GN 607.1
Short Indexing Plungers
Steel / Stainless Steel
Lock-Out
Metric
2
Type
A Without lock nut
AK With lock nut
Metric table
Dimensions in: millimeters - inches
1
d1
Pin −0.02
−0.05
Bore H7
d2
Thread
d3
e≈
l1
l 2 ±0.5
l 3 −0.15
l4
A/F
Spring load ≈
Axial load
Steel
Stainless steel
Initial
End
Initial
End
6
.24
M 12 x 1.5 25
.98
19.6
.77
45
1.77
6
.24
10
.39
5
.20
17
.67
11 N
2.47 lbf
28 N
6.29 lbf
9N
2.02 lbf
25 N
5.62 lbf
400 N
89.92 lbf
8
.31
M 16 x 1.5 31
1.22
21.9
.86
54
2.13
8
.31
12
.47
6
.24
19
.75
15 N
3.37 lbf
29 N
6.52 lbf
13 N
2.92 lbf
26 N
5.85 lbf
500 N
112 lbf
Specification
3
• Threaded body
-- Steel, blackened finish ST
Plunger pin hardened
-- Stainless steel NI
European Standard No. 1.4305 (AISI 303)
Plunger pin chemically nickel plated
• Knob
Plastic
Technopolymer (Polyamide PA)
-- Temperature resistant up to 230 °F (110 °C)
-- Black, matte finish
-- Not removable
Information
GN 607.1 short indexing plungers with lock-out are used for applications where the plunger pin needs
to stay in its retracted position. To achieve this, the knob is rotated by 90 degrees after being retracted.
A notch keeps the plunger in the retracted position.
The extremely thin GN 909 / GN 909.5 lock nuts increase the mounting options.
see also...
• List of Indexing Plunger Types
• Locating Bushings GN 412.2 / GN 412.4
• Locating Bushings with Cone GN 412.3 / GN 412.5
• Spacer Bushings GN 609.5 (to Limit the Thread Length)
• Lock nut
Thin hexagon nut GN 909 / GN 909.5
-- Stainless steel
• RoHS compliant
How to order
1
2
3
GN 607.1-6-A-ST
2
| 3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements
1
Pin diameter d1
2
Type
3
Material
www.jwwinco.com | phone: 1-800-877-8351
很抱歉,暂时无法提供与“L87/A”相匹配的价格&库存,您可以联系我们找货
