10N51AVL/HVY
10N51AVL/HVY
    JWWINCO
    ANTI-VIBRATION LEVELING MOUNT
10N51AVL/HVY 数据手册
MAVLM MAVM “Anti-Vibe®” Anti-Vibration Leveling Mounts Tapped Socket Threaded Stud Steel Metric 4 Type B With light duty pad C With medium duty pad D With heavy duty pad Metric table 1 d1 2 3 d2 l1 Dimensions in: millimeters - inches d3 l2 l3 l4 A/F t Max. load Thread Natural frequency in Hz Light duty Medium duty Heavy duty Light duty Medium duty Heavy duty  31.8 M 10   1.25  50.8  28.0   2.00   1.102 38.1 18.0 4.5 15.9  9.7  1.50  0.708 0.177  0.625  0.38   222.41 N   50.00 lbf   444.82 N   100 lbf   4425.98 N 14    995 lbf 16 14  47.8 M 12   1.88  50.8  43.5   2.00   1.713 44.5 20.0 4.5 19.1 11.2  1.75  0.787 0.177  0.750  0.44   533.78 N   120 lbf   1067.57 N   240 lbf   10675.73 N 14   2400 lbf 16 13  63.5 M 16   2.50  50.8  59.5   2.00   2.342 47.8 21.5 4.5 21.5 15.7  1.88  0.846 0.177  0.845  0.62   978.60 N   220 lbf   1957.21 N   440 lbf   19572.17 N   4400 lbf 13.5 15 12.5  76.2 M 20   3.00  50.8  68.0   2.00   2.677 54.1 22.0 4.5 27.0 19.1  2.13  0.866 0.177  1.063  0.75 1445.67 N   325 lbf   2891.34 N   650 lbf   28913.44 N 13.5   6500 lbf 15 12.5 101.6 M 24   4.00  88.9  96.0   3.50   3.779 63.5 22.0 4.5 34.9 20.6  2.50  0.866 0.177  1.375  0.81 2624.45 N   590 lbf   5248.90 N   1180 lbf   52489.01 N 13   11800 lbf 13.5 11.5 152.4 M 30   6.00 101.6 145.0   4.00   5.709 73.2 19.1 4.5 47.6 25.4  2.88  0.750 0.177  1.875  1.00 6005.09 N 1350 lbf 12054.68 N   2710 lbf 120546.80 N 13   27100 lbf 13 11 Specification Information • Base Steel, yellow zinc plated MAVLM and MAVM “Anti-Vibe ®” anti-vibration leveling mounts swivel 10-15° to all sides of the centerline to adjust to uneven surfaces. • Tapped socket / threaded stud Steel, yellow zinc plated -- Hardened -- Machined from solid bar They are used to reduce transmitted vibration for high precision and computerized machinery. By using the mount which has the maximum load range which comes close to the specific weight required for you need, you may reduce 98% of the transmitted vibrations on most machinery. • RoHS compliant To insure the proper leveling mount size, divide the machine weight by the number of mounts required. This will equal the pounds or load per mount. On request see also... • ”Anti-Vibe ®” Anti-Vibration Leveling Mounts AVLM / AVM (Inch Thread) • For certain minimum quantities, “Anti-Vibe ®” leveling mounts in stainless steel • Vibration Damping Leveling Feet GN 342.1 / GN 342.2 (Metric Thread) How to order (Tapped socket) 1 2 4 MAVLM-1.88-M12-C How to order (Threaded stud) 1 2 3 4 MAVM-4.00-M24-3.50-B 2 | 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements 1 Base diameter d1 2 Thread d 2 4 Type 1 Base diameter d1 2 Thread d 2 3 Stud length l1 4 Type www.jwwinco.com | phone: 1-800-877-8351
10N51AVL/HVY 价格&库存
很抱歉,暂时无法提供与“10N51AVL/HVY”相匹配的价格&库存,您可以联系我们找货
