565.2-26-160-A-BL
565.2-26-160-A-BL
    JWWINCO
    ALUMINUM CABINET U-HANDLE
565.2-26-160-A-BL 数据手册
GN 565.2 Angled Cabinet “U” Handles Aluminum, with Tapped or Through Holes, with Mounting Hardware Metric 3 Type A Mounting from the back (tapped blind hole) B Mounting from the operator’s side (only for b1=26) Metric table 1 Dimensions in: millimeters - inches 2 b1 Length l ±0.25 a b2 b3 b4 b 5 +1 d1 d2 h1 h2 r 20      .79 112      4.41 13      .51 24      .94 32     1.26 50     1.97 13.5    .53 M6 - 32     1.26 48     1.89 13      .51 10      .39 20      .79 128      5.04 13      .51 24      .94 32     1.26 50     1.97 13.5    .53 M6 - 32     1.26 48     1.89 13      .51 10      .39 26     1.02 128      5.04 17      .67 32     1.26 34     1.34 57     2.24 18      .71 M8 M6 34     1.34 54     2.13 17      .67 12      .47 26     1.02 160      6.30 17      .67 32     1.26 34     1.34 57     2.24 18      .71 M8 M6 34     1.34 54     2.13 17      .67 12      .47 Specification • Aluminum -- Powder coated Black, RAL 9005, textured finish Silver, RAL 9006, textured finish -- Anodized finish, natural color -- Blank, tumbled finish 4 SW SR EL BL • Type B -- Socket button head screws ISO 7380-M6-25 -- Hexagon nuts ISO 4032-M6 -- Washers DIN 125 Steel, zinc plated, blue passivated finish • RoHS compliant Type A Type B t min. Information GN 565.2 angled cabinet “U” handles are manufactured from a bent aluminum profile and have excellent stability and ergonomic design. The 35° angled contact surface allows improved access even in tight spaces such as corners. The manufacturing process allows the production of special lengths in relatively small quantities. For type B, socket button head screws, hexagon nuts and washers are included. see also... • Cabinet “U” Handles GN 425.1 (Offset) • Cabinet “U” Handles GN 426.1 (Offset Round Aluminum) • Ergostyle ® Off-Set Open “U” Handles EN 630.1 (Technopolymer Plastic) • T-Nut Assemblies GN 965 (for 30 / 40 mm T-Slot Profile Systems) • T-Nut Assemblies GN 968 (for 30 / 40 / 45 mm T-Slot Profile Systems) On request • Special lengths How to order 1 2 3 4 GN 565.2-26-128-B-SW 10 | 1.2 Operating by Using Machine and Device Handles 1 Handle width b1 2 Length l 3 Type 4 Finish www.jwwinco.com | phone: 1-800-877-8351
565.2-26-160-A-BL 价格&库存
很抱歉,暂时无法提供与“565.2-26-160-A-BL”相匹配的价格&库存,您可以联系我们找货
