GN 581
Safety Swivel Lifting Eye Bolts
Steel
Inch | Metric
2 Type
A Without key
B With key
Inch table
Dimensions in: inches - millimeters
1
d1
d2
d3
d4
d5
h
k1
k2
Length l
Nominal load (WLL)
in metric tons
3/8 x 16
0.63
16
0.98
25
1.18
30
0.98
25
1.81
46
0.35
9
1.85
47
0.59
15
0.40 t [4.0 kN]
1/2 x 13
0.79
30
1.34
34
1.18
30
2.17
55
0.39
10
2.20
56
0.71
18
0.75 t [7.5 kN]
5/8 x 11
0.93
23.5
1.42
36
1.57
40
1.38
35
2.52
64
0.51
13
2.56
65
0.94
24
1.50 t [15.0 kN]
3/4 x 10
1.14
29
1.61
41
1.97
50
1.57
40
2.95
75
0.63
16
2.99
76
1.18
30
2.30 t [23.0 kN]
7/8 x 9
1.14
29
1.61
41
1.97
50
1.57
40
2.95
75
0.63
16
2.99
76
1.18
30
2.30 t [23.0 kN]
1 x 8
1.38
35
2.01
51
2.36
60
1.93
49
3.54
90
0.75
19
3.62
92
1.42
36
3.20 t [32.0 kN]
1 1/4 x 7
1.73
44
2.60
66
2.95
75
2.36
60
4.45
113
0.94
24
4.49
114
1.77
45
4.50 t [45.0 kN]
Thread
Metric table
Dimensions in: millimeters - inches
1
d1
d2
d3
d4
d5
h
k1
k2
Length l
Nominal load (WLL)
in metric tons
M 6
13
0.51
23
0.91
28
1.10
37
1.46
7
0.28
37
1.46
9
0.35
0.10 t [1.0 kN]
M 8
16
0.63
25
0.98
30
1.18
25
0.98
46
1.81
9
0.35
47
1.85
12
0.47
0.30 t [3.0 kN]
M 10
16
0.63
25
0.98
30
1.18
25
0.98
46
1.81
9
0.35
47
1.85
15
0.59
0.40 t [4.0 kN]
M 12
30
1.18
34
1.34
30
1.18
55
2.17
10
0.39
56
2.20
18
0.71
0.75 t [7.5 kN]
M 16
23.5
0.93
36
1.42
40
1.57
35
1.38
64
2.52
13
0.51
65
2.56
24
0.94
1.50 t [15.0 kN]
M 20
29
1.14
41
1.61
50
1.97
40
1.57
75
2.95
16
0.63
76
2.99
30
1.18
2.30 t [23.0 kN]
M 24
35
1.38
51
2.01
60
2.36
49
1.93
90
3.54
19
0.75
92
3.62
36
1.42
3.20 t [32.0 kN]
M 30
44
1.73
66
2.60
75
2.95
60
2.36
113
4.45
24
0.94
114
4.49
45
1.77
4.50 t [45.0 kN]
M 36
53
2.09
75
2.95
90
3.54
72
2.83
135
5.31
29
1.14
135
5.31
54
2.13
7.00 t [70.0 kN]
Thread
2
| 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements
www.jwwinco.com | phone: 1-800-877-8351
GN 581 Safety Swivel Lifting Eye Bolts continued
Safety notes
The loads in brackets refer to the load capacity of the corresponding DIN 580 lifting eye bolt. If this value is not indicated, the use of DIN 580 lifting eye bolts is not
permitted!
The screw-on surface of the GN 581 lifting eye bolts must be plane and at a right angle to the threaded hole; the countersunk must be ≤ the nominal diameter of
the thread.
When screwed in, the collar of the bolt must fit firmly (do not use washers) and the ring housing must rotate freely by 360°.
Before applying the load, turn the lifting eye bolt in the direction of the load. The lifting eye bolt is not suitable for rotary movements under load.
The specified load values apply to a minimum screw-in length of 1.5 × nominal thread diameter in steel with a minimum tensile strength of 37 kp/mm², at an
operating temperature of -40 °F to +212 °F (-40 °C to +100 °C). Load bearing capacity under different conditions on request.
