10N51LP1
10N51LP1
    JWWINCO
    STEEL BASE LEVELING FEET
10N51LP1 数据手册
MLPST “Level-It”™ Leveling Mounts Steel Threaded Stud Type Metric 4 C1 C2 C3 C4 Type Steel base, yellow zinc plated Steel base, black oxide finish Solid Delrin ® plastic base Molded Delrin ® plastic base Specification Information • Type C1 / C2 -- Base Steel, yellow zinc plated or black oxide finish -- Threaded stud with ball end Steel, hardened Machined from solid bar MLPST “Level-It”™ leveling mounts swivel 10-15° to all sides of the centerline to adjust to uneven surfaces. They are typically used for leveling machine tools, electronic racks, benches, etc. The large diameter base design assures a solid support. • Type C3 / C4 -- Base Delrin® plastic Temperature resistant up to 180 °F (82 °C) -- Threaded stud with ball end Steel, hardened, yellow zinc plated Machined from solid bar • Jam nut Materials and finishes are the same as the corresponding stud A coupling nut is not recommended to use for installation. Use nut on tapped hole of 1 - 1 1/2 times the thread diameter being used. To insure a proper leveling mount size, divide the machine weight by the number of mounts required. This will equal the pounds or load per mount. The jam nut is a standard part of the assembly. see also... • ”Level-It”™ Leveling Mounts MLPST (Stainless Steel Threaded Stud Type) • ”Level-It”™ Leveling Mounts LPST (Steel Threaded Stud Type, Inch Size) • ”Level-It”™ Leveling Mounts MLPSO (Steel Tapped Socket Type) • ”NY-LEV®” Leveling Mounts WN 9000 (Nylon Base, Steel Threaded Stud Type) • RoHS compliant On request • Non-skid Elastomer pad • Molded Delrin® plastic base in additional sizes • For certain minimum quantities, modifications such as lag bolt holes and other versions of plating How to order 1 2 3 4 MLPST-1.88-M12-2.00-C1 2 | 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements 1 Base diameter d1 2 Thread d 2 3 Stud length l1 4 Type www.jwwinco.com | phone: 1-800-877-8351 MLPST “Level-It”™ Leveling Mounts continued Metric table 1 2 3 d1 d2 l1 Thread Dimensions in: millimeters - inches l2 l3 A/F Max. load Steel base Delrin ® plastic base 19.1 0.75 M 6 25.4 1.00 13.5 0.53 3.0 0.118 9.5 0.375 3113.75 N 700 lbf 667.23 N 150 lbf 25.4 1.00 M 8 31.8 1.25 17.8 0.70 4.0 0.157 12.7 0.500 4448.22 N 1000 lbf 889.64 N 200 lbf 31.8 1.25 M 10 50.8 2.00 22.4 0.88 5.0 0.197 15.9 0.625 16680.83 N 3750 lbf 1334.46 N 300 lbf 47.8 1.88 M 12 50.8 2.00 28.7 1.13 7.0 0.276 19.1 0.750 22241.10 N 5000 lbf 3113.75 N 700 lbf 63.5 2.50 M 16 50.8 2.00 31.8 1.25 7.0 0.276 22.2 0.875 26689.32 N 6000 lbf 5337.86 N 1200 lbf 76.2 3.00 M 20 50.8 2.00 38.1 1.50 8.0 0.315 27.0 1.062 32916.84 N 7400 lbf 8006.79 N 1800 lbf 101.6 4.00 M 24 88.9 3.50 47.8 1.88 10.0 0.394 34.9 1.375 88964.43 N 20000 lbf 11120.55 N 2500 lbf 101.6 4.00 M 24 108.0 4.25 47.8 1.88 10.0 0.394 34.9 1.375 88964.43 N 20000 lbf 11120.55 N 2500 lbf 152.4 6.00 M 30 101.6 4.00 69.9 2.75 16.0 0.630 47.6 1.875 191273.53 N 43000 lbf 16013.59 N 3600 lbf 152.4 6.00 M 30 152.4 6.00 69.9 2.75 16.0 0.630 47.6 1.875 191273.53 N 43000 lbf 16013.59 N 3600 lbf www.jwwinco.com | phone: 1-800-877-8351 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements | 3
10N51LP1 价格&库存
很抱歉,暂时无法提供与“10N51LP1”相匹配的价格&库存,您可以联系我们找货
