11TLVS/DN
11TLVS/DN
    JWWINCO
    LEVELING MOUNT, TAPPED THREAD
11TLVS/DN 数据手册
LPSO “Level-It”™ Leveling Mounts Stainless Steel Tapped Socket Type Inch 3 Type B1 Stainless steel base B2 Solid Delrin ® plastic base B3 Molded Delrin ® plastic base Specification Information • Tapped socket Stainless steel, not hardened European Standard No. 1.4305 (AISI 303) LPSO “Level-It”™ leveling mounts swivel 10-15° to all sides of the centerline to adjust to uneven surfaces. They are typically used for leveling machine tools, electronic racks, benches, etc. The large diameter base design assures a solid support. • Type B1 Base Stainless steel European Standard No. 1.4305 (AISI 303) These leveling mounts were developed for applications where the mount needs to be easily removed, a longer than standard stud needs to be attached or the equipment already has a fixed stud on it. • Type B2 / B3 Base Delrin® plastic Temperature resistant up to 180 °F (82 °C) • RoHS compliant To insure a proper leveling mount size, divide the machine weight by the number of mounts required. This will equal the pounds or load per mount. see also... • ”Level-It”™ Leveling Mounts LPSO (Steel Tapped Socket Type) • ”Level-It”™ Leveling Mounts MLPSO (Stainless Steel Tapped Socket Type, Metric Thread) • ”Level-It”™ Leveling Mounts LPST (Stainless Steel Threaded Stud Type) • ”NY-LEV®” Leveling Mounts WN 9000.1 (Nylon Base, Stainless Steel Tapped Socket Type) On request • Non-skid Elastomer pad • Molded Delrin® plastic base in additional sizes • For certain minimum quantities, modifications such as lag bolt holes, custom stud lengths, and other versions of plating How to order 1 2 3 LPSO-1.25-5/16X18-B2 2 | 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements 1 Base diameter d1 2 Thread d 2 3 Type www.jwwinco.com | phone: 1-800-877-8351 LPSO “Level-It”™ Leveling Mounts continued Inch table 1 2 d1 d2 Dimensions in: inches - millimeters l1 l2 A/F Thread t Max. load Stainless steel base Delrin ® plastic base 0.75 19.1 10 x 32 0.53 13.5 0.100 2.5 0.375 9.5 min. 0.17 4.3 700 lbf 3113.75 N 150 lbf 667.23 N 1.00 25.4 1/4 x 20 0.70 17.8 0.141 3.6 0.500 12.7 0.31 7.9 1000 lbf 4448.22 N 200 lbf 889.64 N 1.00 25.4 1/4 x 28 0.70 17.8 0.141 3.6 0.500 12.7 0.31 7.9 775 lbf 3447.37 N 125 lbf 556.02 N 1.25 31.8 5/16 x 18 0.88 22.4 0.170 4.3 0.625 15.9 0.38 9.7 2500 lbf 11120.55 N 250 lbf 1112.05 N 1.25 31.8 5/16 x 24 0.88 22.4 0.170 4.3 0.625 15.9 0.38 9.7 2150 lbf 9563.67 N 200 lbf 889.64 N 1.25 31.8 3/8 x 16 0.88 22.4 0.170 4.3 0.625 15.9 0.38 9.7 3750 lbf 16680.83 N 300 lbf 1334.46 N 1.25 31.8 3/8 x 24 0.88 22.4 0.170 4.3 0.625 15.9 0.38 9.7 3300 lbf 14679.13 N 250 lbf 1112.05 N 1.88 47.8 1/2 x 13 1.13 28.7 0.250 6.4 0.750 19.1 0.44 11.2 5000 lbf 22241.10 N 700 lbf 3113.75 N 1.88 47.8 1/2 x 20 1.13 28.7 0.250 6.4 0.750 19.1 0.44 11.2 4000 lbf 17792.89 N 625 lbf 2780.13 N 2.50 63.5 5/8 x 11 1.25 31.8 0.350 8.9 0.875 22.2 0.45 11.4 6000 lbf 26689.32 N 1200 lbf 5337.86 N 2.50 63.5 5/8 x 18 1.25 31.8 0.350 8.9 0.875 22.2 0.45 11.4 5000 lbf 22241.11 N 1100 lbf 4893.04 N 3.00 76.2 3/4 x 10 1.50 38.1 0.410 10.4 1.062 27.0 0.65 16.5 7400 lbf 32916.84 N 1800 lbf 8006.79 N 3.00 76.2 3/4 x 16 1.50 38.1 0.410 10.4 1.062 27.0 0.65 16.5 6200 lbf 27578.97 N 1650 lbf 7339.56 N 4.00 101.6 7/8 x 14 1.88 47.8 0.440 11.2 1.375 34.9 0.81 20.6 13500 lbf 60050.99 N 1950 lbf 8674.03 N 4.00 101.6 7/8 x 9 1.88 47.8 0.440 11.2 1.375 34.9 0.81 20.6 15000 lbf 66723.32 N 1700 lbf 7561.97 N 4.00 101.6 1 x 8 1.88 47.8 0.440 11.2 1.375 34.9 0.81 20.6 20000 lbf 88964.43 N 2400 lbf 10675.73 N 4.00 101.6 1 x 12 1.88 47.8 0.440 11.2 1.375 34.9 0.81 20.6 18000 lbf 80067.99 N 2250 lbf 10008.49 N 6.00 152.4 1 1/4 x 7 2.75 69.9 0.750 19.1 1.875 47.6 1.00 25.4 43000 lbf 191273.53 N 3600 lbf 16013.59 N www.jwwinco.com | phone: 1-800-877-8351 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements | 3
11TLVS/DN 价格&库存
很抱歉,暂时无法提供与“11TLVS/DN”相匹配的价格&库存,您可以联系我们找货
