8W18L89
8W18L89
    JWWINCO
    SS INDEXING PLUNGER PLATE MOUNT
8W18L89 数据手册
GN 608 GN 608.5 Indexing Plungers Steel Plunger Pin Stainless Steel Plunger Pin Non Lock-Out, Plate Mount Metric Metric table 1 2 d1 l1 Pin  −0.02 −0.05 Bore H7 Dimensions in: millimeters - inches b1 b2 d 2  −0.02 −0.1 d3 d4 d5 k l2 l 3 −0.15 l4 l5 Stroke Spring load ≈ Axial load Initial End 6  .24  6   .24 40  1.57 18   .71 10   .39 25   .98 4.3  .17  8.3   .33 30  1.18 37  1.46 2.5  .10 4.5  .18 6  .24  9N   2.02 lbf 25 N   5.62 lbf 400 N   89.92 lbf 6  .24 14   .55 40  1.57 18   .71 10   .39 25   .98 4.3  .17  8.3   .33 30  1.18 45  1.77 2.5  .10 4.5  .18 6  .24  9N   2.02 lbf 25 N   5.62 lbf 400 N   89.92 lbf 8  .31  8   .31 46  1.81 20   .79 12   .47 31  1.22 5.3  .21 10.4   .41 34  1.34 44  1.73 2.5  .10 5.5  .22 8  .31 13 N   2.92 lbf 26 N   5.85 lbf 500 N 112 lbf 8  .31 18   .71 46  1.81 20   .79 12   .47 31  1.22 5.3  .21 10.4   .41 34  1.34 54  2.13 2.5  .10 5.5  .22 8  .31 13 N   2.92 lbf 26 N   5.85 lbf 500 N 112 lbf Specification Information • Mounting plate Zinc die-cast Zinc plated, blue passivated finish GN 608 / GN 608.5 indexing plungers are used in applications that require surface mounting. • Knob Plastic Technopolymer (Polyamide PA) -- Temperature resistant up to 230 °F (110 °C) -- Black, matte finish -- Not removable • GN 608 -- Plunger pin Steel, hardened -- Single components Steel • GN 608.5 -- Plunger pin Stainless steel European Standard No. 1.4305 (AISI 303) Chemically nickel plated -- Single components Stainless steel • RoHS compliant These series have been expanded with additional plunger pin lengths to widen the application opportunities. Please note that for these longer pin lengths (d1 = 6 mm, l1 = 14 mm / d1 = 8 mm, l1 = 18 mm), the pin does not fully retract. see also... • List of Indexing Plunger Types • Locating Bushings GN 412.2 / GN 412.4 • Locating Bushings with Cone GN 412.3 / GN 412.5 • Indexing Plungers GN 817.1 (Lock-Out / Non Lock-Out) • Mini Indexing Plungers GN 822.8 (Lock-Out / Non Lock-Out) How to order (Steel plunger pin) 1 2 GN 608-8-18 How to order (Stainless steel plunger pin) 1 2 GN 608.5- 6 -14 2 | 3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements 1 Pin diameter d1 2 Length l1 1 Pin diameter d1 2 Length l1 www.jwwinco.com | phone: 1-800-877-8351
8W18L89 价格&库存
很抱歉,暂时无法提供与“8W18L89”相匹配的价格&库存,您可以联系我们找货
