817.2-12-15-M20X1.5-B-NI 数据手册
GN 817.2
Indexing Plungers
Steel / Stainless Steel
Lock-Out and Non Lock-Out, with Extended Height Knob
Inch | Metric
4
B
BK
C
CK
Specification
5
• Threaded body
-- Steel, blackened finish —
Plunger pin hardened
-- Stainless steel NI
European Standard No. 1.4305 (AISI 303)
Plunger pin chemically nickel plated
(only available in metric sizes)
Type
Non lock-out, without lock nut
Non lock-out, with lock nut
Lock-out, without lock nut
Lock-out, with lock nut
Information
GN 817.2 indexing plungers are identical to GN 817 but with an extended height knob.
Lock-out types C / CK are used for applications where the plunger pin needs to stay in its retracted
position. To achieve this, the knob is rotated by 90 degrees after being retracted. A notch keeps the
plunger in the retracted position.
see also...
• List of Indexing Plunger Types
• Knob
Plastic
Technopolymer (Polyamide PA)
-- Temperature resistant up to 230 °F (110 °C)
-- Black, matte finish
-- Not removable
• Inch size lock nut
ANSI/ASME B18.2.2
• Metric size lock nut
DIN 439 B / ISO 4035 / ISO 8675
-- Stainless steel (A2)
• RoHS compliant
How to order (Inch, steel)
1
2
3
4
GN 817.2-5-8-3/8X16-B
How to order (Metric, stainless steel)
1
2
3
4
5
GN 817.2-8-12-M16X1.5-CK- NI
2
| 3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements
1
Pin diameter d1
2
Stroke l1
3
Thread d 2
4
Type
1
Pin diameter d1
2
Stroke l1
3
Thread d 2
4
Type
5
Material
www.jwwinco.com | phone: 1-800-877-8351
GN 817.2 Indexing Plungers continued
Inch table
1
2
3
d1
l1
d2
Pin −0.001
−0.002
Bore +0.001
4
.16
.16
4
.20
5
.20
5
.24
6
.24
6
.31
8
.31
8
.39
10
min.
1.65
42
16
.75
.94
24
1.89
48
18
.75
.94
24
1.89
48
18
1/2 x 13
.91
23
1.18
30
2.28
58
.87
22
6
.35
1/2 x 13
.91
23
1.18
30
2.28
58
.87
22
6
.31
5/8 x 11
1.10
28
1.42
36
2.76
70
1.02
26
8
.47
5/8 x 11
1.10
28
1.42
36
2.76
70
1.02
26
8
.47
5/8 x 11
1.10
28
1.42
36
2.76
70
1.02
26
8
d3
k
l2
l3
l4
6
9
8
12
5/16 x 18
.20
3/8 x 16
.31
3/8 x 16
.24
l4
.83
8
.24
16
16
19
19
.63
l3
16
5
5/16 x 18
l2
1.65
42
6
.16
k
.83
4
12
Thread
Dimensions in: inches - millimeters
d3
.63
21
21
.63
.63
.71
.71
5
5
6
6
A/F
.20
.20
.24
.24
.24
.24
.31
.31
.31
Initial
End
.39
1.01 lbf
4.5 N
2.70 lbf
12 N
.39
.90 lbf
4N
2.81 lbf
12.5 N
.47
1.12 lbf
5N
3.37 lbf
15 N
.47
1.12 lbf
5N
4.05 lbf
18 N
.55
1.46 lbf
6.5 N
4.27 lbf
19 N
.55
1.35 lbf
6N
5.62 lbf
25 N
.67
1.91 lbf
8.5 N
5.85 lbf
26 N
.67
1.91 lbf
8.5 N
6.29 lbf
28 N
.67
2.14 lbf
9.5 N
8.54 lbf
38 N
10
10
12
12
14
14
17
17
17
Spring load ≈
Metric table
1
2
3
d1
l1
d2
Pin −0.02
−0.05
Bore H7
4
4
5
5
6
6
8
8
10
12
.16
.16
.20
.20
.24
.24
.31
.31
.39
.47
min.
4
6
5
8
6
9
8
12
12
15
.16
.24
.20
.31
.24
.35
.31
.47
.47
.59
Thread
Dimensions in: millimeters - inches
A/F
Spring load ≈
Initial
M 8x1
16
.83
42
1.65
16
M 8x1
16
.83
42
1.65
16
M 10 x 1
19
.94
48
1.89
18
M 10 x 1
19
.94
48
1.89
18
M 12 x 1.5
23
.91
30
1.18
58
2.28
22
M 12 x 1.5
23
.91
30
1.18
58
2.28
22
M 16 x 1.5
28
1.10
36
1.42
70
2.76
26
1.02
8
M 16 x 1.5
28
1.10
36
1.42
70
2.76
26
1.02
8
M 16 x 1.5
28
1.10
36
1.42
70
2.76
26
1.02
8
M 20 x 1.5
28
1.10
36
1.42
79
3.11
33
1.30
10
.63
.63
.75
.75
21
21
24
24
.63
.63
.71
.71
.87
.87
5
5
6
6
6
6
.20
.20
.24
.24
.24
.24
.31
.31
.31
.39
10
10
12
12
14
14
17
17
17
22
End
.39
4.5 N
1.01 lbf
12 N
2.70 lbf
.39
4N
.90 lbf
12.5 N
2.81 lbf
.47
5N
1.12 lbf
15 N
3.37 lbf
.47
5N
1.12 lbf
18 N
4.05 lbf
.55
6.5 N
1.46 lbf
19 N
4.27 lbf
.55
6N
1.35 lbf
25 N
5.62 lbf
.67
8.5 N
1.91 lbf
26 N
5.85 lbf
.67
8.5 N
1.91 lbf
28 N
6.29 lbf
.67
9.5 N
2.14 lbf
38 N
8.54 lbf
.87
11.5 N
2.59 lbf
40 N
8.99 lbf
3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements |
3
817.2-12-15-M20X1.5-B-NI 价格&库存
很抱歉,暂时无法提供与“817.2-12-15-M20X1.5-B-NI”相匹配的价格&库存,您可以联系我们找货
