12MP95/C
12MP95/C
    JWWINCO
    PLASTIC STAR KNOB, STEEL HUB
12MP95/C 数据手册
GN 6336.1 GN 6336.2 Star Knobs Phenolic Plastic Technopolymer Plastic with Protruding Steel / Stainless Steel Hub Inch | Metric 3 Type E With tapped blind bore C With plain blind bore, tol. H7 Specification 4 • GN 6336.1 Star knob Plastic Duroplast (Phenolic PF) Black, shiny finish Hub insert -- Steel, zinc plated, — blue passivated finish -- Stainless steel NI European Standard No. 1.4305 (AISI 303) Information GN 6336.1 and GN 6336.2 star knobs with protruding hub have important advantages: The face of the hub is exactly square to the bore and is made of steel / stainless steel to prevent edge breakage. see also... • Star Knobs DIN 6336 (Cast Iron / Stainless Steel / Aluminum) • Star Knobs DIN 6336 (Plastic, without Protruding Hub) • GN 6336.2 Star knob Plastic Technopolymer (Polyamide PA) -- Shock-resistant -- Black, matte finish Hub insert -- Steel, zinc plated, — blue passivated finish -- Stainless steel NI European Standard No. 1.4305 (AISI 303) • RoHS compliant On request • Special bores and threads larger than listed • Other modifications such as cross holes, and set screw holes • Special stud variations, either drilled and pinned or glued into place How to order (Inch, Phenolic, steel hub) 1 2 3 GN 6336.1-40-B5/16-C How to order (Metric, Technopolymer, stainless steel hub) 1 2 3 4 GN 6336.2-50-M10-E-NI 2 | 2.2 Tensioning, Clamping with Knobs 1 Handle diameter d1 2 Bore d 3 (Thread d 2 ) 3 Type 1 Handle diameter d1 2 Thread d 2 (Bore d 3 ) 3 Type 4 Hub material www.jwwinco.com | phone: 1-800-877-8351 GN 6336.1 / GN 6336.2 Star Knobs continued Inch table 1 2 d1 d2 Dimensions in: inches - millimeters 2 d 3 +0.001 d4 GN 6336.1 / GN 6336.2 Thread (Type E) GN 6336.2 Thread (Type E) GN 6336.1 / GN 6336.2 Bore (Type C) Steel hub h1 h2 h3 GN 6336.1 GN 6336.2 GN 6336.1 .47 - .79 20 - .55 1.02 26 1.02 26 13 .71 1.34 34 1.26 32 17 Stainless steel hub Steel hub 1.26 32 - - 5/16 x 18 - - 1.57 40 5/16 x 18 - 3/8 x 16 B 1/4 B 5/16 1.97 50 3/8 x 16 1/2 x 13 1/2 x 13 B 3/8 B 1/2 2.48 63 3/8 x 16 1/2 x 13 - B 3/8 B 1/2 .79 20 1.65 42 1.57 40 21 3.15 80 5/8 x 11 - - B 5/8 - .98 25 2.05 52 2.05 52 .98 25 12 14 18 10 .51 .67 .83 t min. GN 6336.2 13 17 21 .39 .33 8.5 .51 10 .67 10 .83 14 1.06 27 15 .39 .39 12 14 18 .47 .55 .71 .55 .87 22 .59 1.18 30 Metric table 1 d1 2 Dimensions in: millimeters - inches 2 d2 d 3 H7 GN 6336.1 / GN 6336.2 Thread (Type E) GN 6336.1 / GN 6336.2 Bore (Type C) Steel hub d4 Stainless steel hub Steel hub M 5 - M 5 - - 10 M 6 - M 6 B 6 - 12 40 1.57 M 6 M 8 M 8 B 6 B 8 14 50 1.97 M 8 M 10 M 10 B 8 B 10 18 63 2.48 M 10 M 12 M 12 B 10 B 12 20 80 3.15 M 12 M 16 M 16 B 16 - 25 25* .98 32 1.26 h1 .39 .47 h2 h3 GN 6336.1 GN 6336.2 GN 6336.1 - 16 - 21 .83 20 .63 .79 10 .55 26 1.02 26 1.02 13 .71 34 1.34 32 1.26 17 .79 42 1.65 40 1.57 21 .98 52 2.05 52 2.05 25 8 .39 .51 .67 .83 .98 t min. GN 6336.2 10 13 17 21 .31 .39 .51 .67 .83 27 1.06 6 .24 8.5 .33 10 10 14 15 .39 .39 .55 .59 9.5 .37 12 14 18 22 .47 .55 .71 .87 30 1.18 *Only available for GN 6336.2 www.jwwinco.com | phone: 1-800-877-8351 2.2 Tensioning, Clamping with Knobs | 3
12MP95/C 价格&库存
很抱歉,暂时无法提供与“12MP95/C”相匹配的价格&库存,您可以联系我们找货
