12NF46/A
12NF46/A
    JWWINCO
    STAINLESS KNURL NUT TAPPED HOLE
12NF46/A 数据手册
DIN 6303 Knurled Nuts Stainless Steel, with Tapped Through Bore Metric 2 Type A Without dowel pin hole B* With dowel pin hole Metric table Dimensions in: millimeters - inches 1 d1 d3 d4 d 5 H11 e h k Length l M 5 14   .55 20   .79 1.5  .06 2.5  .10 12   .47  8   .31  7   .28 M 6 16   .63 24   .94 1.5  .06 2.5  .10 14   .55 10   .39  8   .31 M 8 20   .79 30  1.18 2  .08 3  .12 17   .67 12   .47 10   .39 M 10 28  1.10 36  1.42 3  .12 4  .16 20   .79 14   .55 12   .47 M 12 32  1.26 40  1.57 4  .16 4  .16 24   .94 16   .63 16   .63 Thread * Not available from stock, requires a minimum order quantity Specification • Stainless steel European Standard No. 1.4305 (AISI 303) Matte shot-blasted finish 3 NI • RoHS compliant Information DIN 6303 knurled nuts are machined from solid bar. The dowel pin hole d 5 in the nut is designed for securing the nut onto a shaft with a dowel or groove pin. see also... • Knurled Nuts GN 536 (Stainless Steel) • Knurled Nuts DIN 466 (Stainless Steel) How to order 1 2 3 DIN 6303-M6-A-NI 2 | 2.2 Tensioning, Clamping with Knobs 1 Thread d1 2 Type 3 Material www.jwwinco.com | phone: 1-800-877-8351
12NF46/A 价格&库存
很抱歉,暂时无法提供与“12NF46/A”相匹配的价格&库存,您可以联系我们找货
