MLPSO
“Level-It”™ Leveling Mounts
Steel Tapped Socket Type
Metric
3
A1
A2
A3
A4
Type
Steel base, yellow zinc plated
Steel base, black oxide finish
Solid Delrin ® plastic base
Molded Delrin ® plastic base
Metric table
Dimensions in: millimeters - inches
1
2
d1
d2
l1
l2
A/F
19.1
0.75
M 6
13.5
0.53
2.5
0.100
25.4
1.00
M 8
17.8
0.70
31.8
1.25
M 10
47.8
1.88
Thread
t
Max. load
min.
Steel base
9.5
0.375
4.3
0.17
3113.75 N
700 lbf
667.23 N
150 lbf
3.6
0.141
12.7
0.500
7.9
0.31
4448.22 N
1000 lbf
889.64 N
200 lbf
22.4
0.88
4.3
0.170
15.9
0.625
9.7
0.38
16680.83 N
3750 lbf
1334.46 N
300 lbf
M 12
28.7
1.13
6.4
0.250
19.1
0.750
11.2
0.44
22241.10 N
5000 lbf
3113.75 N
700 lbf
63.5
2.50
M 16
31.8
1.25
8.9
0.350
22.2
0.875
11.4
0.45
26689.32 N
6000 lbf
5337.86 N
1200 lbf
76.2
3.00
M 20
38.1
1.50
10.4
0.410
27.0
1.062
16.5
0.65
32916.84 N
7400 lbf
8006.79 N
1800 lbf
101.6
4.00
M 24
47.8
1.88
11.2
0.440
34.9
1.375
20.6
0.81
88964.43 N
20000 lbf
10675.73 N
2400 lbf
152.4
6.00
M 30
69.9
2.75
19.1
0.750
47.6
1.875
25.4
1.00
191273.53 N
43000 lbf
16013.60 N
3600 lbf
Specification
Information
• Type A1 / A2
-- Base
Steel, yellow zinc plated or black oxide finish
-- Tapped socket
Steel, hardened
MLPSO “Level-It”™ leveling mounts swivel 10-15° to all sides of the centerline to adjust to uneven
surfaces. They are typically used for leveling machine tools, electronic racks, benches, etc. The large
diameter base design assures a solid support.
• Type A3 / A4
-- Base
Delrin® plastic
Temperature resistant up to 180 °F (82 °C)
-- Tapped socket
Steel, hardened, yellow zinc plated
• RoHS compliant
These leveling mounts were developed for applications where the mount needs to be easily removed, a
longer than standard stud needs to be attached or the equipment already has a fixed stud on it.
To insure a proper leveling mount size, divide the machine weight by the number of mounts required.
This will equal the pounds or load per mount.
see also...
• ”Level-It”™ Leveling Mounts MLPSO (Stainless Steel Tapped Socket Type)
• ”Level-It”™ Leveling Mounts LPSO (Steel Tapped Socket Type, Inch Thread)
• ”Level-It”™ Leveling Mounts MLPST (Steel Threaded Stud Type)
• ”NY-LEV®” Leveling Mounts WN 9000 (Nylon Base, Steel Tapped Socket Type)
On request
• Non-skid Elastomer pad
• Molded Delrin® plastic base in additional sizes
• For certain minimum quantities, modifications
such as lag bolt holes, custom stud lengths,
and other versions of plating
2
How to order
1
2
3
MLPSO-1.25-M10-A3
| 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements
1
Base diameter d1
2
Thread d 2
3
Type
www.jwwinco.com | phone: 1-800-877-8351
很抱歉,暂时无法提供与“20NLV3”相匹配的价格&库存,您可以联系我们找货
