822.8-10-10-C
822.8-10-10-C
    JWWINCO
    ZINC DIE-CAST MINI INDEX PLUNGER
822.8-10-10-C 数据手册
GN 822.8 Mini Indexing Plungers Zinc Die-Cast, Lock-Out and Non Lock-Out, with Hidden Lock Mechanism, Plate Mount Metric 3 Type B Non lock-out C Lock-out Metric table 1 2 d1 l1  4   .16  5   .20  5   .20 Dimensions in: millimeters - inches b1 b2 d 2 −0.15 d3 d4 k l2 l3 l4 l5 Initial End 10   .39 35  1.38 15   .59  8   .31 21   .83 4.3  .17 25   .98 20.5   .81 2  .08 4  .16  5   .20  4N   .90 lbf 12 N   2.70 lbf  6   .24 12   .47 40  1.57 18   .71 10   .39 25   .98 4.3  .17 30  1.18 25.5  1.00 2.5  .10 4  .16  6   .24  6N   1.35 lbf 16 N   3.60 lbf  6   .24  6   .24 12   .47 40  1.57 18   .71 10   .39 25   .98 4.3  .17 30  1.18 25.5  1.00 2.5  .10 4  .16  6   .24  6N   1.35 lbf 16 N   3.60 lbf  8   .31 10   .39 20   .79 50  1.97 23   .91 14   .55 33  1.30 5.3  .21 38  1.50 35  1.38 2.5  .10 5  .20 10   .39 11 N   2.47 lbf 35 N   7.87 lbf 10   .39 10   .39 20   .79 50  1.97 23   .91 14   .55 33  1.30 5.3  .21 38  1.50 35  1.38 2.5  .10 5  .20 10   .39 11 N   2.47 lbf 35 N   7.87 lbf Pin h9 Bore  +0.03 +0.08 Stroke Spring load ≈ Specification Information • Body with mounting plate Zinc die-cast Powder coated Black, textured finish GN 822.8 mini indexing plungers feature small, compact dimensions. They are mounted by countersunk screws. • Plunger pin Stainless steel European Standard No. 1.4305 (AISI 303) • Spring Stainless steel European Standard No. 1.4310 (AISI 301) • Knob Plastic Technopolymer (Polyamide PA) -- Temperature resistant up to 230 °F (110 °C) -- Black, matte finish -- Not removable Type C offers a lock-out position for applications that require the plunger pin to be retracted for an extended period of time. After retracting the indexing pin, turn the knob 30 degrees, release the knob and it will stay in the retracted position via the indexing lock. These mini indexing plungers present an affordable alternative to the GN 608 and GN 608.1 indexing plungers. see also... • List of Indexing Plunger Types • Indexing Plungers GN 817.1 (Lock-Out and Non Lock-Out) • Indexing Plungers GN 608 (Non Lock-Out) • Indexing Plungers GN 608.1 (Lock-Out) • Locating Bushings GN 412.2 / GN 412.4 • RoHS compliant How to order On request • With red knob 2 1 2 3 GN 822.8-6-12-B | 3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements 1 Pin diameter d1 2 Length l1 3 Type www.jwwinco.com | phone: 1-800-877-8351
822.8-10-10-C 价格&库存
很抱歉,暂时无法提供与“822.8-10-10-C”相匹配的价格&库存,您可以联系我们找货
