448-V2.00-V1.78-3/4X10
    JWWINCO
    THREADED TUBE END, PLASTIC
448-V2.00-V1.78-3/4X10 数据手册
EN 448 Threaded Tube Ends Plastic, Square Type, with Nickel Plated Brass Insert Inch | Metric ELESA original design NDX.Q Specification Information • Body Plastic Technopolymer (Polyamide PA) -- Glass fiber reinforced -- Black, matte finish -- Temperature resistant up to 212 °F (100 °C) EN 448 threaded tube ends enable threaded studs to be installed in tubes, e.g. to accommodate threaded leveling feet. Installed by using a plastic mallet, the tube ends are help in position by the slightly tapered body. • Tapped insert Brass, nickel plated • RoHS compliant The values of the static load capacity given in the table are guide values. Exceeding these values can lead to permanent deformation or breakage of the tube end. see also... • Threaded Tube Ends EN 448 (Plastic, Round Type) • Threaded Tube Ends SN 993 (Plastic, Square Type, without Insert) • Threaded Tube Ends GN 992 (Aluminium / Stainless Steel) On request • Additional sizes How to order 1 2 3 EN 448-V1.50-V1.26-3/8X16 2 | 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements 1 Outer square s1 2 Inner square s 2 3 Thread d www.jwwinco.com | phone: 1-800-877-8351 EN 448 Threaded Tube Ends continued Inch table 1 2 s1 s2 Outer Dimensions in: inches - millimeters 3 d Thread Ø - t Thread depth Inner l1 l2 Static load 3/8 x 16 - 5/8 x 11 3/4 x 10 V 1.50 V 1.26 V 1.37 3/8 x 16-0.39 1/2 x 13-0.39 5/8 x 11-0.59 3/4 x 10-0.79 1.50 38.1 0.31 7.9 1349 lbf 6000 N 1798 lbf 8000 N V 2.00 V 1.78 V 1.87 3/8 x 16-0.39 1/2 x 13-0.39 5/8 x 11-0.59 3/4 x 10-0.79 1.77 45.0 0.39 9.9 1349 lbf 6000 N 1911 lbf 8500 N Metric table Dimensions in: millimeters - inches 1 2 s1 s2 M8 - M16 M20 - M24 V 20 * V 16 - - - M 8-10 - - - - - 23 0.91 5 0.20 4000 N 899 lbf - V 20 V 17 - - - M 8-10 - - - - - 23 0.91 5 0.20 4000 N 899 lbf - V 25* V 21 - - - M 8-10 M 10-10 - - - - 26 1.02 6 0.24 4500 N 1012 lbf - V 25 V 22 - - - M 8-10 M 10-10 M 12-10 - - - 26 1.02 6 0.24 4500 N 1012 lbf - V 30 * V 26 - - - M 8-10 M 10-10 M 12-10 M 14-15 M 16-15 - 31 1.22 6 0.24 4500 N 1012 lbf - V 30 V 27 - - - M 8-10 M 10-10 M 12-10 M 14-15 M 16-15 - 31 1.22 6 0.24 4500 N 1012 lbf - V 35* V 31 - - - M 8-10 M 10-10 M 12-10 M 14-15 M 16-15 M 20-20 38 1.50 8 0.31 6000 N 1349 lbf 6000 N 1349 lbf V 35 V 32 - - - M 8-10 M 10-10 M 12-10 M 14-15 M 16-15 M 20-20 38 1.50 8 0.31 6000 N 1349 lbf 6000 N 1349 lbf V 40 * V 34 - - - - M 10-10 M 12-10 - - - 38 1.50 8 0.31 6000 N 1349 lbf 8000 N 1798 lbf V 40 V 35 V 36 V 37 V 37.6 M 8-10 M 10-10 M 12-10 M 14-15 M 16-15 M 20-20 38 1.50 8 0.31 6000 N 1349 lbf 8000 N 1798 lbf V 45* V 39 - - - - - M 12-10 - M 16-15 - 38 1.50 8 0.31 6000 N 1349 lbf 8000 N 1798 lbf V 50 * V 44 - - - - M 10-10 M 12-10 M 14-15 M 16-15 M 20-20 45 1.77 10 0.39 6000 N 1349 lbf 8500 N 1911 lbf V 50 V 45 V 46 V 47 V 47.6 M 8-10 M 10-10 M 12-10 M 14-15 M 16-15 M 20-20 45 1.77 10 0.39 6000 N 1349 lbf 8500 N 1911 lbf V 60 V 54 V 56 - - M 10-10 M 12-10 M 14-15 M 16-15 M 20-20 45 1.77 10 0.39 6000 N 1349 lbf 8500 N 1911 lbf Outer 3 d Thread Ø - t Thread depth Inner - l1 l2 Static load *For GN 990 construction tubings www.jwwinco.com | phone: 1-800-877-8351 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements | 3
448-V2.00-V1.78-3/4X10 价格&库存
很抱歉,暂时无法提供与“448-V2.00-V1.78-3/4X10”相匹配的价格&库存,您可以联系我们找货
