1.50
38
1.50
38
1.50
38
1.50
38
1.50
45
1.77
45
1.77
45
1.77
45
1.77
45
1.77
24-20 52
2.05
l2
5
0.20
5.5
0.22
6
0.24
6
0.24
6
0.24
8
0.31
8
0.31
8
0.31
8
0.31
8
0.31
8
0.31
8.5
0.33
10
0.39
10
0.39
10
0.39
10
0.39
10
0.39
12
0.47
Static load
M8 - M16
M20 - M24
4500 N
1012 lbf
4500 N
1012 lbf
4500 N
1012 lbf
4500 N
1012 lbf
4500 N
1012 lbf
5000 N
1124 lbf
5000 N
1124 lbf
5000 N
1124 lbf
5000 N
1124 lbf
5000 N
1124 lbf
5000 N
1124 lbf
5000 N
1124 lbf
5500 N
1236 lbf
5500 N
1236 lbf
5500 N
1236 lbf
5500 N
1236 lbf
5500 N
1236 lbf
5500 N
1236 lbf
8000 N
1798 lbf
8000 N
1798 lbf
8500 N
1911 lbf
8500 N
1911 lbf
8500 N
1911 lbf
8500 N
1911 lbf
*For GN 990 construction tubings
3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements |
3
448-D42.4-D37.4-M10 价格&库存
很抱歉,暂时无法提供与“448-D42.4-D37.4-M10”相匹配的价格&库存,您可以联系我们找货
