MLPST
“Level-It”™ Leveling Mounts
Stainless Steel Threaded Stud Type
Metric
4
Type
D1 Stainless steel base
D2 Solid Delrin ® plastic base
D3 Molded Delrin ® plastic base
Specification
Information
• Threaded stud with ball end
Stainless steel
European Standard No. 1.4305 (AISI 303)
Machined from solid bar
MLPST “Level-It”™ leveling mounts swivel 10-15° to all sides of the centerline to adjust to uneven
surfaces. They are typically used for leveling machine tools, electronic racks, benches, etc. The large
diameter base design assures a solid support.
• Type D1
Base
Stainless steel
• Type D2 / D3
Base
Delrin® plastic
Temperature resistant up to 180 °F (82 °C)
• Jam nut
Materials and finishes are the same as the
corresponding stud
• RoHS compliant
A coupling nut is not recommended to use for installation. Use nut on tapped hole of 1 - 1 1/2 times the
thread diameter being used.
To insure a proper leveling mount size, divide the machine weight by the number of mounts required.
This will equal the pounds or load per mount.
The jam nut is a standard part of the assembly.
see also...
• ”Level-It”™ Leveling Mounts MLPST (Steel Threaded Stud Type)
• ”Level-It”™ Leveling Mounts LPST (Stainless Steel Threaded Stud Type, Inch Size)
• ”Level-It”™ Leveling Mounts MLPSO (Stainless Steel Tapped Socket Type)
• ”NY-LEV®” Nylon Base Leveling Mounts WN 9000.1
(Nylon Base, Stainless Steel Threaded Stud Type)
On request
• Non-skid Elastomer pad
• Molded Delrin® plastic base in additional sizes
• For certain minimum quantities, modifications
such as lag bolt holes and other versions of
plating
How to order
1
2
3
4
MLPST-1.25-M10-2.00-D2
2
| 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements
1
Base diameter d1
2
Thread d 2
3
Stud length l1
4
Type
www.jwwinco.com | phone: 1-800-877-8351
MLPST “Level-It”™ Leveling Mounts continued
Metric table
1
2
3
d1
d2
l1
Thread
Dimensions in: millimeters - inches
l2
l3
A/F
Max. load
19.1
0.75
M 6
25.4
1.00
13.5
0.53
3.0
0.118
9.5
0.375
3981.15 N
895 lbf
667.23 N
150 lbf
25.4
1.00
M 8
31.8
1.25
17.8
0.70
4.0
0.157
12.7
0.500
6174.13 N
1388 lbf
889.64 N
200 lbf
31.8
1.25
M 10
50.8
2.00
22.4
0.88
5.0
0.197
15.9
0.625
16680.83 N
3750 lbf
1334.46 N
300 lbf
47.8
1.88
M 12
50.8
2.00
28.7
1.13
7.0
0.276
19.1
0.750
22241.10 N
5000 lbf
3113.75 N
700 lbf
63.5
2.50
M 16
50.8
2.00
31.8
1.25
7.0
0.276
22.2
0.875
26689.32 N
6000 lbf
5337.86 N
1200 lbf
76.2
3.00
M 20
50.8
2.00
38.1
1.50
8.0
0.315
27.0
1.062
32916.84 N
7400 lbf
8006.79 N
1800 lbf
101.6
4.00
M 24
88.9
3.50
47.8
1.88
10.0
0.394
34.9
1.375
111205.54 N
25000 lbf
11120.55 N
2500 lbf
101.6
4.00
M 24
108.0
4.25
47.8
1.88
10.0
0.394
34.9
1.375
111205.54 N
25000 lbf
11120.55 N
2500 lbf
152.4
6.00
M 30
101.6
4.00
69.9
2.75
16.0
0.630
47.6
1.875
191273.53 N
43000 lbf
16013.59 N
3600 lbf
152.4
6.00
M 30
152.4
6.00
69.9
2.75
16.0
0.630
47.6
1.875
191273.53 N
43000 lbf
16013.59 N
3600 lbf
3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements |
3
很抱歉,暂时无法提供与“30N102LVP”相匹配的价格&库存,您可以联系我们找货
