10W24LGF
10W24LGF
    JWWINCO
    STEEL INDEXING PLUNGER TOP MOUNT
10W24LGF 数据手册
GN 817.3 Indexing Plungers Steel, for Precision Locating, with Top Mount Flange, with Cylindrical Plunger Pin Metric 3 Type B Non lock-out C Lock-out Metric table Dimensions in: millimeters - inches 1 2 d1 l1 l2 l3 b d2 d3 d4 k l4 l5 l6 Initial End  6  0.24 18  0.71  9  0.35  9  0.35 13  0.51 23  0.91 4.3 0.17 34  1.34 23  0.91 45  1.77 6 0.24 25  0.98 6N 1.35 lbf 25 N   5.62 lbf  6  0.24 24  0.94  9  0.35 15  0.59 13  0.51 23  0.91 4.3 0.17 34  1.34 23  0.91 45  1.77 6 0.24 25  0.98 6N 1.35 lbf 25 N   5.62 lbf  8  0.31 20  0.79 10  0.39 10  0.39 16  0.63 28  1.10 5.5 0.22 38  1.50 26  1.02 51  2.01 8 0.31 27  1.06 8.5 N 1.91 lbf 28 N   6.29 lbf  8  0.31 26  1.02 10  0.39 16  0.63 16  0.63 28  1.10 5.5 0.22 38  1.50 26  1.02 51  2.01 8 0.31 27  1.06 8.5 N 1.91 lbf 28 N   6.29 lbf 10  0.39 24  0.94 12  0.47 12  0.47 16  0.63 28  1.10 5.5 0.22 38  1.50 26  1.02 51  2.01 8 0.31 27  1.06 9.5 N 2.14 lbf 38 N   8.54 lbf 10  0.39 32  1.26 12  0.47 20  0.79 16  0.63 28  1.10 5.5 0.22 38  1.50 26  1.02 51  2.01 8 0.31 27  1.06 9.5 N 2.14 lbf 38 N   8.54 lbf Pin h6 Stroke Spring load ≈ Specification Information • Body Steel, blackened finish GN 817.3 indexing plungers make highly accurate positioning possible, by utilizing DIN 172 / DIN 179 press-fit drill bushings as a guide. • Plunger pin Steel, hardened and ground The bushings are used to guide the plunger pin as well as for the indexing bore. The plunger pins and bushings are hardened and ground. Larger guide lengths further increase the precision. • Knob Plastic Technopolymer (Polyamide PA) -- Temperature resistant up to 230 °F (110 °C) -- Black, matte finish -- Not removable • RoHS compliant The lock-out type C is used for applications where the plunger pin needs to stay in its retracted position. To achieve this, the knob is rotated by 90 degrees after being retracted. A notch keeps the plunger in the retracted position. see also... • Construction and Assembly Instructions • List of Indexing Plunger Types Accessory • Press-fit drill bushings DIN 172 (with flange) • Press-fit drill bushings DIN 179 (without flange) How to order 1 2 3 GN 817.3-10-24-C 52 | 3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements 1 Pin diameter d1 2 Length l1 3 Type www.jwwinco.com | phone: 1-800-877-8351
10W24LGF 价格&库存
很抱歉,暂时无法提供与“10W24LGF”相匹配的价格&库存,您可以联系我们找货
