10W12P82
10W12P82
    JWWINCO
    STEEL CAM ACTION INDEX PLUNGER
10W12P82 数据手册
GN 612.2 Cam Action Indexing Plungers Steel, Lock-Out, with Mounting Flange Metric 3 Type A Without plastic sleeve B With plastic sleeve Metric table Dimensions in: millimeters - inches 1 2 d1 d2 d3 h k l1 l2 l3 l4 s Initial End  6   .24 16   .63 35  1.38 16   .63 20   .79 56  2.20 10   .39 32  1.26 42  1.65 12   .47 12 N   2.70 lbf 32 N   7.19 lbf  8   .31 16   .63 35  1.38 16   .63 20   .79 56  2.20 10   .39 32  1.26 42  1.65 12   .47 12 N   2.70 lbf 32 N   7.19 lbf  8   .31 20   .79 40  1.57 20   .79 22   .87 69  2.72 12   .47 37  1.46 52  2.05 15   .59 21 N   4.72 lbf 58 N 13.04 lbf 10   .39 16   .63 35  1.38 16   .63 20   .79 56  2.20 10   .39 32  1.26 42  1.65 12   .47 12 N   2.70 lbf 32 N   7.19 lbf 10   .39 20   .79 40  1.57 20   .79 22   .87 69  2.72 12   .47 37  1.46 52  2.05 15   .59 21 N   4.72 lbf 58 N 13.04 lbf 12   .47 20   .79 40  1.57 20   .79 22   .87 69  2.72 12   .47 37  1.46 52  2.05 15   .59 21 N   4.72 lbf 58 N 13.04 lbf 0 Pin  −0.05 Bore H7 Spring load ≈ Specification Information • Body / lever arm Steel, blackened finish GN 612.2 cam action indexing plungers are best utilized in applications where the pin may need to be retracted periodically. By rotating the lever arm 180° the plunger pin is withdrawn. The notch allows for safe positioning while the plunger pin is held in the retracted position • Plunger pin Steel, nitrided • Plastic sleeve Technopolymer (Polyamide PA) -- Temperature resistant up to 230 °F (110 °C) -- Black, matte finish • RoHS compliant These indexing plungers also feature a counterbored flange for surface mounting. The plastic ribbed sleeve offers an aesthetically pleasing and comfortable finger grip. see also... • Product Range Standard Parts for Profile Systems • List of Cam Action Indexing Plungers Types • Locating Bushings GN 412.2 / GN 412.4 • Square Spring Latches GN 722.3 • T-Nut Assemblies GN 965 (for 30 / 40 mm T-Slot Profile Systems) • T-Nut Assemblies GN 968 (for 30 / 40 / 45 mm T-Slot Profile Systems) How to order 1 2 3 GN 612.2-8-16-B 80 | 3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements 1 Pin diameter d1 2 Outer diameter d 2 3 Type www.jwwinco.com | phone: 1-800-877-8351
10W12P82 价格&库存
很抱歉,暂时无法提供与“10W12P82”相匹配的价格&库存,您可以联系我们找货
