120FR84/A
120FR84/A
    JWWINCO
    STAINLESS SHORT INDEXING PLUNGER
120FR84/A 数据手册
GN 607.1 Short Indexing Plungers Steel / Stainless Steel Lock-Out Metric 2 Type A Without lock nut AK With lock nut Metric table Dimensions in: millimeters - inches 1 d1 Pin  −0.02 −0.05 Bore H7 d2 Thread d3 e≈ l1 l 2 ±0.5 l 3 −0.15 l4 A/F Spring load ≈ Axial load Steel Stainless steel Initial End Initial End 6  .24 M 12 x 1.5 25   .98 19.6   .77 45  1.77 6  .24 10   .39 5  .20 17   .67 11 N   2.47 lbf 28 N   6.29 lbf  9N   2.02 lbf 25 N   5.62 lbf 400 N   89.92 lbf 8  .31 M 16 x 1.5 31  1.22 21.9   .86 54  2.13 8  .31 12   .47 6  .24 19   .75 15 N   3.37 lbf 29 N   6.52 lbf 13 N   2.92 lbf 26 N   5.85 lbf 500 N 112 lbf Specification 3 • Threaded body -- Steel, blackened finish ST Plunger pin hardened -- Stainless steel NI European Standard No. 1.4305 (AISI 303) Plunger pin chemically nickel plated • Knob Plastic Technopolymer (Polyamide PA) -- Temperature resistant up to 230 °F (110 °C) -- Black, matte finish -- Not removable Information GN 607.1 short indexing plungers with lock-out are used for applications where the plunger pin needs to stay in its retracted position. To achieve this, the knob is rotated by 90 degrees after being retracted. A notch keeps the plunger in the retracted position. The extremely thin GN 909 / GN 909.5 lock nuts increase the mounting options. see also... • List of Indexing Plunger Types • Locating Bushings GN 412.2 / GN 412.4 • Locating Bushings with Cone GN 412.3 / GN 412.5 • Spacer Bushings GN 609.5 (to Limit the Thread Length) • Lock nut Thin hexagon nut GN 909 / GN 909.5 -- Steel, blackened finish -- Stainless steel European Standard No. 1.4305 (AISI 303) • RoHS compliant How to order 1 2 3 GN 607.1-6-A-ST 2 | 3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements 1 Pin diameter d1 2 Type 3 Material www.jwwinco.com | phone: 1-800-877-8351
120FR84/A 价格&库存
很抱歉,暂时无法提供与“120FR84/A”相匹配的价格&库存,您可以联系我们找货
