6336.4-ST-50-3/8X16-40
    JWWINCO
    PLASTIC STAR KNOB, STEEL STUD
6336.4-ST-50-3/8X16-40 数据手册
GN 6336.4 GN 6336.5 Star Knobs Steel Threaded Stud Stainless Steel Threaded Stud Plastic h h Inch | Metric d d d Specification 1 • GN 6336.4 -- Star knob Plastic Technopolymer (Polyamide PA) ST Shock-resistant, black, matte finish -- Star knob Plastic Duroplast (Phenolic PF) SK Black, shiny finish (only available in metric sizes) -- Threaded stud Steel, zinc plated, blue passivated finish Information GN 6336.4 and GN 6336.5 star knobs comply with DIN 6336 type L. see also... • Star Knobs GN 6336.10 (with Brass or Nylon Tip) • Star Knobs GN 6336.12 (with Toggle Thrust Pad) • Star Knobs GN 6336.13 (with Loss Protection) • Star Knobs GN 6336.4 / GN 6336.5 with Loss Protection GN 111.7 • GN 6336.5 -- Star knob Plastic Technopolymer (Polyamide PA) ST Shock-resistant, black, matte finish Threaded stud Stainless steel M5 - M10: European Standard No. 1.4567 (AISI 304 Cu) M12: European Standard No. 1.4305 (AISI 303) -- Star knob Plastic Duroplast (Phenolic PF) SK Black, shiny finish Threaded stud Stainless steel A2 • RoHS compliant On request • Special shorter than listed stud lengths and various stud tips How to order (Inch, steel threaded stud) 1 2 3 4 GN 6336.4-ST-25-1/4X20-15 How to order (Metric, stainless steel threaded stud) 1 2 3 4 GN 6336.5-ST-63-M12-40 10 | 2.2 Tensioning, Clamping with Knobs 1 Material 2 Handle diameter d1 3 Thread d 2 4 Length l 1 Material 2 Handle diameter d1 3 Thread d 2 4 Length l www.jwwinco.com | phone: 1-800-877-8351 GN 6336.4 / GN 6336.5 Star Knobs continued Inch table 2 3 d1 d2 Dimensions in: inches - millimeters 4 Length l ≈ GN 6336.4 ST d3 h1 h2 GN 6336.5 ST 0.98 25 1/4 x 20 0.59 15 0.87 22 1.10 28 - - - 0.59 15 0.87 22 1.10 28 1.34 34 - 0.47 12 0.63 16 0.31 8 1.26 32 1/4 x 20 0.43 11 0.63 16 0.71 18 0.94 24 1.22 31 1.46 37 0.43 11 0.75 19 0.94 24 1.26 32 1.46 37 0.55 14 0.79 20 0.39 10 1.57 40 5/16 x 18 0.79 20 0.91 23 1.26 32 1.42 36 1.89 48 - 0.67 17 0.94 24 1.42 36 1.89 48 - 0.71 18 0.98 25 0.51 13 1.97 50 3/8 x 16 0.98 25 1.18 30 1.57 40 1.69 43 2.17 55 - 0.98 25 1.18 30 1.69 43 2.17 55 - 0.87 22 1.26 32 0.67 17 2.48 63 1/2 x 13 - - - - - - 0.75 19 0.98 25 1.97 50 - - 1.02 26 1.57 40 0.83 21 Metric table 2 3 d1 d2 Dimensions in: millimeters - inches 4 Length l ≈ GN 6336.4 d3 h1 h2 GN 6336.5 ST SK ST SK 25 M 5 10 15 20 0.98 0.39 0.59 0.79 25 