MM 100
“Mighty Mount”™ Heavy Duty Vibration Mounts
Steel, Fixed Threaded Stud Type, with Rubber Pad
Inch | Metric
4 Type
D With heavy duty pad
Specification
Information
• Base
High strength steel, safety yellow powder
coated
Similar to Barrymounts®, MM 100 “Mighty Mount”™ heavy duty vibration mounts are ideal for drill
presses, grinders, CNC machines, die casting machines, punch presses, saws, and injection molding
equipment.
• Hexagon cap screw
Steel
-- Grade 8
-- Zinc plated
-- Bolt is separate, screws into mount base
-- Hexagon nut is included
They offer a high level of shock and vibration isolation for an extended machinery life and reduce noise
levels.
• Vibration damping pad
Elastomer rubber
-- High density
-- Non-skid
• RoHS compliant
They are sturdy, have a reliable construction and a safety yellow finish. The full inch of elastomer
padding is oil resistant.
To insure a proper vibration mount size, divide the machine weight by the number of mounts required.
This will equal the pounds or load per mount.
see also...
• Vibration Damping Leveling Feet EN 248
• Anti-Vibration Leveling Mounts LP 100 / LP 100.1
• ”Anti-Vibe ®” Anti-Vibration Leveling Mounts AVM
• ”Anti-Vibe ®” Anti-Vibration Leveling Mounts MAVM
• Vibration Damping Leveling Feet GN 342.2
On request
• For certain minimum quantities, other sizes and
bolt lengths
How to order (Inch)
1
2
3
4
MM100-2.00-1/4X28-1.75-D
How to order (Metric)
1
2
3
4
MM100-5.00-M12-5.00-D
2
| 3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements
1
Diameter d1
2
Thread d 2
3
Stud length l1
4
Type
1
Diameter d1
2
Thread d 2
3
Stud length l1
4
Type
www.jwwinco.com | phone: 1-800-877-8351
MM 100 “Mighty Mount”™ Heavy Duty Vibration Mounts continued
Inch table
1
2
3
d1
d2
l1
Dimensions in: inches - millimeters
l2
h
Load rating
Thread
min.
max.
2.00
50.8
1/4 x 28
1.75
44.5
1.00
25.4
0.24
6.1
30.00 lbf
133.44 N
100.00 lbf
444.82 N
2.00
50.8
3/8 x 16
3/8 x 24
3.00
76.2
1.00
25.4
0.24
6.1
100.00 lbf
444.82 N
300 lbf
1334.46 N
3.00
76.2
3/8 x 16
3/8 x 24
3.00
76.2
1.50
38.1
0.39
9.9
100.00 lbf
444.82 N
300 lbf
1334.46 N
3.00
76.2
1/2 x 13
6.00
152.4
1.50
38.1
0.39
9.9
100.00 lbf
444.82 N
300 lbf
1334.46 N
5.00
127.0
1/2 x 13
5.00
127.0
1.50
38.1
0.47
11.9
500 lbf
2224.11 N
1500 lbf
6672.33 N
5.00
127.0
5/8 x 11
8.00
203.2
1.50
38.1
0.47
11.9
500 lbf
2224.11 N
1500 lbf
6672.33 N
6.00
152.4
1/2 x 13
3/4 x 10
5.00
127.0
1.73
43.9
0.43
10.9
1000 lbf
4448.22 N
4200 lbf
18682.53 N
6.00
152.4
3/4 x 10
8.00
203.2
1.73
43.9
0.43
10.9
1000 lbf
4448.22 N
4200 lbf
18682.53 N
Metric table
1
2
3
d1
d2
l1
Dimensions in: millimeters - inches
l2
h
Load rating
Thread
min.
76.2
3.00
M 10
76.2
3.00
38.1
1.50
9.9
0.39
127.0
5.00
M 12
127.0
5.00
38.1
1.50
11.9
0.47
444.82 N
100.00 lbf
2224.11 N
500 lbf
max.
1334.46 N
300 lbf
6672.33 N
1500 lbf
3.4 Installing, Lifting, Damping with Leveling Feet, Lifting Gear and Rubber Elements |
3
很抱歉,暂时无法提供与“8T5FA2”相匹配的价格&库存,您可以联系我们找货
