LPST
“Level-It”™ Leveling Mounts
Steel Threaded Stud Type
Inch
4
C1
C2
C3
C4
Type
Steel base, yellow zinc plated
Steel base, black oxide finish
Solid Delrin ® plastic base
Molded Delrin ® plastic base
Specification
Information
• Type C1 / C2
-- Base
Steel, yellow zinc plated or black oxide finish
-- Threaded stud with ball end
Steel, hardened
Machined from solid bar
LPST “Level-It”™ leveling mounts swivel 10-15° to all sides of the centerline to adjust to uneven
surfaces. They are typically used for leveling machine tools, electronic racks, benches, etc. The large
diameter base design assures a solid support.
• Type C3 / C4
-- Base
Delrin® plastic
Temperature resistant up to 180 °F (82 °C)
Steel, hardened, yellow zinc plated
• Jam nut
Materials and finishes are the same as the
corresponding stud
A coupling nut is not recommended to use for installation. Use nut on tapped hole of 1 - 1 1/2 times the
thread diameter being used.
To insure a proper leveling mount size, divide the machine weight by the number of mounts required.
This will equal the pounds or load per mount.
The jam nut is a standard part of the assembly.
see also...
• ”Level-It”™ Leveling Mounts LPST (Stainless Steel Threaded Stud Type)
• ”Level-It”™ Leveling Mounts MLPST (Steel Threaded Stud Type, Metric Size)
• ”Level-It”™ Leveling Mounts LPSO (Steel Tapped Socket Type)
• ”NY-LEV®” Nylon Base Leveling Mounts WN 9000
(Nylon Base, Steel Threaded Stud Type)
• RoHS compliant
On request
• Non-skid Elastomer pad
• Molded Delrin® plastic base in additional sizes
• For certain minimum quantities, modifications
such as lag bolt holes and other versions of
plating
How to order
1
2
3
4
LPST-0.75-10X32-1.00-C1
2
| 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements
1
Base diameter d1
2
Thread d 2
3
Stud length l1
4
Type
www.jwwinco.com | phone: 1-800-877-8351
LPST “Level-It”™ Leveling Mounts continued
Inch table
1
2
3
d1
d2
l1
Thread
Dimensions in: inches - millimeters
l2
l3
A/F
Max. load
Steel base
0.75
19.1
10
x 32
1.00
25.4
0.53
13.5
0.156
4.0
0.375
9.5
700 lbf
3113.75 N
150 lbf
667.23 N
0.75
19.1
10
x 32
2.00
50.8
0.53
13.5
0.156
4.0
0.375
9.5
700 lbf
3113.75 N
150 lbf
667.23 N
1.00
25.4
1/4
x 20
1.25
31.8
0.70
17.8
0.188
4.8
0.500
12.7
1000 lbf
4448.22 N
200 lbf
889.64 N
1.00
25.4
1/4
x 20
2.50
63.5
0.70
17.8
0.188
4.8
0.500
12.7
1000 lbf
4448.22 N
200 lbf
889.64 N
1.00
25.4
1/4
x 28
1.25
31.8
0.70
17.8
0.188
4.8
0.500
12.7
775 lbf
3447.37 N
125 lbf
556.02 N
1.25
31.8
5/16
x 18
2.00
50.8
0.88
22.4
0.218
5.5
0.625
15.9
2300 lbf
10230.90 N
250 lbf
1112.05 N
1.25
31.8
5/16
x 24
2.00
50.8
0.88
22.4
0.218
5.5
0.625
15.9
2150 lbf
9563.67 N
250 lbf
1112.05 N
1.25
31.8
3/8
x 16
2.00
50.8
0.88
22.4
0.218
5.5
0.625
15.9
3750 lbf
16680.83 N
300 lbf
1334.46 N
1.25
31.8
3/8
x 16
4.00
101.6
0.88
22.4
0.218
5.5
0.625
15.9
3750 lbf
16680.83 N
300 lbf
1334.46 N
1.25
31.8
3/8
x 24
2.00
50.8
0.88
22.4
0.218
5.5
0.625
15.9
3300 lbf
14679.13 N
250 lbf
1112.05 N
1.88
47.8
1/2
x 13
2.00
50.8
1.13
28.7
0.250
6.4
0.750
19.1
5000 lbf
22241.10 N
700 lbf
3113.75 N
1.88
47.8
1/2
x 13
4.00
101.6
1.13
28.7
0.250
6.4
0.750
19.1
5000 lbf
22241.10 N
700 lbf
3113.75 N
1.88
47.8
1/2
x 20
2.00
50.8
1.13
28.7
0.250
6.4
0.750
19.1
4000 lbf
17792.88 N
625 lbf
2780.13 N
2.50
63.5
5/8
x 11
2.00
50.8
1.25
31.8
0.250
6.4
0.875
22.2
6000 lbf
26689.32 N
1200 lbf
5337.86 N
2.50
63.5
5/8
x 11
4.00
101.6
1.25
31.8
0.250
6.4
0.875
22.2
6000 lbf
26689.32 N
1200 lbf
5337.86 N
2.50
63.5
5/8
x 18
2.00
50.8
1.25
31.8
0.250
6.4
0.875
22.2
5000 lbf
22241.10 N
1100 lbf
4893.04 N
3.00
76.2
3/4
x 10
2.00
50.8
1.50
38.1
0.312
7.9
1.062
27.0
7400 lbf
32916.84 N
1800 lbf
8006.79 N
3.00
76.2
3/4
x 10
4.00
101.6
1.50
38.1
0.312
7.9
1.062
27.0
7400 lbf
32916.84 N
1800 lbf
8006.79 N
3.00
76.2
3/4
x 16
2.00
50.8
1.50
38.1
0.312
7.9
1.062
27.0
6200 lbf
27578.97 N
1650 lbf
7339.56 N
4.00
101.6
7/8
x 9
4.00
101.6
1.88
47.8
0.380
9.7
1.375
34.9
15000 lbf
66723.32 N
1950 lbf
8674.03 N
4.00
101.6
7/8
x 14
4.00
101.6
1.88
47.8
0.380
9.7
1.375
34.9
13500 lbf
60050.99 N
1700 lbf
7561.97 N
4.00
101.6
1
x 8
3.50
88.9
1.88
47.8
0.380
9.7
1.375
34.9
20000 lbf
88964.43 N
2500 lbf
11120.55 N
4.00
101.6
1
x 8
4.25
108.0
1.88
47.8
0.380
9.7
1.375
34.9
20000 lbf
88964.43 N
2500 lbf
11120.55 N
4.00
101.6
1
x 8
6.00
152.4
1.88
47.8
0.380
9.7
1.375
34.9
20000 lbf
88964.43 N
2500 lbf
11120.55 N
4.00
101.6
1
x 12
3.50
88.9
1.88
47.8
0.380
9.7
1.375
34.9
18000 lbf
80067.98 N
2250 lbf
10008.49 N
6.00
152.4
1 1/4 x 7
4.00
101.6
2.75
69.9
0.562
14.3
1.875
47.6
43000 lbf
191273.53 N
3600 lbf
16013.59 N
6.00
152.4
1 1/4 x 7
6.00
152.4
2.75
69.9
0.562
14.3
1.875
47.6
43000 lbf
191273.53 N
3600 lbf
16013.59 N
3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements |
3
很抱歉,暂时无法提供与“3T1250LMB”相匹配的价格&库存,您可以联系我们找货