30 0.98 1.18 - - - - - - - - - 10 15 20 0.39 0.59 0.79 25 0.98 10 15 20 0.39 0.59 0.79 25 0.98 12 0.47 16 8 0.63 0.31 25 M 6 10 16 20 0.98 0.39 0.63 0.79 25 30 0.98 1.18 35 1.38 45 1.77 60 2.36 - - - - - 10 16 20 0.39 0.63 0.79 25 30 0.98 1.18 - - 12 0.47 16 8 0.63 0.31 32 M 6 10 16 20 1.26 0.39 0.63 0.79 25 30 0.98 1.18 35 1.38 45 1.77 60 16 20 2.36 0.63 0.79 25 30 0.98 1.18 35 1.38 45 1.77 10 16 20 0.39 0.63 0.79 25 30 0.98 1.18 10 16 20 0.39 0.63 0.79 25 30 0.98 1.18 14 20 0.55 0.79 10 0.39 - - - 20 0.79 25 30 0.98 1.18 40 1.57 - - - - - 14 20 0.55 0.79 10 0.39 35 1.38 40 1.57 50 1.97 55 2.17 - 40 1.57 M 8 16 20 0.63 0.79 25 30 0.98 1.18 35 1.38 40 1.57 50 1.97 55 2.17 16 20 0.63 0.79 25 30 0.98 1.18 40 1.57 55 2.17 20 0.79 25 30 0.98 1.18 40 1.57 - 20 0.79 25 30 0.98 1.18 40 1.57 - 18 0.71 25 13 0.98 0.51 40 1.57 M 10 15 20 0.59 0.79 25 30 0.98 1.18 35 1.38 40 1.57 45 1.77 55 2.17 - - - - - 20 0.79 25 30 0.98 1.18 45 1.77 55 2.17 - - - - 18 0.71 25 13 0.98 0.51 50 1.97 M 10 15 20 0.59 0.79 25 30 0.98 1.18 35 1.38 40 1.57 45 1.77 55 2.17 25 30 0.98 1.18 35 1.38 45 1.77 55 2.17 - 20 0.79 25 30 0.98 1.18 45 1.77 55 2.17 20 0.79 25 30 0.98 1.18 45 1.77 55 2.17 22 32 0.87 1.26 17 0.67 50 1.97 M 12 20 0.79 25 30 0.98 1.18 35 1.38 40 1.57 50 1.97 60 2.36 - - - - - - 30 1.18 40 1.57 50 1.97 - - - - - - - 22 32 0.87 1.26 17 0.67 63 M 12 20 2.48 0.79 25 30 0.98 1.18 35 1.38 40 1.57 50 1.97 60 2.36 30 1.18 35 1.38 40 1.57 50 1.97 60 2.36 30 1.18 40 1.57 50 1.97 - - 30 1.18 40 1.57 50 1.97 - - 26 1.02 40 1.57 21 0.83 80 3.15 - - - - - 30 1.18 40 1.57 50 1.97 60 70 2.36 2.76 - - - - - - - - - - 35 1.38 50 1.97 25 0.98 - www.jwwinco.com | phone: 1-800-877-8351 - - - - 25 30 0.98 1.18 - - - 32 M 8 16 20 1.26 0.63 0.79 M 16 - - - - 2.2 Tensioning, Clamping with Knobs | 11
1. 物料型号: - GN 6336.4:钢制螺纹杆的星形旋钮 - GN 6336.5:不锈钢螺纹杆的星形旋钮
2. 器件简介: - 星形旋钮有两种材质:塑料(Technopolymer,聚酰胺PA,抗冲击,黑色,哑光表面)和Duroplast(酚醛PF,黑色,光亮表面,仅提供公制尺寸)。 - 螺纹杆材质:GN 6336.4为镀锌钢蓝白钝化表面,GN 6336.5为不锈钢,M5-M10为1.4567(AISI 304 Cu),M12为1.4305(AISI 303),A2不锈钢。
3. 引脚分配:文档中没有明确提及引脚分配,但提供了星形旋钮的尺寸和螺纹规格。
4. 参数特性: - 符合DIN 6336 L型标准。 - 螺纹规格包括M5至M16。 - 提供RoHS合规选项。
5. 功能详解: - 星形旋钮用于张力调节和夹紧。
6. 应用信息: - JWWINCO公司提供多种星形旋钮变体,包括带黄铜或尼龙尖端的GN 6336.10,带切换推力垫的GN 6336.12,带防丢保护的GN 6336.13,以及带防丢保护GN 111.7的GN 6336.4/GN 6336.5。
7. 封装信息: - 提供了详细的尺寸表,包括英寸和毫米单位的直径、螺纹规格、长度等。
6336.4-ST-50-3/8X16-40 价格&库存
很抱歉,暂时无法提供与“6336.4-ST-50-3/8X16-40”相匹配的价格&库存,您可以联系我们找货
