L85/AK
L85/AK
    JWWINCO
    STEEL SHORT INDEXING PLUNGER
L85/AK 数据手册
GN 607 Short Indexing Plungers Steel / Stainless Steel Non Lock-Out Metric 2 Type A Without lock nut AK With lock nut Metric table Dimensions in: millimeters - inches 1 d1 Pin  −0.02 −0.05 Bore H7 b d2 Thread d3 e≈ l1 l 2 ±0.5 l 3 −0.15 l 4 l5 A/F Spring load ≈ Axial load Steel Stainless steel Initial End Initial End 6  .24 4  .16 M 12 x 1.5 25   .98 19.6   .77 45  1.77 6  .24 10   .39 5  .20 3  .12 17   .67 11 N   2.47 lbf 28 N   6.29 lbf  9N   2.02 lbf 25 N   5.62 lbf 400 N   89.92 lbf 8  .31 4.5  .18 M 16 x 1.5 31  1.22 21.9   .86 54  2.13 8  .31 12   .47 6  .24 3  .12 19   .75 15 N   3.37 lbf 29 N   6.52 lbf 13 N   2.92 lbf 26 N   5.85 lbf 500 N 112 lbf 3 Information Specification • Threaded body -- Steel, blackened finish ST Plunger pin hardened Thin hexagon nut GN 909 -- Stainless steel NI European Standard No. 1.4305 (AISI 303) Plunger pin chemically nickel plated Thin hexagon nut GN 909.5 GN 607 short indexing plungers are standard units used for a wide range of indexing applications where the threaded body needs to be reduced to a minimum. • Knob Plastic Technopolymer (Polyamide PA) -- Temperature resistant up to 230 °F (110 °C) -- Black, matte finish -- Not removable • Spacer Bushings GN 609.5 (to Limit the Thread Length) The extremely thin GN 909 / GN 909.5 lock nuts increase the mounting options. see also... • List of Indexing Plunger Types • Locating Bushings GN 412.2 / GN 412.4 • Locating Bushings with Cone GN 412.3 / GN 412.5 • Lock nut Thin hexagon nut GN 909 / GN 909.5 -- Steel, blackened finish -- Stainless steel European Standard No. 1.4305 (AISI 303) • RoHS compliant How to order 1 2 3 GN 607-8-AK-ST 2 | 3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements 1 Pin diameter d1 2 Type 3 Material www.jwwinco.com | phone: 1-800-877-8351
L85/AK 价格&库存
很抱歉,暂时无法提供与“L85/AK”相匹配的价格&库存,您可以联系我们找货
