12NLV2
12NLV2
    JWWINCO
    LEVELING MOUNT, TAPPED THREAD
12NLV2 数据手册
MLPSO “Level-It”™ Leveling Mounts Steel Tapped Socket Type Metric 3 A1 A2 A3 A4 Type Steel base, yellow zinc plated Steel base, black oxide finish Solid Delrin ® plastic base Molded Delrin ® plastic base Metric table Dimensions in: millimeters - inches 1 2 d1 d2 l1 l2 A/F  19.1   0.75 M 6 13.5  0.53  2.5  0.100  25.4   1.00 M 8 17.8  0.70  31.8   1.25 M 10  47.8   1.88 Thread t Max. load min. Steel base Delrin ® plastic base  9.5  0.375  4.3  0.17   3113.75 N    700 lbf   667.23 N   150 lbf  3.6  0.141 12.7  0.500  7.9  0.31   4448.22 N   1000 lbf   889.64 N   200 lbf 22.4  0.88  4.3  0.170 15.9  0.625  9.7  0.38   16680.83 N   3750 lbf   1334.46 N   300 lbf M 12 28.7  1.13  6.4  0.250 19.1  0.750 11.2  0.44   22241.10 N   5000 lbf   3113.75 N   700 lbf  63.5   2.50 M 16 31.8  1.25  8.9  0.350 22.2  0.875 11.4  0.45   26689.32 N   6000 lbf   5337.86 N   1200 lbf  76.2   3.00 M 20 38.1  1.50 10.4  0.410 27.0  1.062 16.5  0.65   32916.84 N   7400 lbf   8006.79 N   1800 lbf 101.6   4.00 M 24 47.8  1.88 11.2  0.440 34.9  1.375 20.6  0.81   88964.43 N   20000 lbf 10675.73 N   2400 lbf 152.4   6.00 M 30 69.9  2.75 19.1  0.750 47.6  1.875 25.4  1.00 191273.53 N   43000 lbf 16013.60 N   3600 lbf Specification Information • Type A1 / A2 -- Base Steel, yellow zinc plated or black oxide finish -- Tapped socket Steel, hardened MLPSO “Level-It”™ leveling mounts swivel 10-15° to all sides of the centerline to adjust to uneven surfaces. They are typically used for leveling machine tools, electronic racks, benches, etc. The large diameter base design assures a solid support. • Type A3 / A4 -- Base Delrin® plastic Temperature resistant up to 180 °F (82 °C) -- Tapped socket Steel, hardened, yellow zinc plated • RoHS compliant These leveling mounts were developed for applications where the mount needs to be easily removed, a longer than standard stud needs to be attached or the equipment already has a fixed stud on it. To insure a proper leveling mount size, divide the machine weight by the number of mounts required. This will equal the pounds or load per mount. see also... • ”Level-It”™ Leveling Mounts MLPSO (Stainless Steel Tapped Socket Type) • ”Level-It”™ Leveling Mounts LPSO (Steel Tapped Socket Type, Inch Thread) • ”Level-It”™ Leveling Mounts MLPST (Steel Threaded Stud Type) • ”NY-LEV®” Leveling Mounts WN 9000 (Nylon Base, Steel Tapped Socket Type) On request • Non-skid Elastomer pad • Molded Delrin® plastic base in additional sizes • For certain minimum quantities, modifications such as lag bolt holes, custom stud lengths, and other versions of plating 2 How to order 1 2 3 MLPSO-1.25-M10-A3 | 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements 1 Base diameter d1 2 Thread d 2 3 Type www.jwwinco.com | phone: 1-800-877-8351
12NLV2 价格&库存
很抱歉,暂时无法提供与“12NLV2”相匹配的价格&库存,您可以联系我们找货
