EN 448
Threaded Tube Ends
Plastic, Square Type, with Nickel Plated Brass Insert
Inch | Metric
ELESA original design NDX.Q
Specification
Information
• Body
Plastic
Technopolymer (Polyamide PA)
-- Glass fiber reinforced
-- Black, matte finish
-- Temperature resistant up to 212 °F (100 °C)
EN 448 threaded tube ends enable threaded studs to be installed in tubes, e.g. to accommodate
threaded leveling feet. Installed by using a plastic mallet, the tube ends are help in position by the
slightly tapered body.
• Tapped insert
Brass, nickel plated
• RoHS compliant
The values of the static load capacity given in the table are guide values. Exceeding these values can
lead to permanent deformation or breakage of the tube end.
see also...
• Threaded Tube Ends EN 448 (Plastic, Round Type)
• Threaded Tube Ends SN 993 (Plastic, Square Type, without Insert)
• Threaded Tube Ends GN 992 (Aluminium / Stainless Steel)
On request
• Additional sizes
How to order
1
2
3
EN 448-V1.50-V1.26-3/8X16
2
| 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements
1
Outer square s1
2
Inner square s 2
3
Thread d
www.jwwinco.com | phone: 1-800-877-8351
EN 448 Threaded Tube Ends continued
Inch table
1
2
s1
s2
Outer
Dimensions in: inches - millimeters
3
d Thread Ø - t Thread depth
Inner
l1
l2
Static load
3/8 x 16 - 5/8 x 11
3/4 x 10
V 1.50 V 1.26 V 1.37 3/8 x 16-0.39
1/2 x 13-0.39
5/8 x 11-0.59
3/4 x 10-0.79
1.50
38.1
0.31
7.9
1349 lbf
6000 N
1798 lbf
8000 N
V 2.00 V 1.78 V 1.87 3/8 x 16-0.39
1/2 x 13-0.39
5/8 x 11-0.59
3/4 x 10-0.79
1.77
45.0
0.39
9.9
1349 lbf
6000 N
1911 lbf
8500 N
Metric table
Dimensions in: millimeters - inches
1
2
s1
s2
M8 - M16
M20 - M24
V 20 *
V 16
M 8-10
23
0.91
5
0.20
4000 N
899 lbf
V 20
V 17
M 8-10
23
0.91
5
0.20
4000 N
899 lbf
V 25*
V 21
M 8-10
M 10-10
26
1.02
6
0.24
4500 N
1012 lbf
V 25
V 22
M 8-10
M 10-10
M 12-10
26
1.02
6
0.24
4500 N
1012 lbf
V 30 *
V 26
M 8-10
M 10-10
M 12-10
M 14-15
M 16-15
31
1.22
6
0.24
4500 N
1012 lbf
V 30
V 27
M 8-10
M 10-10
M 12-10
M 14-15
M 16-15
31
1.22
6
0.24
4500 N
1012 lbf
V 35*
V 31
M 8-10
M 10-10
M 12-10
M 14-15
M 16-15
M 20-20
38
1.50
8
0.31
6000 N
1349 lbf
6000 N
1349 lbf
V 35
V 32
M 8-10
M 10-10
M 12-10
M 14-15
M 16-15
M 20-20
38
1.50
8
0.31
6000 N
1349 lbf
6000 N
1349 lbf
V 40 *
V 34
M 10-10
M 12-10
38
1.50
8
0.31
6000 N
1349 lbf
8000 N
1798 lbf
V 40
V 35
V 36
V 37
V 37.6 M 8-10
M 10-10
M 12-10
M 14-15
M 16-15
M 20-20
38
1.50
8
0.31
6000 N
1349 lbf
8000 N
1798 lbf
V 45*
V 39
M 12-10
M 16-15
38
1.50
8
0.31
6000 N
1349 lbf
8000 N
1798 lbf
V 50 *
V 44
M 10-10
M 12-10
M 14-15
M 16-15
M 20-20
45
1.77
10
0.39
6000 N
1349 lbf
8500 N
1911 lbf
V 50
V 45
V 46
V 47
V 47.6 M 8-10
M 10-10
M 12-10
M 14-15
M 16-15
M 20-20
45
1.77
10
0.39
6000 N
1349 lbf
8500 N
1911 lbf
V 60
V 54
V 56
M 10-10
M 12-10
M 14-15
M 16-15
M 20-20
45
1.77
10
0.39
6000 N
1349 lbf
8500 N
1911 lbf
Outer
3
Inner
l1
l2
Static load
*For GN 990 construction tubings
3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements |
3
很抱歉,暂时无法提供与“448-V50-V45-M16”相匹配的价格&库存,您可以联系我们找货