The operating instruction contains further guidelines and is included with every eye bolt (see also at www.jwwinco.com/service).
Dimensions in: metric tons
Mounting method
1
0°
1
Quantity
Angle of inclination
Factor
1
90°
1
2
0°
2
2
90°
2
2
0 to 45°
1.4
2
45 to 60°
1
2
asymmetric
1
3 and 4
0 to 45°
2.1
3 and 4
45 to 60°
1.5
3 and 4
asymmetric
1
M 6
0.50 t[0.10]
0.10 t
1.00 t [0.28]
0.20 t
0.14 t [0.10]
0.10 t
0.10 t
0.21 t
0.15 t
0.10 t
M 8
0.30 t
2.00 t [0.28]
0.60 t
0.42 t [0.10]
0.30 t
0.30 t
0.63 t
0.45 t
0.30 t
x 16
1.00 t [0.14]
M 10
3/8
1.00 t [0.23]
0.40 t
2.00 t [0.46]
0.80 t
0.56 t [0.17]
0.40 t
0.40 t
0.84 t
0.60 t
0.40 t
M 12
1/2
x 13
2.00 t [0.34]
0.75 t
4.00 t [0.68]
1.50 t
1.00 t [0.24]
0.75 t
0.75 t
1.57 t
1.12 t
0.75 t
M 16
5/8
x 11
M 20
3/4
x 10
7/8
M 24
1
x 8
8.00 t [1.80]
3.20 t
16.00 t [3.60]
6.40 t
4.50 t [1.29]
3.20 t
3.20 t
6.70 t
4.80 t
3.20 t
M 30
1 1/4 x 7 -
12.00 t [3.20]
4.50 t
24.00 t [6.40]
9.00 t
6.30 t [2.30]
4.50 t
4.50 t
9.50 t
6.75 t
4.50 t
16.00 t [4.60]
7.00 t
32.00 t [9.20]
14.00 t
9.80 t [3.30]
7.00 t
7.00 t
14.70 t
10.50 t
7.00 t
M 36
x 9
4.00 t [0.70]
1.50 t
8.00 t [1.40]
3.00 t
2.12 t [0.50]
1.50 t
1.50 t
3.15 t
2.24 t
1.50 t
6.00 t [1.20]
2.30 t
12.00 t [2.40]
4.60 t
3.22 t [0.86]
2.30 t
2.30 t
4.83 t
3.45 t
2.30 t
Specifi cation
Information
• Ring
Steel
German Material No. 1.6541
- Forged
- High-strength tempered
- 100% electromagnetic tensile tested
according to EN 1677
- Bright pink powder coated
The bolt of GN 581 safety swivel lifting eye bolts is captively mounted in the ring housing, yet
rotates freely, allowing the direction of the load to be adjusted and preventing unintentional loosening
or overtightening (as it is possible with DIN 580 lifting eye bolts).
• Threaded socket head bolt
Steel
- Property class 10.9
GN 581 lifting eye bolts comply with Machinery Directive 2006/42/EG and are BG tested.
• Hexagon key cover plate
Steel, zinc plated
• RoHS compliant
These lifting eye bolts offer a high load carrying capacity and are tested to meet high safety standards
in all load directions (safety factor 4).
The nominal values for load capacity in the table are for the most extreme loading conditions listed, and
are also clearly marked on the ring.
The integrated RFID transponder is used to clearly identify the lifting gear, e.g. during the prescribed
regular inspection.
Type B with hexagon key allows assembly without the need to use tools: inserting the hexagon key in
the hexagon socket of the bolt allows the bolt to be turned by hand.
see also...
• Safety Swivel Lifting Eye Bolts GN 581.5 (Stainless Steel)
On request
• Additional sizes
How to order
1
2
GN 581-3/4X10-B
1
Thread d1
2
Type
3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements |
3
很抱歉,暂时无法提供与“581-3/8X16-A”相匹配的价格&库存,您可以联系我们找货
