822.6-0.249-1/2X20-C 数据手册
GN 822.6
Mini Indexing Plungers
Steel, Lock-Out and Non Lock-Out, with Hidden Lock Mechanism
Inch | Metric
3 Type
B Non lock-out
C Lock-out
Specification
Information
• Threaded body
Steel, zinc plated, blue passivated finish
GN 822.6 mini indexing plungers feature small, compact dimensions.
• Plunger pin
Stainless steel
European Standard No. 1.4305 (AISI 303)
• Spring
Stainless steel
European Standard No. 1.4310 (AISI 301)
• Knob
Plastic
Technopolymer (Polyamide PA)
-- Temperature resistant up to 230 °F (110 °C)
-- Black, matte finish
-- Not removable
• RoHS compliant
Based on the principle of the GN 822 mini indexing plungers, this model combines their clever type of
construction with a complete series of all current sizes of bolts and threads. They provide a reasonably
priced alternative to the GN 607 / GN 607.1 indexing plungers of the appropriate sizes.
Plungers are inserted into position by holding them by the knurled knob. The wrench flats on the lock
nut are exposed when the pin is retracted, so that the plunger can be easily tightened by means of an
open-end wrench.
Type C offers a lock-out position for applications that require the plunger pin to be retracted for an
extended period of time. After retracting the plunger pin, turn the knob 30 degrees, release the
knob and it will stay in the retracted position via the indexing lock. In the rest position, the lock-out
mechanism is completely concealed by the knob.
GN 909 thin hexagon nuts are to be ordered separately.
see also...
• List of Indexing Plunger Types
• Spacer Bushings GN 609.5 (to Limit the Thread Length)
• Locating Bushings GN 412.2 / GN 412.4
Accessory
• Thin hexagon nuts GN 909
On request
• With red knob
How to order (Inch)
1
2
3
GN 822.6-0.155-5/16X24-B
How to order (Metric)
1
2
3
GN 822.6-8-M16x1.5-B
2
| 3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements
1
Pin diameter d1
2
Thread d 2
3
Type
1
Pin diameter d1
2
Thread d 2
3
Type
www.jwwinco.com | phone: 1-800-877-8351
GN 822.6 Mini Indexing Plungers continued
Inch table
1
2
d1
d2
Pin −0.002
Bore +0.001
+0.003
Thread
Dimensions in: inches - millimeters
d3
d4
l1
l2
l3
min.
k
A/F
Spring load ≈
Initial
End
.155
3.9
5/16 x 24
.83
21.1
.59
15.0
1.08
27.4
.20
5.1
.24
6.1
.65
16.5
.39
9.9
.90 lbf
4N
2.70 lbf
12 N
.186
4.7
3/8 x 24
.98
24.9
.71
18.0
1.34
34.0
.24
6.1
.31
7.9
.79
20.1
.47
11.9
1.35 lbf
6N
3.60 lbf
16 N
.249
6.3
1/2 x 20
1.10
27.9
.79
20.1
1.59
40.4
.28
7.1
.39
9.9
.93
23.6
.55
14.0
2.25 lbf
10 N
5.17 lbf
23 N
.311
7.9
5/8 x 18
1.30
33.0
.91
23.1
1.87
47.5
.39
9.9
.47
11.9
1.00
25.4
.67
17.0
2.47 lbf
11 N
7.87 lbf
35 N
Metric table
1
2
d1
d2
Pin h9
Bore +0.03
+0.08
4
5
6
6
7
8
10
.16
.20
.24
.24
.28
.31
.39
Dimensions in: millimeters - inches
Thread
d3
d4
l1
15
.59
27.5
1.08
5
.71
34
1.34
6
.71
34
1.34
6
.79
40.5
1.59
7
.79
40.5
1.59
7
.91
47.5
1.87
10
.91
47.5
1.87
10
M 8
M 8x1
21
M 10
M 10 x 1
25
M 10
M 10 x 1
25
M 12
M 12 x 1.5
28
1.10
M 12
M 12 x 1.5
28
1.10
M 16
M 16 x 1.5
33
1.30
23
M 16
M 16 x 1.5
33
1.30
23
.83
.98
.98
18
18
l2
min.
.20
.24
.24
.28
.28
.39
.39
l3
k
A/F
16.5
.65
10
Spring load ≈
Initial
6
8
8
10
10
12
12
.24
.31
.31
.79
12
.39
23.5
.93
14
.39
23.5
.93
14
.47
25.5
1.00
17
.47
25.5
1.00
17
End
.39
4N
.90 lbf
12 N
2.70 lbf
.47
6N
1.35 lbf
16 N
3.60 lbf
.47
6N
1.35 lbf
16 N
3.60 lbf
.55
10 N
2.25 lbf
23 N
5.17 lbf
.55
10 N
2.25 lbf
23 N
5.17 lbf
.67
11 N
2.47 lbf
35 N
7.87 lbf
.67
11 N
2.47 lbf
35 N
7.87 lbf
3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements |
3
822.6-0.249-1/2X20-C 价格&库存
很抱歉,暂时无法提供与“822.6-0.249-1/2X20-C”相匹配的价格&库存,您可以联系我们找货
