GN 6336.1
GN 6336.2
Star Knobs
Phenolic Plastic
Technopolymer Plastic
with Protruding Steel / Stainless Steel Hub
Inch | Metric
3 Type
E With tapped blind bore
C With plain blind bore, tol. H7
Specification
4
• GN 6336.1
Star knob
Plastic
Duroplast (Phenolic PF)
Black, shiny finish
Hub insert
-- Steel, zinc plated, —
blue passivated finish
-- Stainless steel NI
European Standard No. 1.4305 (AISI 303)
Information
GN 6336.1 and GN 6336.2 star knobs with protruding hub have important advantages:
The face of the hub is exactly square to the bore and is made of steel / stainless steel to prevent edge
breakage.
see also...
• Star Knobs DIN 6336 (Cast Iron / Stainless Steel / Aluminum)
• Star Knobs DIN 6336 (Plastic, without Protruding Hub)
• GN 6336.2
Star knob
Plastic
Technopolymer (Polyamide PA)
-- Shock-resistant
-- Black, matte finish
Hub insert
• RoHS compliant
On request
• Special bores and threads larger than listed
• Other modifications such as cross holes, and
set screw holes
• Special stud variations, either drilled and
pinned or glued into place
How to order (Inch, Phenolic, steel hub)
1
2
3
GN 6336.1-40-B5/16-C
How to order (Metric, Technopolymer, stainless steel hub)
1
2
3
4
GN 6336.2-50-M10-E-NI
2
| 2.2 Tensioning, Clamping with Knobs
1
Handle diameter d1
2
Bore d 3 (Thread d 2 )
3
Type
1
Handle diameter d1
2
Thread d 2 (Bore d 3 )
3
Type
4
Hub material
www.jwwinco.com | phone: 1-800-877-8351
GN 6336.1 / GN 6336.2 Star Knobs continued
Inch table
1
2
d1
d2
Dimensions in: inches - millimeters
2
d 3 +0.001
d4
Thread (Type E)
GN 6336.2
Thread (Type E)
Bore (Type C)
Steel hub
h1
h2
h3
GN 6336.1
GN 6336.2
GN 6336.1
.47
.79
1.02
26
1.02
26
13
.71
1.34
34
1.26
32
17
Stainless steel hub
Steel hub
1.26
32
5/16 x 18
1.57
40
5/16 x 18
3/8 x 16
B 1/4
B 5/16
1.97
50
3/8 x 16
1/2 x 13
1/2 x 13
B 3/8
B 1/2
2.48
63
3/8 x 16
1/2 x 13
B 3/8
B 1/2
.79
42
1.57
40
21
3.15
80
5/8 x 11
B 5/8
.98
25
2.05
52
2.05
52
.98
25
12
14
18
10
.51
.67
.83
t min.
GN 6336.2
13
17
21
.39
.33
8.5
.51
10
.67
10
.83
14
1.06
27
15
.39
.39
12
14
18
.47
.55
.71
.55
.87
22
.59
1.18
30
Metric table
1
d1
2
Dimensions in: millimeters - inches
2
d2
d 3 H7
Thread (Type E)
Bore (Type C)
Steel hub
d4
Stainless steel hub
Steel hub
M 5
M 5
10
M 6
M 6
B 6
12
40
1.57
M 6
M 8
M 8
B 6
B 8
14
50
1.97
M 8
M 10
M 10
B 8
B 10
18
63
2.48
M 10
M 12
M 12
B 10
B 12
3.15
M 12
M 16
M 16
B 16
25
25*
.98
32
1.26
h1
.39
.47
h2
h3
GN 6336.1
GN 6336.2
GN 6336.1
16
21
.83
.79
10
.55
26
1.02
26
1.02
13
.71
34
1.34
32
1.26
17
.79
42
1.65
40
1.57
21
.98
52
2.05
52
2.05
25
8
.39
.51
.67
.83
.98
t min.
GN 6336.2
10
13
17
21
.31
.39
.51
.67
.83
27
1.06
6
.24
8.5
.33
10
10
14
15
.39
.39
.55
.59
9.5
.37
12
14
18
22
.47
.55
.71
.87
30
1.18
*Only available for GN 6336.2
2.2 Tensioning, Clamping with Knobs |
3
很抱歉,暂时无法提供与“10NX37/E”相匹配的价格&库存,您可以联系我们找货
