GN 617
Indexing Plungers
Steel / Stainless Steel
Non Lock-Out
Inch | Metric
3
Type
A
With plastic knob,
without lock nut
AK With plastic knob,
with lock nut
AN With stainless steel knob,
without lock nut
AKN With stainless steel knob,
with lock nut
G
With threaded stem,
without lock nut
GK With threaded stem,
with lock nut
Specification
4
• Threaded body
Steel, blackened finish —
Plunger pin hardened
• Threaded body
Stainless steel NI
European Standard No. 1.4305 (AISI 303)
Plunger pin chemically nickel plated
• Knob (Type A / AK)
Plastic
Technopolymer (Polyamide PA)
-- Temperature resistant up to 230 °F (110 °C)
-- Black, matte finish
-- Not removable
Information
GN 617 indexing plungers are standard components used for a wide range of indexing applications.
Type G and GK with threaded stem are for applications where a special knob or attachment is required,
or for such cases where the spindle is linked directly to an operating mechanism.
The indexing plungers completely made of stainless steel parts are a good choice for use in corrosion
free environments.
see also...
• List of Indexing Plunger Types
• Mounting Blocks GN 412.1
• Locating Bushings GN 412.2 / GN 412.4
• Spacer Bushings GN 609.5 (to Limit the Thread Length)
• Knob (Type AN / AKN)
Stainless steel
Not removable
• Inch size lock nut
-- Steel, blackened finish
ANSI/ASME B18.2.2
-- 18-8 Stainless steel (A2)
• Metric size lock nut
DIN 439 B / ISO 8675
-- Stainless steel (A2)
• RoHS compliant
How to order (Inch, steel, with plastic knob)
1
2
3
GN 617-5-3/8X24-A
How to order (Inch, stainless steel, with plastic knob)
1
2
3
4
GN 617-6-1/2X13-AK-NI
How to order (Metric, stainless steel, with stainless steel knob)
1
2
3
4
GN 617-8-M16X1.5-AKN-NI
2
| 3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements
1
Pin diameter d1
2
Thread d 2
3
Type
1
Pin diameter d1
2
Thread d 2
3
Type
4
Material
1
Pin diameter d1
2
Thread d 2
3
Type
4
Material
www.jwwinco.com | phone: 1-800-877-8351
GN 617 Indexing Plungers continued
Inch table
1
2
d1
d2
Pin −0.001
Thread
−0.002
Bore +0.001
Dimensions in: inches - millimeters
d3
d4
Thread
e
l1 ≈
l2
l3
l4
l5
min.
l6
l7
A/F
Spring load ≈
Steel
Stainless steel
Initial
5
6
8
.20
3/8 x 24
.83
M5
.54
13.8
1.77
45
5
.24
1/2 x 13
.98
25
M6
.64
16.2
2.15
54.5
6
.31
5/8 x 11
1.22
31
M8
.86
21.9
2.72
69
8
21
.20
17
.67
5
.24
.79
.31
1.02
26
8
.20
.24
.31
15
17
21
.59
.67
.83
6
10
12
.24
.18
4.5
.39
.47
8
10
.31
.39
12
14
19
End
Initial
End
.47
1.57 lbf
7N
3.82 lbf
17 N
1.35 lbf
6N
3.37 lbf
15 N
.55
2.02 lbf
9N
5.40 lbf
24 N
1.80 lbf
8N
4.72 lbf
21 N
.75
2.47 lbf
11 N
6.74 lbf
30 N
2.02 lbf
9N
5.85 lbf
26 N
Metric table
1
2
d1
d2
Pin −0.02
−0.05
Bore H7
5
6
8
10
.20
.24
.31
.39
Thread
Dimensions in: millimeters - inches
d3
d4
Thread
e
l1 ≈
l2
l3
l4
l5
min.
l6
l7
A/F
Spring load ≈
Steel
Initial
M 10 x 1
21
M5
13.8
.54
45
1.77
5
M 12 x 1.5
25
M6
16.2
.64
54.5
2.15
6
M 16 x 1.5
31
1.22
M8
21.9
.86
69
2.72
8
M 20 x 1.5 31
1.22
M8
25.4
1.00
80
3.15
10
.83
.98
.20
.24
17
.79
5
6
.31
26
1.02
8
.39
33
1.30
10
.20
.24
.31
.39
15
17
23
.59
.67
.91
30
1.18
6
10
12
12
.24
.39
.47
.47
4.5
.18
12
8
14
10
12
.31
.39
.47
19
22
Stainless steel
End
Initial
End
.47
7N
1.57 lbf
17 N
3.82 lbf
6N
1.35 lbf
15 N
3.37 lbf
.55
9N
2.02 lbf
24 N
5.40 lbf
8N
1.80 lbf
21 N
4.72 lbf
.75
11 N
2.47 lbf
30 N
6.74 lbf
9N
2.02 lbf
26 N
5.85 lbf
.87
19 N
4.27 lbf
45 N
10.12 lbf
17 N
3.82 lbf
40 N
8.99 lbf
3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements |
3
很抱歉,暂时无法提供与“617-5-M10X1-AN-NI”相匹配的价格&库存,您可以联系我们找货
